10-31-2019, 07:09 AM | #23 | |
M340i
392
Rep 967
Drives: BMW M340i
10-31-2019, 11:16 AM | #24 |
Rep 7,597
Awesome, thank you. I also have stock exhaust, so this will be exactly the sound difference i am looking to see.
11-12-2019, 02:24 PM | #25 |
Rep 7,597
bump - did you get a chance to install this yet? curious for results.
11-14-2019, 06:19 PM | #26 |
M340i
392
Rep 967
Drives: BMW M340i
Yes I did but could not find this thread to post links to the sound clips. It definitely made a nice difference in power even though I am still bm3 stage 1. It did not change the exhaust note as much as I expected. It is barely noticeable. On cold start up there is a deeper sound and a tiny bit of rasp but I doubt nobody but a Bimmer enthusiast would notice. In the car you really don't hear much increase in sound. It sounds much louder on the video. It also really quiets down after about a minute or two. This is good since I didn't want to be ricey.
Here is the link: https://www.youtube.com/channel/UCw7...SynoUzRNTlrmA/ |
11-14-2019, 06:38 PM | #27 |
Uhh... Khakis?
54
Rep 155
The VRSF catted DP will throw a code sooner or later. For those considering a catted DP for emissions and CEL do your research because if you’re trying to save money and skip on Fabspeed, CG or even Wagner you may as well go catless.
11-14-2019, 08:16 PM | #28 | |
Rep 7,597
My other question was about the smell - any noticable increase compared to stock? I know it will eventually throw a code and am not really concerned about emissions, I just don't want the smell of a catless DP. I have a catless 3000gt and i know how bad it is (although im sure a modern car would be a little less bad). |
11-24-2019, 05:19 PM | #29 | |
M340i
392
Rep 967
Drives: BMW M340i
So the install was a pain like most have said. It is a smaller cat which should be easier to install but it is not. It is a real pain in the ass to get the top v-band clamp on from the turbo to the downpipe. It took me at least an hour and a half to get it on. After that the exhaust what never going to bolt up to the back of the downpipe. There was at least a 1/2" gap. The v-band clamp would not pull it together. I ended up dropping the exhaust where ever it was connected to the car. This allowed me to pull it in the mate up with the downpipe. Once it was secured with the v-band I bolted the exhaust back up. Work fine and was easy. I can not smell a difference from oem. It seems to be doing a good job at burning residual fuel. I had an 07 Acura TL-S with test pipes and it smelled pretty bad. You should be fine with a catted pipe. I many be the winner for fastest cel though. I got the check engine light for the cat after maybe 2 miles. Didn't cause any issues and I was able to suppress it in bootmod3. So to recap I am stage 1 tune with full bolt on EWG N55. The power and sound are very nice!!! Stage 2 should be coming soon.... |
11-24-2019, 09:22 PM | #30 | |
Rep 7,597
11-25-2019, 12:56 PM | #31 |
Rep 205
Don't mean to threadjack, but does anyone know how durable/reliable the high-flow catted DPs are?
Not only are they significantly more expensive than catless DPs, but they're also prone to breaking since they still have cats. |
11-25-2019, 02:25 PM | #32 | |
Rep 7,597
Now if you are using excessive burbles that would most likely shorten the lifespean and probably cause issues in the long run. I have no interest in running burbles (above stock tune) so not a concern of mine. |
11-25-2019, 10:48 PM | #33 | |
Rep 205
11-26-2019, 10:19 AM | #34 | |
Rep 115,980
Some cats are VERY expensive and some are VERY cheap. So that is what drives the cost. For example HJS cats are SUPER expensive but they guarantee no CEL. Mike |
pkiledj46.00 |
11-26-2019, 11:28 AM | #35 | |
Rep 190,725
I probably would not run aggressive burble though
pkiledj46.00 |
11-26-2019, 04:50 PM | #36 | ||
Rep 194
