11-04-2018, 07:54 AM | #1 |
Rep 32
N26 Valvetronic servomotor failure at 68k
I just purchased my '13 328i M-sport xDrive from a private seller in NY - took a train from Philly to pick it up and drive it home. Less than a week later after getting a handful of Drivetrain Malfunction warnings and one limp-mode instance, I started the car Thursday evening to extremely rough idle and limp mode - not drivable.
I had it towed to an indy specialist in my area (Western suburbs of Philly) who diagnosed a failed valvetronic servomotor. They're still working on the quote as they need cost of additional parts required from BMW, but I've been told over $3k to have it replaced - I'm guessing close to $4k when the estimate is complete. Some background - the timing chain was replaced in March of this year at the prior owner's BMW dealership at 64k miles and BMW covered the cost - the seller had reported screeching at start up like a slipping belt. I handed over the service receipt for the rebuild to my local center so they can review what was done and consult with the dealership about potential warranty coverage (though I have little hope for this outcome). I'm not a litigious person and frankly, I don't know how I could prove the seller knew of impending valvetronic servomotor failure, but stomaching a $4k bill after just buying the car makes me sick to my stomach. That's nearly 30% of my purchase price on the car! I was planning to ask the guy for help on the repair - on the order of 50%+... thoughts? I will be seeking a second opinion but I know the place (Bavarian Motor Sport Kennett Square, PA) is competent - it's well-rated and other local mechanics have respect for the guys there. So I've got some questions and am seeking the collective advice of folks here - - I've searched on this and don't see that it's a common failure - has anyone else experienced this and, if so, what was the outcome? - no-brainer, get a second opinion? - what are the typical costs seen with this replacement from other indys? - since the timing chain was recently replaced, but clearly not anything else that wasn't already defective, what would be some items to consider replacing beyond plugs and coils while they're in there considering the engine has 70k miles on it? Any advice, help, or referrals to other competent service techs in the vicinity who might be able to do this for less would be greatly appreciated. |
11-04-2018, 07:59 AM | #2 |
Rep 5,984
Did you know the vehicles history prior to purchase, like the timing chain issue? Even if you scored a deal it would not be worth it with a a $4k repair after purchase which is nearly half the retail value of the car. Best to go CPO unless the car has a clean history with no issues or recalls.
11-04-2018, 08:08 AM | #3 | |
Rep 32
sspade2464.50 |
11-04-2018, 09:34 AM | #4 |
Rep 5,457
Drives: F30
Sorry to hear about your situation...
Have not heard of that failure yet on N20/N26. Hoping someone else chimes in that has. Searched realoem for the part number but was unable to locate. Internet search reveals this was a common issue on E90 body but not (yet) on F30. I would get a code scanner (BimmerLink and OBD dongle) to see what codes may be present yourself. Keep us posted on the outcome. |
flysmith8.00 |
11-04-2018, 09:37 AM | #5 |
Rep 5,457
Drives: F30
I would want the previous owner to make good for the failure as well but I highly doubt that will happen.
This is the risk of buying used vehicles especially high end ones. Get a code scanner and research the crap out of this forum for simple DIY's so that you dont have to pay an indy for easy stuff you can do yourself. |
flysmith8.00 |
11-04-2018, 09:50 AM | #6 | |
Rep 5,984
11-04-2018, 10:16 AM | #7 |
Rep 3,679
Definitely not a common failure for the F30s. I've spent a good bit of time on here and I believe you're the first instance of valvetronic servomotor failure I've seen. For that reason it's hard for us to give you a window of what a reasonable repair price would be considering this isn't something that happens often. Also, it's up to you to get a second opinion or not. It can never hurt, other than it being a waste of your time if the second opinion is the same as the first. If you trust the mechanic the car is at now, I wouldn't necessarily recommend a second opinion but I also wouldn't recommend against it.
As far as other stuff you should doing maintenance wise at 70k miles, plugs and coils is a good idea, and it would probably be wise to service all fluid. If it shows a trans fluid change 10k miles ago on the vehicle history, then obviously don't worry about it, but I doubt that will be the case. So I would look into doing (preventatively and just to keep the car in good working order as long as possible): trans fluid, diff fluid, engine oil, plugs and coils, coolant flush. Look for if/when any of these things were last done on your car, and then consider performing these maintenance items accordingly.
11-04-2018, 10:28 AM | #8 |
Rep 943
Drives: F30 328i Msport
Why would the seller have to pay anything? If the car was driving/running fine when he sold it to you then thats that. Is it bad luck that this would happen? Certainly, is it his fault in any way? Nope.
11-04-2018, 10:48 AM | #9 | |
Rep 32
I watched a video in Portuguese of a valvetronic replacement and it doesn't appear to be a straightforward DIY project, and especially not for myself. |
11-04-2018, 10:57 AM | #10 |
Rep 16,054
FWIW once out of warranty you should not be going to a dealer for service. Dealers make little to no money selling cars, so the service department is what supports the entire operation. Go to an indy that specializes in German cars. Also, this is what you're paying $3k plus to replace:
https://www.fcpeuro.com/products/bmw...hoCABsQAvD_BwE |
11-04-2018, 11:24 AM | #11 | |
Rep 32
Yes. I found the part online, too, and was shocked there could be that much labor to get it in and out to run up a $3k+ tab. Any hardcore hobbyists in the Philly area want to take the job on? Last edited by flysmith; 11-04-2018 at 01:32 PM.. |
11-04-2018, 11:28 AM | #12 |
Rep 32
Here's the video I found online. You can turn on close caption auto translate to understand what they're saying if you don't speak Portuguese.
It looks pretty buried in the block... |
11-04-2018, 01:31 PM | #13 |
Rep 32
11-04-2018, 04:37 PM | #14 | ||
Rep 5,984
11-04-2018, 04:44 PM | #15 |
Rep 3,679
Agreed, something I would probably leave to a professional.
11-06-2018, 01:05 PM | #17 |
Rep 2,382
I would not. You're likely going to further damages.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
11-07-2018, 06:47 PM | #18 |
Rep 32
There's hope!
Major update to the story. I called the dealer who rebuilt the motor earlier this year. Those repairs / replacements are warranted for two years, but although there was a valvetronic error, they didn't replace the servomotor and it tested clear after they completed their repairs, so it doesn't fall under that coverage.
However, the SA informed me that the valvetronic servomotor was included the category of parts that are SULEV-related since my model was purchased in NY state. My 328 is a SULEV (super ultra-low emissions vehicle) model - I didn't realize there was a difference. Shame on me. In any case, the SA told me that if the vehicle was registered in a SULEV state (which it's not), the valvetronic motor would be covered under the extended warranty for that category of parts. SULEV coverage extends anywhere from 70-150k and up to 15 years depending on the parts. In my zest to find a loophole to this warranty coverage exclusion for non-SULEV state residents, I started googling and found an old thread where someone mentioned that the BMW warranty did not specify where subsequent owners of the vehicles had to reside / have the vehicle registered to get the coverage. Mind you, the OP was referring to a 2004 328i, so I found and downloaded the warranty for 2013. In the 2013 warranty, BMW does specify where they will honor SULEV part warranty coverage and it turns out that my state (PA) is one of the handful of non-SULEV mandated states where BMW will honor the coverage. My guess is that BMW does this as they presume used vehicles will trade in a multi-state region around the state of original purchase. So... the Service Manager of my local dealership is doing his due diligence to ensure the part is truly covered before I have my 328 towed in for service, but I'm quite hopeful that I'll dodge the $3k bullet on this repair. I'll post another update once the vehicle is either in the shop or if they ultimately deny the claim. Hope springs eternal! |
11-07-2018, 07:06 PM | #19 | |
Rep 10,249
11-07-2018, 07:22 PM | #20 | |
Rep 3,679
12-11-2018, 06:29 PM | #21 |
Rep 136
I actually have an F30 N55 2013, was told by an indy shop here in Richmond Hill Queens NYC, that my valvetronic motor + eccentric shaft needs replacement...my car also threw a drivetrain malfunction, which would get thrown everytime I start the car.
I recall a 400ish$ quote for the motor, 120ish$ for a harness, and 550ish$ for the eccentric shaft + 750 for labor... though its supposed to be about 1200-1500$ for labor, quite a bit of work is involved. |
12-05-2019, 10:59 AM | #22 | |
Masterchief
354
Rep 1,003
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
