11-21-2023, 12:26 PM | #1 |
Old Fart
361
Rep 694
XHP black Friday discount
I just spotted XHP have done 15% for black Friday.
I've been checking daily for a few weeks to make sure they didn't put the price up before putting on a fake discount, like Currys for instance, and it's been hovering around £288. It's now £244 so the discount is genuine 👍
The doctors said it's OK to listen to the voices..... just don't do what they tell me
11-26-2023, 04:52 PM | #5 |
Rep 79
11-27-2023, 02:19 AM | #6 | |
Rep 428
I also find the shifting speed in general to be much faster (or at least it feels it) and the engagement of other gears can be felt a lot more which I felt was missing with the standard box. I understand some people might like the gearbox to be buttery smooth like it is at standard but I like to know I've changed gear with some mechanical feedback.. maybe that's because I've owned DSG cars prior. Finally the throttle blips on downshift and torque reduction on upshifts really means you can get it sounding/performing just how you like personally. If you aren't keen on the settings you can adjust them in less then 60 seconds and for me this is the best feature of buying your own license. It's so adjustable I think everyone can find some settings they like and it will likely be different to the next persons. Seems to be pretty bulletproof in terms of reliability too which is a great thing but guess remains to be seen for me personally. Mine is also paired with MHD stage 1 tune. |
12-01-2023, 05:50 AM | #9 |
1894
Rep 2,088
This is defoo something I'll be doing come the New Year once I've got he box serviced
Is it literally plug n play; or is it best to find someone who has it to map my ZF8 etc?
12-01-2023, 05:56 AM | #10 | |
Rep 79
It's easy. Follow their instructions, and it's not a problem. I've started to make a quick video about it, which I'll hopefully stick on the youtubes next week… (not like you need it, it's that easy ) |
danb19791894.00 |
12-01-2023, 06:39 AM | #11 | |
1894
Rep 2,088
Cheers for that I'm fairly tech savvy when it comes to my Macs, hifi and stuff like that but with cars I tend to be more at home with my 12lb sledgehammer
moppity94.50 |
12-01-2023, 06:59 AM | #12 | |
Rep 8,500
Start off by selecting the Stage map that you want (I've tried them all, and have stuck with Stage 3). Once the 50 miles bedding-in process has been done you can re-flash at any time in literally a couple of minutes. There are multiple parameters that you can tweak, i.e. I set the max rpm for my 30d according to the Drive mode => 4000 for Comfort; 4300 for Sport; 4600 for Manual. You can also set toque limits per gear, and a host of other things. The XHP website is the place to go and have a read - there's too much to set out here.
12-01-2023, 08:17 AM | #14 | |
Rep 428
Advantage of buying the license and map pack yourself is you can adjust it as much as you like or add new features as they become available within a few minutes. Great mod. |
12-08-2023, 08:46 AM | #16 |
Rep 1,013
I don't mind paying full price if it sorts out 2 annoying things in comfort mode:
1) Hanging onto 2000rpm, or higher, for no reason when driving gently between 2nd and 3rd. Typical scenario.....see a gap at a junction or roundabout and give it medium pedal, then back off whilst straightening up. The revs rise WAY too much for the load and road speed. 2) Hunting between 2nd, 3rd and 4th. Typical scenario..... the grounds where I work has a very strict 20mph limit. Sometimes I get stuck behind someone doing 18mph, then they'll accelerate to 21mph then drop to 17mph The car feels like it wants to maintain 22mph in 4th, but due to people not maintaining a constant speed, it keeps hunting between 3rd and 4th, sometimes 2nd and it's frickin irritating. Same in slow moving traffic. Both are the firstest of all the first world problems out there, and both easily fixed by switching to manual mode. Sport mode is too thrashy when you just want to cruise along at 1100rpm quietly and smoothly. But for scenario 1, another first world problem presents itself. Steering wheel mounted paddles instead of column mounted - where they should be! Easily fixed by using the console lever instead I guess. Hmmmm, looks like I've successfully talked myself out of spending £290 by just using features that already exist But it would be nice to just get in and comfort mode behaves comfortably. |
danb19791894.00 |
12-08-2023, 08:59 AM | #17 | |
Rep 79
Please hold caller… Oh, caveat emptor, mine's a petrol. This could change things massively * might be next week before I use the car again |
danb19791894.00 |
12-08-2023, 09:03 AM | #18 |
1894
Rep 2,088
I've got my F31 in with Automatic Transmissions late Jan for a full box service and fluid change etc; so I'll do the XHP remap after that I think
I don't like how the ZFu8 hangs onto gears at times; it's not as bad in Sport; but in every day driving and Comfort, it's a bit too slow I feel at times However; it's leagues ahead of the ZF5s I was used to in my E39s
12-08-2023, 12:42 PM | #20 | |
Rep 8,500
The ‘box in my car has always suffered from hunting between 2nd/3rd at specific rpm and light throttle. The full rebuild improved it a little but it’s still there. I can’t say that XHP has made it any better or worse.
12-11-2023, 03:38 AM | #21 | |
Rep 1,013
moppity94.50 |
12-11-2023, 03:41 AM | #22 | |
Rep 1,013
Yeah the reluctance to engage 8th happens to me everyday when I join the dual carriageway. When I hit 70mph, it hangs in 7th....but it seems to be proportional to gear oil temp. It's fine when hot. OK, sounds like it's just the nature of the beast then. Manual mode it is then |
