BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Any Other High-Mileage 328d's Out There?
proTUNING Freaks
      02-26-2019, 05:33 PM   #199
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Originally Posted by Grammarking View Post
I cleaned it and broke the flips off.
I'll be at 200k by June
Is the warning light for the missing swirl flaps?
      02-27-2019, 07:08 AM   #200
Enabled
Drives: 328xd Wagon, M2 Competition
New gasket with flaps is $52 or less.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      02-27-2019, 07:34 AM   #201
n00bkiller944
Drives: '14 328d M Sport
How did you clean it and how did it turn out?
      04-11-2019, 03:41 AM   #202
Grammarking
Drives: BMW 328d
Been on vacation.
Used a toothbrush and parts cleaner...
Buying new flaps/gasket and using a pressure washer this time.
328iX785.50
Gabreigns493.50
      04-11-2019, 11:28 AM   #203
328iX
David
328iX's Avatar
Been on vacation.
awesome
      04-12-2019, 08:35 AM   #204
n00bkiller944
Been on vacation.
After looking at your pictures I was thinking it might be easier to buy one. Then I saw the $1,158 dollar price tag from FCPeuro... Cleaning sounds better
      04-16-2019, 08:11 AM   #205
beanbaguk
beanbaguk's Avatar
Spain
455
Drives: BMW G30 520d M-Sport
Blimey! I made 123k miles on my F31 320d before I sold it.
Full service history and other than new front wheel bearings and rear subframe bushes, the car was as good as new.
I'm now down to 14k on my new G30. I'm hoping to get at least 150k on it when it's finally sold in about four years or so.
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport
      05-25-2019, 07:44 PM   #206
wicked510
Drives: 328d xDrive
Add Rear AND front Differential Seal Failure & Front Tension Arm Bushing Failures @ 172,000
It almost makes sense just to replace the front wheel bearings (which I will do) on the xdrive setup since you need to remove the collar bolt to get the tension arm out anyway.
Guibo (universal disc/flex disc) is showing signs of wear.
So there you have it. My verdict is... If you are not a DIYer get out of the car before 150,000 miles.
      05-28-2019, 07:10 AM   #207
Jram328d
Drives: BMW 328d xdrive
Any 328d's pushing close to or over 200k miles? I'm at 120k and thinking of getting rid of her based on the major repairs that could be looming as I get into the higher 100's.
      05-28-2019, 07:30 AM   #208
Troy27
Drives: Bmw f30
That's a diesel engine...the car will fall apart before the engine fails!
      05-28-2019, 12:16 PM   #209
Uber Commuter
Uber Commuter's Avatar
722
Drives: 2014 328D xDrive
Had a check engine light; code through Carly says it's the EGR Cooler valve so recall part. Also have a worsening coolant leak that isn't leaving any fluids behind (nothing on the ground) so either the head gasket is failing or the EGR Cooler is failing and leaking coolant into the exhaust stream...
It's at BMW right now, 110,XXX miles on it, getting diagnosed. Once they tell me the failures and whether the recall covers the work; I'll probably be DIY'ing what remains.
      05-29-2019, 02:33 PM   #210
wicked510
Drives: 328d xDrive
I think you are right. I plan on fixing it until the engine or transmission go. It's a little more than I bargained for here in the high mileage TBH
I posted a few photos so you all can see. Transmission pan leaked onto the drive shaft which spun fluid onto the heat/sound shield in the tunnel. Shield swelled up and rubs on tunnel now... There are two holes in the frame where I may be able to form some sort of bracket to hold the shield back.
When I replace the pan and fluid again (since it's just about time anyway) I am going with amsoil. I will report back if it fries the transmission
      05-29-2019, 03:15 PM   #211
n00bkiller944
What happened to the trans seal? How old is the seal?
      05-30-2019, 12:01 AM   #212
wicked510
Drives: 328d xDrive
Hmm about 50,000 miles zf oem torqued to spec
      05-31-2019, 07:52 AM   #213
Uber Commuter
722
All the issues, CEL and coolant leak are related to the recall so covered by BMW. Getting a new EGR cooler, manifold, and valve out of the deal. So I had them check the suspension while I have the car in the shop; hit a really nasty pothole a few weeks ago and the car seems to be off ever since...
Turns out I pushed the strut 2+ inches through the lower mount, tearing up the CV boot and knuckle, and causing the tire to rub on the spring perch. The tire is worn through on the inner edge of the tread to steel belts...
All the issues I've been feeling/hearing are way worse than I thought, to the tune of about $5600 in parts and labor...
      05-31-2019, 03:40 PM   #214
wicked510
Drives: 328d xDrive
How big was the pothole? Did it stop the car? I hit a pothole about 18" deep and 12" wide no major damage. You can file a collision claim for that if you need to. Depends on how much the car is worth and if you can DIY or not.
      05-31-2019, 04:52 PM   #215
Enabled
I've encountered a bent strut, tie rod, and lower arm in front, and some bent arm/s on rear due to "road obstacles". I stopped driving on immediately, because the steering was so off.
New arms, struts, and tie rods are fairly priced, and you can either do the work yourself or a trusted indy for cheaper. Check the rear too, because the arms are made to give before chassis damage happens.
After all that alignment came into perfect spec, without fudging or maxing out adjustments.
I did it all myself with lots of care, for what it's worth.
Others:
      06-03-2019, 08:11 AM   #216
Uber Commuter
722
Sorry; I should have specified that's the BMW price and it's being covered under warranty. I'm reasonably competent at DIY work but I just don't have the time or a back-up car to drive while fixing this; so into the shop and in a rental while it gets repaired.
The pothole wasn't all that large, but I think the angle of the lip as I exited it was just right to screw everything up. Add in 100k plus miles and some parts that were probably ready for replacement anyway and it just collapsed...
      06-06-2019, 12:51 PM   #217
wicked510
Drives: 328d xDrive
Since everyone is always asking for pictures! Here is a transmission pan and mechatronics from 120k miles to 170k miles. Definitely a lot less metal in the pan but the fluid looks a little burnt and the filter definitely caught some stuff black bits and tiny metal flecks like the first change at 120k.
FaRKle!4016.00
jeffc83725.00
      06-08-2019, 01:35 PM   #218
n00bkiller944
Thanks for the pictures. Bushings look a little toasted. Is that 170k on them? Are those the lower control arms (or thrust arms or whatever bmw calls them?)
      06-12-2019, 02:18 PM   #219
Brekalo
Drives: F31 320d 2014
I have 320d 2014 with 165,000 km,and it's still running smooth.
Didnt have any repairs, just regular oil and filter service.
I'm thinking of changing transmission oil, but maybe its bit to late now with 165,000 km
      06-12-2019, 04:30 PM   #220
rbreding
Drives: 328d, 335d, x5d
Change it. But at this mileage I would highly suggest dropping the mechatronic also and getting all those tube seals and bridge seal replaced also. When dropping the mecha 90%+ of the fluid will drain.
