04-02-2020, 10:03 PM | #1 |
Rep 7,555
Help - Concerning Noise from Rear Seat / Center Consol Area
2015 335i RWD 8AT Msport. Fabspeed catted DP, VRSF IC+CP. Stock suspension, wheels, etc. MHD Stage 2+ 91 tune.
So, i started hearing a noise the other day. Conincidentally (may be a coincidence or not), it seemed to start shortly after i added 2 gallons of E85 and the rest 91 to a tank of gas. This is my first timing mixing in ethanol on this car. I would best describe the sound as somewhat like grinding, but also like when a pump is sucking air. Some notes about the sound: - It is definitely load/boost dependent. It is loudest when WOT, in any gear, and in boost. - It is not really RPM dependent. I can accelerate up to 6k rpm at low throttle and the noise does not occur. - Also not speed or gear dependent. It can occur if i floor it in any gear, whether its 1st gear at 5000 rpm or 5th gear and 2500 rpm. - Started when i had a full tank of gas, still at half a tank and it sounds the same or maybe worse (could just be that i am more focused on it now). So i dont think its the fuel pump getting air. It does sound like its around where the LPFP would be... and it did seem to start right after adding the E85, but it was only 2 gallons... I captured a log right when the noise started happening (i was checking for HPFP dips also), but of course i cant get any info on LPFP from that. https://datazap.me/u/thejeremyman9/4...ta=4-5-6-25-27 Interestingly my STFT are quite negative in most of that log, despite the ethanol on a non E tune. Anyways, looking for any input on what it could be. Does it sound like LPFP? I am still under CPO warranty for a little longer thankfully, and i was already planning to take the car in for some other stuff this month, so i am going to just go in for an oil change and brake fluid flush and have BMW check it out. I am not 100% sure if it will do it on stock tune, but i am going to completely uninstall MHD before taking it in anyways and will test that. I really hope it does so that it's repeatable for the dealer. Here's a video, the sound actually sounds even louder here than in the car i think: You can hear the noise a little when i first take off at medium throttle, it goes away when i let off, then get really loud when i step on it. This was 2nd gear i believe, but the gear doesnt make a difference. |
04-03-2020, 08:58 AM | #2 |
Rep 63
Get under your car and check this first. The clip retainer that holds the ebrake tube was hitting the driveshaft due to a broken part of this clip on mine. This happened to me when is was WOT or close to it and with with people in the back seat. some fatties loading me down, lol.
Here is that clip, https://www.ecstuning.com/b-genuine-...r/34406854898/ Its a pain in the ass to get to if you cant properly get under your car but easy to see from the back if you follow the drive shaft an it's right above the heat shield I believe. Let me know what you find, Ill see if I can get a good pic for you. |
04-03-2020, 09:30 AM | #3 | |
Rep 5,776
04-03-2020, 09:49 AM | #4 | |
Rep 1,105
Check the ebrake tube because I has the same noise after installing the M-LSD but have heard that after time the tab on the ebrake cable breaks. |
04-03-2020, 10:07 AM | #6 | |
Rep 7,555
Thanks both; I will try to get under the car today and see what i can find. Maybe the E85 was just a coincidence (kindof hoping and i want to be able to run it). My car only has 44k miles on it. Maybe the load is making the car squat and this contacts the driveshaft. Will report back. |
Rebound152.50 |
04-03-2020, 11:18 AM | #7 | |
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
04-03-2020, 11:54 AM | #8 | ||
Rep 7,555
I think you guys win the prize. I wasn't able to full get under the car to check things with it on the ground but i captured a few pictures. It looks like there is a mark in the exact same location as the one 14F30Daily posted. Attachments are below. |
04-03-2020, 01:51 PM | #9 |
Rep 63
Hell yea man. That was my first post in this forum so glad I wasnt steering you in the wrong direction. Let me know how the fix goes but I believe you're going to need to drop the mid pipe, not fully remove it, and remove the heat shield, I dont think the drive shaft is mandatory. I have yet to fix mine properly cause Im not paying $700 for that $10 piece, I really just set a temp tie on the right ebrake tube until I can this done, gotta love BMW and their hidden plastic pieces...
There should be some posts in the past talking about how to fix this part specifically. Good luck. |
04-03-2020, 05:33 PM | #10 | |
Rep 7,555
I took a closer look at my photos and i think i actually see the broken clip now; the first time i just saw the mark on the driveshaft. So i am pretty confident this is what it is. |
Rebound152.50 |
04-06-2020, 09:48 PM | #11 |
Rep 7,555
So, to wrap this up, it was exactly what we thought it was. I took the car to the dealer and dropped it off on saturday for my oil chane, brake fluid flush, and this issue. I had to pay a $50 deductable for the CPO warranty claim but they covered it. The price quoted for the repair had it not been covered was over $900.
Annoyingly, they had to drop the gas tank to do it... not sure why as that didnt seem like the easiest approach. I just hope that did that correctly and i dont have any future issues with the tank, filler, rattles, etc. They also drained my gas as a part of that but i think they refilled with the same fuel? Not sure though so i am going to run this tank down as empty as i can before i mix some ethanol in my next tank. I havent looked under the car yet since it was raining but next time i do ill try and grab some photos and post if anything is noteworthy. |
04-07-2020, 07:28 AM | #12 |
Rep 63
Good to hear, I'm out of CPO so this is going to be me doing it. Like how are they able to quote 900, seems I estimated even low. 890 in labor, comeon man. Dropping the gas tank to get there would seem like a complete waste of time but maybe makes the part install as easy as possible...
07-13-2020, 08:24 PM | #14 |
Rep 7,555
Just reach under there a put a zip tie on it. The dealer dropped my tank as part of the warranty replacement and now i have the slow fuel fill issue described in this thread: https://f30.bimmerpost.com/forums/sh....php?t=1736419
09-14-2021, 12:39 PM | #15 |
Rep 18
Drives: ‘16 328i wgn, M Roadster
So I have the same sound in my ‘16F31 except it happens under load and when turning right only. I’m fine with a zip tie fix, do I need to drop any pans or splash guards to access this spot? Is it easier to get by jacking up the front or back?
09-14-2021, 01:26 PM | #16 |
Rep 7,555
Depends how small your hands are... you should be able to get to it without removing anything and you may just be able to crawl under the car. Just go look under your car while its park and confirm as shown in my photo above.
10-16-2021, 12:52 PM | #17 |
Rep 18
Just to close the loop here. This was exactly the problem in my 2016 F31. The bracket wasn’t holding the two ebrake housing tubes and on turns those tubes would rub on the drive shaft. I managed to thread a zip tie behind the bracket and the two tubes and it seems to have worked. To replace the bracket you’d need to drop the exhaust and/or the drive shaft which sounds like a big PITA. I’ll try and post a pic when I’m at my computer next
10-16-2021, 01:29 PM | #18 |
Rep 44
I have the same grinding noise when accelerating and turning right. Haven’t looked underneath the car yet, but seems likely that I have the same issue.
10-17-2021, 01:11 PM | #19 | |
Rep 7,555
10-17-2021, 05:25 PM | #20 |
Rep 18
OK. So here are two photos that hopefully help. I took the car for a longer drive today and can confirm this solved my noise problem. First photo you can clearly see where the ebrake tube is rubbing on the drive shaft and even the broken clip. In the second, you can (hopefully) see how I ran a zip-tie behind the broken clip and around the two ebrake tubes to hold them up and off the drive shaft. Took some work as the space is tight but my car is out of warranty and if this works I'll take a 1 hour (took me longer to put the car on and off the jack stands) work and $0.05 zip tie solution than another BMW clip that will probably just break anyway and the hours to drop all that stuff. As a tip, I did remove a few nuts holding the heat shielding in place to make it easier it access - just a 10mm socket there.
