12-03-2019, 03:08 PM | #1 |
Rep 1,282
Which ots tune to run?
Planning to install the xdi 35 hpfp this weekend. What OTS tune can I run while I get the custom tune. I notice BMW DIY GUY is running a custom tune and got 419whp on stock turbo. I plan to get a custom cary jordan tune after the holidays. Would it be safe to run the BM3 stage 2H e30 tune? I read that others were doing it with stock hpfp but they were getting knocks in their logs. Would me having the xdi 35 make a difference? Below is the post I am talking about.
https://f30.bimmerpost.com/forums/sh....php?t=1641253
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
12-03-2019, 05:58 PM | #2 |
DisplacementReplacement
409
Rep 1,101
I'm definitely under the impression that you need to have a specific tune for that hpfp. With that said, I know MHD has a box check off for the pump, I don't have BM3 so I don't know but would assume they do also.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
12-03-2019, 06:05 PM | #3 |
Rep 1,282
Yes, bm3 does as well. From what I was told it changes the parameters. And the car will run fine once I choose the xdi option.
12-04-2019, 05:33 AM | #4 |
409
Rep 1,101
Off topic but the 3.5 Tmap is which one? Is it the Tmap used on the BMW 4 cyl turbo and is this allowing more load/boost?
12-04-2019, 09:37 AM | #5 | |
Rep 1,282
12-04-2019, 06:09 PM | #6 | |
Rep 2,357
(A Dane in China) |
12-04-2019, 06:41 PM | #7 | ||
Rep 1,282
12-04-2019, 07:01 PM | #8 |
Rep 2,357
Ahhh, sorry I misunderstood. You sure can but it might affect your ign timing in a negative way so you loose power on that account.
(A Dane in China) |
12-04-2019, 08:01 PM | #9 | |
Rep 1,282
12-06-2019, 02:48 PM | #10 |
3441
Rep 79,211
You sound like a candidate ready for a turbo upgrade.
oma3710194.50 BeerHerder250.50 |
12-08-2019, 02:19 PM | #11 |
Uhh... Khakis?
54
Rep 155
Did you already upgrade to a stage 2+ lpfp? If not, you should if you’re planning on running an e3/40 mix. 450whp will likely require a turbo upgrade but please keep us posted with the dyno run results after the custom tune.
oma3710194.50 |
12-09-2019, 07:43 AM | #12 |
Rep 1,282
From what I have read no need to replace the lpfp. I run e30 now on stock hpfp. I am pretty sure I can run e30-e40 with the aftermarket hpfp.
Jake From State Farm54.00 |
12-13-2019, 01:05 PM | #13 |
Rep 1,282
What is the target boost on the bm3 tage 2h e30 tune?
