09-20-2018, 11:50 AM | #1 |
"Punished"
Rep 4
LS swapped f30
just kinda throwing the idea out there...would it be possible to LS swap an F30...in my case i got an M-Sport RWD 328i...it would be dope tbh.
09-20-2018, 12:23 PM | #3 |
"Punished"
Rep 4
09-20-2018, 12:40 PM | #6 |
Rep 640
Drives: 2008 M3 (E93)
LS swap on an F30 would be a magical thing
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
09-20-2018, 01:25 PM | #7 |
Rep 5,364
Anything is possible. Just be prepared to spend about $20-30K+ to do it and pray you can get all the electronics to happily talk to one another. You'll also lose out on BMW refinement as you'll be making your own engine and motor mounts. I'd also suggest going with a 6MT as there's no way the ZF auto will work. Lining up the shifter to fit into the BMW shifter console opening could be a problem.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
09-20-2018, 02:13 PM | #8 | |
Rep 5,984
09-20-2018, 02:41 PM | #9 |
Rep 5,364
I'll just say that if you have to ask, then you likely have not a clue about what all is involved. You can't even replace a battery in these cars without some level of programming. I'll leave it at that.
eluded3005.00 |
09-20-2018, 02:45 PM | #10 | |
Rep 5,984
09-20-2018, 03:04 PM | #11 |
Rep 7
Buy a Camaro, put a few M badges on it and call it a day.
09-20-2018, 09:15 PM | #12 |
Rep 1,290
09-21-2018, 03:40 AM | #13 |
Rep 355
09-21-2018, 08:00 AM | #14 |
Rep 1,290
Yeah, it has the ls3 from the previous zeta chassis camaro, and c6 vette I believe. There seems to be some nice used ones available, depending on location. A '16 or '17 with low miles will run about 40k+. An older one (some also with low miles) can be any where from around 33 to 36k. Manuals are harder to find, and usually have an asking price on the higher end of that spectrum.
09-25-2018, 11:54 AM | #15 |
"Punished"
Rep 4
hey i really appreciate all the help guys...might end up trying to do and n54 or s85 swap in the long run like way out...as of now im probably gonna run a dinan signature s2 kit...unless you guys got any other ideas for the n20 engine in the sense of power adders?
-thanks |
09-25-2018, 10:45 PM | #16 | |
Rep 5,984
10-02-2018, 02:37 AM | #17 | |
Rep 1,666
https://en.wikipedia.org/wiki/ZF_8HP_transmission |
engine swap |
