02-27-2024, 01:37 PM | #1 |
Rep 8
Rattling noise help, 320i 2018
I've been experiencing a rattling noise on start up and when coasting or deacclerating. Local indy thinks it may be timing chain related and suggested replacement. 320i 2018.
I'm not 100% convinced. Any help appreciated. Link to a video with sound below https://youtu.be/uiZk839acHU?si=DzqZ8tFmVXQeDgOS[/url][/QUOTE][/IMG] Last edited by Ianed8484; 02-27-2024 at 01:44 PM.. |
02-27-2024, 01:58 PM | #2 |
1893
Rep 2,088
Not the best video really... Can you get one with the engine running and you filming it with the bonnet open etc?
Do the rattles increase/decrease with revs etc? What oil/filter changes has it hand in your ownership and before? Always thought the N20 gave off more of a high pitch whine when the chains having issues...
02-27-2024, 02:27 PM | #4 |
Rep 8
Car is currently in the garage, I'll get another video when I pick it up tomorrow.
Milage is 63000, serviced every year, there was an 18 month gap from 2022 to 2023. I bought the car June 2023 and it was serviced then Transmission seal replaced by indy. Cam shaft sensor replaced by bmw Been in for diagnostics and health check with bmw twice since ownership. They previously didn't pick up on timing chain issues |
02-27-2024, 02:29 PM | #6 | |
1893
Rep 2,088
My pals had a 328i in recently and it was a loud whine when being run; that was a fubar'd timing chain
02-28-2024, 03:02 AM | #7 | |
Rep 105
TBH that start up sounds just like mine and any other B48 3er I've heard. It's all Massey Ferguson for about 20 seconds and then quietens down. |
02-28-2024, 03:25 AM | #8 | |
1893
Rep 2,088
And yes; the B48s are noisy at times aren't they...
02-28-2024, 04:22 AM | #9 | |
Rep 105
Who knew |
02-28-2024, 05:50 AM | #10 | |
1893
Rep 2,088
One of the lads that has quite a few niche cars that my pals look after has an E60 M5; that's deffo a tractor on start up haha Even with the Supersprint exhaust; it sounds a bag of spanners on cold start!
Ianed84841.50 |
02-28-2024, 06:11 AM | #11 |
Rep 105
All that wastegate-opening trickery to warm up the Cats doesn't help
02-28-2024, 11:26 AM | #13 |
Rep 8
Indy has quoted 2.3k to replace timing chain, they have said I could try an oil flush and see if that helps. Would this make any difference??
I get the car back tomorrow so I'll post another video with the bonnet up. A friend has suggested getting a 2nd diagnostic. |
02-28-2024, 12:08 PM | #14 | |
1893
Rep 2,088
Deffo get a 2nd opinion ASAP
Ianed84841.50 |
02-28-2024, 12:18 PM | #15 |
Rep 8
They said "it made an awful rattle on start up which sounded like it was coming from the timing chain"
They were concerned over service history as on bmw database it hadn't been serviced for 24k but as previously mentioned receipts would indicate there was an 18 month gap between service. It could just be it wasn't recorded on the database. The rattling sound I originally took the car in for on diagnostic seemed to go away the more I accelerated, surely if it was timing chain the sound would get worse? I think a second opinion is definitely the right thing to do. The indy I have used is usually pretty good but I'm not 100% convinced on this occasion |
danb19791892.50 |
02-28-2024, 12:49 PM | #16 |
Rep 1,706
If you have an intermittent 'rattle' which is largely rev related, I would have a good look for something being physically slightly loose in the engine bay TBH before replacing an expensive cam chain. 63k miles is very low for an N20, let alone a B48.
I had my daughter's Mini booked in for a cam chain replacement because of the dreadful noise it was making. Turned out to a damaged aux belt which was whacking against something on every revolution. Sounded much more serious than it was. |
Ianed84841.50 |
02-28-2024, 01:32 PM | #17 | |
Rep 8
