BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > 0-100 times dropped dramatically 275 tyres
Studio RSR
      10-24-2020, 02:28 PM   #1
trescuarenta
Drives: BMW 340i xDrive
Hey guys,
I recently changed wheels and tyres on my 340i xDrive. I had 225/255 before. Now i changed to 235/275 tyres, and my 0-100 times dropped from 3,4 average to 3,8 average. My 100-200 time also dropped by about 0,3 secs. No issues or juddering or anything, could my transfer case be limiting power without giving me any notice? Before the car takes off when launching it looks like it waits a bit and then goes..
2020 M340i xDrive Mineral White Metallic
RIP: 9 second 1/4 BMW 340i xDrive Melbourne Red | Instagram: daddy.340
      10-24-2020, 03:00 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The wider the tire the more rolling resistance it has. That would account in part for the loss of acceleration. If the wider tires are heavier that would explain part of it as well. The higher friction between the tire and roadway with wider tires is only beneficial in turns.
      10-24-2020, 04:17 PM   #3
visionaut
visionaut's Avatar
Drives: 2016 435iX GC & 1976 2002
Like Bill says for tire width/weight, but it’d have to be pretty significant to account for .4 secs 0-100. You’re less than an inch wider.
Are you working from GPS or your speedo for your timing? If you changed your tire diameter your speedo might be off, no?
So maybe a combo of the two effects (width + speedo error).
Also, I hope your new tires have ~equal diameters, since you’re XDrive. If the car senses they’re not, maybe it’s possible that could cause some traction fault/delay (?)
      10-24-2020, 09:08 PM   #4
340iGUY
Drives: 340i manual
235-275 may make oversteer worse.
      10-24-2020, 09:45 PM   #5
Billfitz
Billfitz's Avatar
I can't think of any improvement that 235-275 would give, especially with xDrive.
Skyhigh1879.00
      10-27-2020, 03:12 AM   #6
trescuarenta
Im using dragy to measure times, previously i was spinning my entire first gear. I also have new wheels which are 1kg lighter each corner, so its not an increase in weight.. Hopefully with the 265 rears things will be back to normal..
      10-27-2020, 07:19 AM   #7
Billfitz
Billfitz's Avatar
You shouldn't get spinning with xDrive.
      10-27-2020, 10:59 AM   #8
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
You probably have other problems if you're spinning through 1st. I run 255 square and have a little spin on initial launch but not enough definitely not through the whole gear. How much power are you putting down?
      10-29-2020, 07:29 AM   #9
trescuarenta
Car is making 540 hp at the crank, it was good for 3,1-3,2 0-60 mph times.
      10-29-2020, 12:59 PM   #10
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
you should be able to get traction with x-drive at that power level. maybe some stickier rubber is in order. You can also adjust the launch control to not put so much power down in 1st in order to get more traction.
      11-07-2020, 09:25 AM   #11
trescuarenta
Now with 265 tyres the car is flying again. Even broke my pr and 0-60 in 3.0x
      11-08-2020, 11:05 AM   #12
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
265 square or just in the rear? Glad to hear your traction is solved though.
      03-03-2021, 07:04 PM   #13
Wires
Drives: 2016 340i xDrive
Most likely it's the rotational mass from heavier rubber. Lighter tires allows the axles to spin up faster (less flywheel effect)
