09-04-2023, 06:34 PM | #23 | ||
Rep 2,048
The old P-Zero Rosso Corsa's were pretty decent for their time but yes, the P6/7 etc ranges were awful, and the P-Zero Nero was garbage in the wet (albeit entertaining if you had space to do some provocation). Even with the stock 230bhp my Impreza originally came with I could light all four tyres up with ease off a roundabout with very little effort. Fun when you wanted it but not so much when you were just trying to make progress on slick roads! The newer PZ4 I will caveat and say are both run flat and star marked in my example, but they just seem vague. I've had numerous occasions where in tight 2nd gear corners the back end has properly stepped out under power, something the Michelins and even the winters have never done, and they feel quite glidey on greasy roads. It's a strange sensation but they do eventually hook, it's just that they only do so about 3m further on than you really wanted them to. Again, on wide sweeping A roads this isn't the end of the world but on tighter/narrower/badly cambered stuff where there's less real estate on the tarmac to play with it's a problem and limits how hard you're willing to push. I've done a good few thousand miles on them now and they're still the same, and tyre pressures do little to change this trait, from 2.4 up to 2.9 (hot). I'm pretty sure the last time I had a tyre do this it was a Pirelli too! They also feel decidedly front limited compared to the Michelin. Whether this is because of the sidewall construction, BMW spec compound (if any) or because the front tyre is relatively smaller than a normal 225/40 to match the 255/35 rear I don't know, but it definitely wants to push on a bit more. I now find myself sometimes a gear down for certain corners just to initiate a more aggressive load transfer to get the car moving in the way I want it to. I mean I can continue doing that, but it just feels a bit unnecessary when all you want to do is make progress to get somewhere! On the Impreza I've got Eagle F1 Asym 5's as since dropping back down to 17's to deal with the utter shite quality of the roads up here I can't use a lot of the real UHP tyres. And after getting fed up of going through 888R's every 1500 miles I decided to ditch the ultra soft track day style tyres too. That and I got fed up of getting my arms crossed at high speeds on wet roads. I mean it's Scotland; even on the hottest day of the year you will still somehow find standing water about! I'd have preferred the PS4S but they only go down to 18", and the PS4 seems below the Asym 5, or at least did at the time. I did run Yoko V105's on the old Prodrive PFF7's and they were actually a decent tyre, albeit lacking peak grip, and definitely not dealing well with damp and cold roads. They had stiff sidewalls which made for a sharp turn in but made them fidgety on rougher tarmac, and had rubber which needed warmed up. But as a fun tyre they were actually pretty decent. The downside is that like most Japanese performance tyres, tread life was almost comical. In fact I've never once gelled with a Japanese tyre, other than the 888R, and even then that was far from the best trackway tyre, just a cheap option that was easily available and was reasonably good. They all, to me, just seem a bit one trick. Which is fine if that trick works for you, but I prefer a more all round option given I use my car in most weathers and don't exactly want to hold back just because it's raining/damp/cold etc etc. It's interesting hearing your feedback on the CS7's as I definitely found previous versions vague. My (partially hypothetical) question is whether that translates to being quite such a good all rounder as the PS4S, and whether tread life can match that benchmark while accessing the performance. A good all rounder it seems is a rare beast, and is rarely all about maximum peak grip. And yes, very true about all online views/reviews being subjective to the individual's ability/preference, and the situations they're using the tyres in. Quote:
09-05-2023, 05:10 AM | #24 |
Rep 1,993
Drives: F30 335d
I managed to get 43,000 miles out of the rears of my Eagle F1 AS5s. Although they were down to the wear marker! The fronts lasted about 32,000 miles before needing to be replaced. All tyres were fitted at the same time 3 years ago.
if I've helped - an Appreciate would be, er, very appreciated!
Leeg1633138.00 |
09-05-2023, 05:35 AM | #25 |
Rep 175
Some really good and interesting reviews / responses on here. Thanks. I'll stick with my plan of getting non rft PS4s, prob sometime in October. Any suggestions of best ( cheapest ) places to source these, 18 inch staggered?
Will also get the tracking done. Didn't mention earlier that it's had eibach springs and 15mm rear / 12mm front spacers fitted ( f31 330d xdrive ). Is it best to go with standard set up on tracking or is anyone aware of improved settings. Most of the time it's normal driving but I do like sneaking out at 5am on a Sunday morning for a good b road blast. This may be what has aided the lower than expected life of these tyres. |
09-06-2023, 06:29 AM | #26 | |
Rep 3,068
For tyres Costco do some good deals on PS4s at times if you know someone who is a member. |
Leeg1633138.00 |
09-06-2023, 03:37 PM | #27 | |
Rep 525
if you reckon you'd be chewing through front tyres after 6k miles then either michelins are considerably softer than the goodyears (which again you've not accounted for in your strawman rambling response), or you're possibly understeering around everywhere. watch out for the oncoming tractors though. to be even remotely near testing the grip levels of these sorts of cars and tyres you would have to be doing easily 40-70+ around most corners on most B roads, so if you're saying that's what youre doing then youre an unsafe driver and shouldn't be on the road, period. I hate losing speed and so i'll stick it on cruise at 65 on a typical A or B road where its national speed limit and usually try and carry speed around to not lose momentum or have to accelerate again. The tyres definitely aren't squealing and i'm no where near the cars limit but i would say i'm still cornering harder/quicker than your average road user. and as someone who has a radical sr3 for a track toy and laps donington GP in sub 1.30, i have a pretty fair idea of what driving quickly is all about. Also i clearly say in my post "That's probably 70/30 motorway/urban and when it comes to roundabouts i don't hang about." clearly implying that most of the mileage i covered was straight line motorway which is probably pretty typical for the average road user. If you're living in godknowswhere negotiating bendy roads all the time then yes, i'm sure you will use tyres at a quicker rate than an average person. you've successfully made no points in your essay. Last edited by gippy; 09-06-2023 at 03:45 PM.. |
09-06-2023, 05:19 PM | #28 | |
Rep 385
Swap fronts with rears when rears are about 4-5mm for simultaneous replace. Since this thread now has a driving style variable, I'd like to add that I do take advantage of serpentine roads sometimes. |
09-06-2023, 05:44 PM | #29 |
Rep 1,993
Drives: F30 335d
I can't swap fronts with rears as I'm on a staggered setup.
I replaced the worn out rears with AS6s, easier to find than AS5s, very good tyre, comfy and quiet! So I'm running As5 at the front and as6 at the rear, might make the transfer case warriors sweat a bit! |
Allworth204.00 |
09-08-2023, 05:48 PM | #30 | |
Rep 2,048
So I maintain that stating you get 20k+ while driving 'hard' (your word not mine), when you don't go fast around corners on A/B roads (40-60mph isn't fast), and doing most of your mileage on urban roads and motorways, doesn't make you an actual fast or hard driver away from a track, regardless of what time you're capable of sticking a track car around a circuit in. And nor does me potentially driving faster than you on roads with little traffic and good sight lines make me dangerous. Give over. |
09-09-2023, 04:53 AM | #31 | |
Rep 1,013
I think for me the F1 SuperSport has been the best tyre overall, pretty darn close to the PS4S but has the edge in cornering grip and stability, but again, it's all subjective It's just not great in the cold, but where I live doesn't justify snow tyres, I drive accordingly. RE: the CS7s, Contis have always erred on the softer side vs their competitors, and I went for them knowing that but coming from rock hard 7 year old P Zeros RFs, they are an absolute god send in terms of comfort, noise and they massively better grip in all conditions. The trade off is a loss of steering precision off centre because they are non RF, but again, a trade off I'm happy with It's a tyre you can sling into any situation and not worry about under or over steer, which is important to me on a heavy RWD car. Consistency and predictability are the name of the game. On a side note, Contis are light tyres. They were a good 4KG lighter than the P zero RFs and over a KG lighter than the equivalent size PS4S non RF |
Ennoch2257.00 |
02-10-2024, 06:18 AM | #32 |
Rep 175
Quick update. Got the tracking done and a full set of star marked PS4's back in September. Tyres first, then tracking. And I've got to say these PS4's are the best tyre I've ever had. Comfortable, quiet and the grip... wow! Used in rain, -6 and wet roads and its never put a foot wrong. The confidence I have in them, you can throw the car around and it just grips and goes. Cars running approx 310bhp and 600nm, now I now thats not the most powerful but with the old Contis it would easily spin up the wheels on a hard launch, not on these, not even in the wet. Would highly recommend to anyone in the market for new tyres. I got the full set on 18inch staggered for 680 at costco.
Alscoob2120.50 |
