View Poll Results: Who's right on the tire pressure? | |||
BMW | 6 | 75.00% | |
Continental | 2 | 25.00% | |
Voters: 8. You may not vote on this poll |
11-29-2021, 11:49 AM | #24 |
Rep 15,858
BMW vs. Continental.
Also remember BMW will have recommendations based on the specification of that particular model and options. I've noted that not all door plate pressure stickers are equal, even for a given model in the range. I always start with BMW recommended pressures, and work from there. Typically end up running a couple of extra psi, than the 'normal use' recommendation. This gives me the best balance for performance criteria and even wear rates. BTW, the Continental figures do look high to me. Looks like a set of ECO pressure recommendations. |
11-29-2021, 01:20 PM | #25 |
Rep 16,081
Maybe, but that being the case the BMW recommendations aren't CAFE based, and a couple of extra pounds of air works just as well in that regard as changing their oil recommendation from 5W-30 to 0W-20. That's what leads me to think it's more ride comfort oriented. While on the subject, those who don't think the LL branding isn't about the money haven't been paying attention. BMW changed suppliers again, this time back to Castrol.
https://www.castrol.com/en_us/united...-supplier.html |
11-29-2021, 06:21 PM | #26 |
Rep 1,425
My understanding is that M+S generally applies to all-season (which is noted on the OP's vehicle). On the other hand, a snowflake or "Three Peak Mountain Snowflake" applies to a true snow tire (noted on Continental's site, but not specifically on the vehicle).
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
11-29-2021, 09:11 PM | #27 |
Rep 16,081
3PMSF indicates the tire meets required performance criteria to be considered severe snow service-rated. Some all season tires have this rating. I just got Michelin CrossClimate 2 because they do, and they're a top performer in wet and dry conditions as well.
11-30-2021, 01:46 AM | #28 | |
Rep 3,873
Generally the consensus is that there are only a few reasons to drive all-season tires all year long as they are compromised at both ends of the environmental conditions range. - Climate which barely includes temperatures below +7 degrees Celsius and above +25C (and clearly no skiing as hobby ) - Laziness / Negligence - No need/desire for performance driving Some claim it is cheaper this way but that's not really true. You still drive the same kilometres per year, but instead of distributing them on 2 sets of tires (made for the corresponding conditions) - you put them down on a single set, which will need to be replaced twice as sooner. I just bought new winter tires for my Audi. The previous set I purchased back in 2013… When I was a child, all-season-tires were the default. Many didn't even know there is such thing as Summer and Winter tires or considered it an overkill. People know better now and it is extremely rare that someone even mentions all-season…., even more still drive them. In Europe that is. Not to mention proper winter tires are a requirement in many countries for the winter season. There is no such thing as a universal screw-driver.
11-30-2021, 04:32 PM | #29 |
Rep 413
Continental Wintercontact TS830P have both the 3 Peak Snow Flake as well as M+S on them. Didn't feel like going outside to take a pic of mine, so here's one I found of a TS830P:
11-30-2021, 04:49 PM | #30 |
Rep 1,425
I agree with your thoughts on All-Season. I suppose there are some drivers who have mild winters and are non-performance oriented where they are acceptable. I subscribe to seperate Summer/Winter tires for my personal climate: Michelin PS4S Summer , Michelin Pilot Alpin PA4 Winter.
Thanks for sharing. What I was suggesting is that the pressures listed on Continental's website are for a 3PMSF tire, and therefore perhaps higher as a result. On the other hand, the listing on your vehicle is the same tire dimension, but for M+S (and not necessarily 3PMSF). Thus, the pressure is lower. Again, this is just a thought.
2017 X5M - Current
11-30-2021, 05:10 PM | #31 | |
Rep 413
I also thought of the possibility that Continental's chart may assume a tire workshop temperature of, let's say 20° Celsius (room temperature), whereas BMW's door frame sticker may assume a wintertime outside temperature of around 0° Celsius. Tires pressure decreases with lower temperatures, so it makes sense that you should "over-inflate" winter tires at room temperature to have "normal" pressure under typical winter driving circumstances. |
Onizukachan1086.00 |
12-02-2021, 10:54 PM | #32 |
Rep 1,386
Those Conti pressures are stupid high. Must have been recommended by the brain donor at my local dealership who always sets my tires to 41 PSI all round. It's 32F 36R on the door placard.
12-03-2021, 12:47 AM | #33 | ||
Rep 3,873
It can be checked easily in the tire pressure and temperature monitor, but I reckon they get to around +5 degrees after some driving even when the outside temp is say -5. The result of friction + heat from breaks, etc.
12-03-2021, 04:44 AM | #34 | |
Rep 413
General consensus is that one should add 0.3 bar to the pressure when inflating tires on a car that has been driven for >5 km or >15km. |
12-03-2021, 05:51 AM | #35 | |
Rep 15,858
BMW recommendation will definitely be cold tyre temperature settings. Summer or winter tyres. |
12-03-2021, 09:52 AM | #36 | |
Rep 413
This could be the case for Conti chart as tire fitters will ususally mount tires in a heated workshop at around 20C/68F. For BMW door sticker, it does not make sense to give 20 degree Celsius pressure for winter tires, because who has winter tires on their cars at 20 degrees? Makes much more sense to indicate cold temperature at typical usage circumstances (inflating outside at a gas station), which will be closer to 0C/32F. Anyway, this is getting very speculative, and unless someone from BMW or Conti would get involved in the discussion, it will remain a guessing game... |
12-03-2021, 10:03 AM | #37 | |
Rep 15,858
