09-19-2019, 01:18 PM | #1 |
Rep 66
Is this fixable/repairable?
I have a pair of "Future Design" CF replacement mirrors. Last week I noticed that the Carbon looks cloudy/foggy. Is there anything I can do to fix this?
09-19-2019, 01:55 PM | #2 |
Rep 121
This looks like the sort of haziness that often appears on older headlights with polycarbonate lenses. I have had good luck restoring those the Chemical Guys compounds (V32-V38) on polishing pads on a random-orbital machine, but probably any fine rubbing compound would do. Of course, try a test patch in the most inconspicuous spot to make sure you don't cut through to the color layer.
DarkF3054.00 |
09-19-2019, 02:14 PM | #4 |
Rep 338
https://www.youtube.com/results?sear...e+clear+carbon
try something like this...i had restore a few CF items in the past using similar method |
09-19-2019, 03:08 PM | #5 |
Rep 17
I've had decent luck with wetsanding and polishing on something like this, but who knows if this part has already had that done to it. You risk sanding through the clear. Unless you have decent knowledge of wetsanding/polishing (or the tools to do it) you might be better off just going to a body shop that does work for dealerships (mobile or retail shop) and asking them what they would charge you to re-clear those. In my opinion, that would be the easiest way to get good results. Again, that's IF you do not have the tools/know-how to wetsand/polish.
09-20-2019, 03:58 AM | #6 | |
Rep 202
However, before you spend money on a body shop repair, first try polishing like others have suggested. Go with a Menzerna polish like SF4800 and a coarse hand polishing pad and it should come right back. If not, use my guide here to re-clear and wet sand yourself. DIY: An Enthusiasts Guide to Painting with Rattle Cans https://f30.bimmerpost.com/forums/sh....php?t=1653152 Those parts are about as easy as it gets to paint. Just ignore everything in the guide before the clear coating stage and you'll fix that for around 10 bucks |
09-20-2019, 12:25 PM | #7 | |
Rep 17
Your rattle can write-up would be a good option for this for sure! I hadn't seen that one yet! |
B1ue52127.00 |
09-20-2019, 09:01 PM | #8 |
Yoda of mods
1673
Rep 3,005
Drives: X5 RWD
Not worth repairing. IMO
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos Last edited by EDWYER; 09-20-2019 at 09:09 PM.. |
12-08-2019, 03:15 PM | #9 | |
Rep 109
if those don't work, buy a can of 2K CLEAR, make sure it's the 2k kind as that is what will not only give you high gloss but also a weather resistant and durable clear coat This is what I used : https://www.amazon.com/Sp*****x-Glam...s%2C204&sr=8-3 |
