01-20-2024, 06:08 AM | #45 | |
Rep 1,013
The actual issue is in the Relaxed mode's pedal speed map. They have retuned it to ignore slow and/or gentle inputs. It is exactly what I want for daily meandering as it means the box won't downshift at the slightest whiff of an inclination, but they've tuned it poorly. The Relaxed map allows me to pull 7th from 950rpm. I know diesels are robust and torquey, but high load and ultra low rpm is extremely bad for pistons and rod bearings. Stock would over ride that request and downshift way before 950rpm. Yeah I saw your DSC issues in other threads when researching xHP. Not good really. As you say, diesels don't need to rev. That is the whole point of them. Anyway, I think I've got it to where I want it. 8th is still an issue, but I think that is more to do with the cold weather / warm up behaviour as stock is also sluggish to engage 8th during warm up. |
01-22-2024, 09:58 AM | #46 |
Rep 1,013
FWIW, I reset the gearbox adaptations yesterday with ISTA and went out for a 100 mile relearn drive. It's the best it's ever been, stock or xHP'd.
Apparently other brands of car that use the ZF 8HP always clear the adaptations after a fluid flush, but BMW don't mention it. It seems to work though, and makes sense to relearn after fresh oil and a filter as the clutch mbar readings will be different. |
02-06-2024, 03:14 AM | #48 |
Rep 1,013
Yeah Sport is even sportier than the standard Sport I don't know why, but my 30d feels waaaaay more responsive and punchy in Sport Manual with xHP than it did before. Not sure if you've found the same in your petrol? It's not just the rev band and shift points.....it's almost like it's bringing the boost in sooner.....or something.
I rarely use it though. Just for some fun blasts occasionally and getting past tractors swiftly. In other news, Stage 2 with the relaxed shift map has increased my mpg from 49 to 52 over the last 1300 or so miles since I flashed it. And to answer my own question - it can indeed be flashed back to stock, but it still leaves the gear number in D, so it's not quite 100% back to stock. |
moppity94.50 |
02-06-2024, 04:51 AM | #50 |
Rep 8,636
My mpg has dropped since going stage 3, I struggle to hit 40mpg on shorter varying speed journeys now where as before it was easy. But I think that could be down to 2 things, I’m “playing” a lot more to see how well it goes, and the weather/temps….
Will be having a longer run on Sunday so will be a fairer test on a mway journey. |
02-06-2024, 07:38 AM | #51 |
Rep 1,013
Yeah it's probably just the weather. Very strong head winds and cold temps can cause a slight mpg drop. The shift speed shouldn't really affect mpg, but shift points can
02-07-2024, 03:14 AM | #52 | |
Rep 811
If you do lots of stop/start, this will have an impact on MPG - by my cigarette-packet calculations, the car consumes about 6-8x more fuel at idle with the TC still engaged. I and other here have come to accept it and plop the car in neutral themselves. I personally have found a modest MPG gain with XHP, although its hard to prove. My shifts are configured lower and I've made them faster, which causes less TC slippage. |
02-07-2024, 05:29 AM | #53 | |
Rep 1,013
That bug, no DTC in comfort mode and pretty poor shift consistency from cold to hot (sporadic and unwanted very early down shifts, which unsettles the car like a clumsy manual gearbox shift) is making feel like this product is a bit over rated tbh. As you say, the support is pretty naff as well. It seems people gush over it but never mention the negatives, apart from a few people. I've been tempted to flash it back to stock permanently because it's more consistent and smoother, but I like the benefits of xHP too much. Hopefully it will improve over time, but the guy seems to be happy to offer custom tunes for 500 odd euros without fixing the OTS maps first EDIT: Just realised v1.8 relates to Stage 3 only. Stage 2 is only at v1.4, so it probably does still work on that. Last edited by TurboWeasel; 02-07-2024 at 07:00 AM.. |
02-07-2024, 07:28 AM | #54 |
Rep 8,636
I’m at Stage 3 v1.5 from 06/05/23 so shouldn’t be an issue at this version.
I put it down to cold weather/higher electrical use and the fact I’ve probably played more to see the differences rather than just drive. Got a 100+ mile round trip this weekend so really interested to see what it gets. |
02-07-2024, 07:28 AM | #55 | |
Rep 811
Easiest way to tell is shift to neutral while stationary - you can obviously feel significant load releasing from the drivetrain. |
02-07-2024, 08:43 AM | #56 | |
Rep 1,013
I did report the lack of DTC in comfort mode, and decoupling not working earlier, just to get the numbers up, and got these lame responses: "Most people want DTC in Sport mode" (so tough luck basically). "Decoupling is enabled in the settings." Gee, thanks for that |
02-07-2024, 09:04 AM | #57 | |
Rep 8,501
TurboWeasel793.50 |
02-08-2024, 09:46 AM | #58 | |
Rep 1,013
For those interested, more info about Torque Converter decoupling at idle on the 8HP70. I've compared stock to xHP Stage 2 (v1.4) today and the behaviour is the same. It looks like it doesn't work with the handbrake, only the foot brake, which is annoying.
Eddamoo391.00 |
02-10-2024, 05:08 AM | #60 |
Rep 1,013
That would be nice eh? Unfortunately for me, 50% of my daily grind is sitting in slow moving traffic or idling. Hence why I'm so hung up on the low rpm shift behaviour
Come to a stop, foot on brake, slide into N, foot off brake, handbrake up. Then foot on brake, handbrake off, slide into D, foot off brake..... drive 3 feet forwards, rinse and repeat. Baaaaah, it's such a bind doing that 50+ times every journey. Hence why I just use the handbrake in D I can understand locking the shifter to the brake pedal when it comes to reverse when moving, but locking out N and D is fapping annoying in heavy traffic! They could have applied a 10mph limit, but nope, you HAVE to be at a complete stop to switch between N, P & D. And don't get me started on locking out N to engine rotation. Want to roll the car forward a bit to work on it without starting the engine?....nope. DENIED. Got a mechanical problem and need N to roll the car off the road quickly? DENIED. It's the same dumb mentality with push (the clutch) to start on manual cars. Dry crank thrust bearings with all that clutch pedal pressure on them, great idea And there endeth my Saturday morning rant |
02-10-2024, 06:12 AM | #61 | |
Rep 8,501
If there’s enough of an incline for the car to roll forwards under gravity I can shift into D while the car is moving as long as there’s a slight touch on the brake pedal.
02-12-2024, 05:09 AM | #63 |
Rep 8,636
Run this weekend saw 44mpg there and 46mpg back home, another run to Reading this morning nudged just over 50mpg and settled to 48 by the end of the journey and it was a cold morning so looks like it’s fine and not really changed since xHP - when I’m not lead footing it for fun that is!
02-15-2024, 03:55 AM | #64 | |
Rep 1,013
02-15-2024, 07:45 AM | #65 | |
Rep 1,013
First go with Stage 3 today, just in comfort mode. I can't say I can notice much difference to stage 2 tbh I'm still getting some random and very jerky downshifts with Stage 2 and 3 though. It's always 20 minutes into a journey it starts, so I'm guessing that's when the oil is up to temp and the adaptations kick in. Seems to be OK again after 40-50 minutes. Not going to lie, I'm not impressed with the warm up mapping. It's sh1te compared to stock. I'm guessing it uses a closed loop PID like wideband air fuel ratio fuel control. Needs improvement imo. What am I talking about? Well, I'll be cruising along in 7th at 1500rpm, at 50ish mph, and it just drops to 6th for no reason, then back to 7th again. Sometimes it double shifts to 5th, then back to 7th again. It'll do it a few times in a 60 minute journey. Stock and Stage 1 don't do that. Stage 2 and 3 apparently have "optimised comfort mode for more driver orientated shifts". Looks like by that they mean changing down earlier, but it's naff. Adaptations are all miniscule now after xHP has been doing it's thing, so I don't think I have any mechanical issues with a 60K old box. I think we need a dedicated xHP troubleshooting and info thread? I feel like I'm the only one with issues |
02-15-2024, 08:45 AM | #66 | |
Rep 134
I like the urgency of shifting in Sport mapping, but dislike that gearchange jolt when in Comfort mode. So mine is Neutral with +10% upshifts and -8% downshifts (roughly). Sport mode = epic (when you don't want to cruise!)
'16 BMW 440i GC AT | '17 LCI BMW M240i AT | '94 Mazda MX5 | '04 BMW M3 E46 6MT | '07 Seat Lean FR 2.0 | '01 Seat Ibiza Sport 1.6 | '94 Nissan Sunny LX 1.4 |
