01-18-2020, 05:55 AM | #2179 | |
Rep 44
Edit: page 100 |
01-18-2020, 05:55 AM | #2180 | ||
Rep 399
If you have powered the unit on desk, how does it behave when you just cut the power? |
01-18-2020, 05:56 AM | #2181 | |
Rep 190
But i do not have comfort access and i am not sure if i can code it. |
01-18-2020, 05:57 AM | #2182 |
Rep 190
01-18-2020, 06:01 AM | #2183 | |
Rep 2,366
Drives: E63 645Ci
01-18-2020, 06:01 AM | #2184 |
Rep 190
https://mega.nz/#!kF5zDajb!bGe_vs0xn...krKaQ42JNU2Etg
This is how is the electrical system in my car. |
01-18-2020, 06:06 AM | #2185 | |
Rep 190
I understand . So why android is not booting up although CCC gives power and is active?\ Perhaps because CID is missing? Can we fake the system to believe that the CID is present so will light up and if lights up Android will boot up? I wonder what will happen if i connect both screens , without LVDS cable in the OEM screen but only in Android. |
01-18-2020, 06:11 AM | #2186 |
Rep 2,366
Drives: E63 645Ci
For the same reason that CID is not powering up as soon as you unlock your car. However your are right, once you press knob on your CCC / MAS-K a message to CID is sent to power up. Why this doesn't bring Android on, I don't know. I will have to check if I have the same behaviour as you.
01-18-2020, 06:24 AM | #2187 |
Rep 1,048
01-18-2020, 06:26 AM | #2188 |
Rep 2,366
Drives: E63 645Ci
Looks like I'll have a busy weekend. I need to check CID power behaviour with relation to CAS module, trace some some lines on Android PCB to check where CAN transceivers go to, try out 3.8.3 update, maybe play again with modding some apps, and I bought few microphone modules to try out with Android unit (noise cancelling, omni-directional and uni-directional). Will report back as soon as I learn something.
01-18-2020, 07:39 AM | #2189 | |
Rep 87
It's still trying to switch sound output for those warning, and its annoying. I would be happier if this "feature" could be completely disabled. |
01-18-2020, 10:52 AM | #2190 | |
Rep 1,048
Code:
ro.build.display.id=Ksw-P-Userdebug_OS_v3.8.3 ro.build.version.incremental=eng.zlx.20200113.193155 ro.build.date=Mon Jan 13 19:31:58 CST 2020 ro.build.description=Ksw-P-Userdebug_OS_v3.8.3 ro.build.fingerprint=Android/msm8953_64/msm8953_64:9/PKQ1.190202.001/zlx01131931:userdebug/test-keys No Updates to the factory_config.xml Update/Bugfix: Bluetooth Stack Update, some kinde of Pause behaviour have been implemented and some more code changes. EDIT: Feature: AUX switching does Stay at AUX-in when switching to OEM GUI (when manual Aux switching is selected, detailes here ) Feature ? : new code so the MCU itself seems to is now able to reboot the Bluetooth module. Feature: Widevine DRM has been implemented, so it seems that they again listened to our requests however, at least on my machine Netflix does still not work, i now do get an Error (-13). Maybe a full factory reset installation will help, but i can`t test at the moment as i`m not at home. Kri Last edited by Kri; 01-20-2020 at 09:35 AM.. |
01-18-2020, 12:37 PM | #2191 |
Rep 11
Hi friends, I have been reading you for several weeks, and now, since I have received my Android 9 screen 4+64 from NAVIODM+fakra C "Y adapter" (for the GPS)+front and rear wireless cameras, I am going to proceed to install it, so thank you for sharing all your knowledgement.
But, before installing all the things, I have some questions: -Where is the best place to locate the provided microphone? -Is it correct to take the +12V cable from the rear light to power the rear camera and wireless transmitter? -The front camera is going to be located under the plate, so I need to know where the hell do I take the +12V for the camera and the wireless transmitter -Where do I connect the front camera? DVR input? Thank you in advance for your help! |
01-18-2020, 01:00 PM | #2192 | |
Rep 79
I ordered front camera too but seems too complicated so I CBA to install it. |
01-18-2020, 03:18 PM | #2193 | |
Rep 80
In regards to the front camera, I bought this one and it had a wire for the constant 12V and another one for the trigger to start recording. I believe I added the constant 12V from the cigarette lighter that I never use (copilot feet) and the trigger may have been from the headunit as it had a leftover wire that I wasn't using and turned on/off with ignition. I checked again today and the bluetooth apk I modded is a system app. No issues with Lucky Patcher installing the modded app over the original. I'm running Android 8.1, but it should be the same concept. |
01-18-2020, 03:45 PM | #2194 | |
Rep 28
You mean remove the aux connector in the armrest ? Disassemble it and remove the cable in the aux in the armrest ? But will this solve ? It will improve the sound quality ? My problem is that when i hear music from oem side either spotify from my phone through aux conencted with my phone or radio the sound quality is very good. When i hear from the spotify app installed in the android side sound quality is much much worse no matter how i change the three equalizer settings. So if i remove aux from armrest how will this improve sound quality ? (Android 9, snap unit) |
01-18-2020, 08:35 PM | #2195 |
Rep 122
automate the startup of navigation + music (split screen)?
anyone figured out how to automate the startup of navigation + music (split screen)? and ideally make it 66/33% ratio vs 50/50?
01-19-2020, 04:51 AM | #2196 | |
Rep 114
01-19-2020, 04:58 AM | #2197 | |
Rep 43
Change the aux input volume level on the BMW OEM side and make sure that the audio level on the Android side is set to around 24. The sound quality is poor when the aux input is overloaded. Reduce input sensitivity and android output level. Simple as that. |
01-19-2020, 06:06 AM | #2198 | |
Rep 399
01-19-2020, 06:59 AM | #2199 | |
Rep 399
01-19-2020, 09:49 AM | #2200 | |
Rep 2,366
Drives: E63 645Ci
PA_MONITOR_ACTIVE is not an option in CAS2.C05 at all so I couldn't try it out. Maybe someone with newer version of CAS can check that. Also pressing volume/power knob on CCC when key is not present, doesn't do anything in my case - no screen, no sound, nothing. |
