BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Advice on replica 405M wheels on 335d
      12-13-2017, 04:52 AM   #1
olie123
Drives: F30 335d xDrive
Okay, so I've found some replica 405M wheels direct from manufacturer in China for a silly low price. I'm working on the basis that replica wheels bought from a UK seller will have come from China anyway so I'm just cutting out the middle man.
Are there any particular problems with replica wheels or are they usually alright?
Also I'd assume best wheels would be 20x8 front and 20x8.5 rear to match BMW 405 wheels.
Thanks in advance!
      12-16-2017, 11:11 PM   #2
PabloK
PabloK's Avatar
Drives: F30
finish usually isn't as durable, typically heavier. I run replicas in the winter but thats about it... they last 2-3 years then start to look like shit
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      12-17-2017, 09:48 AM   #3
jnecr
Drives: 2014 328d
I'd be very surprised if they are direct from the manufacturer. Manufacturers like that generally wouldn't sell to the public and probably wouldn't even have the salesman to do it. They're looking to sell 10,000 wheels, not 4. It's more than likely still a middle man that's just posing as a manufacturer.
I'd be very wary of those wheels, and the old adage "you get what you pay for" most definitely applies.
2014 328d
      12-17-2017, 10:39 AM   #4
olie123
I think they are as I've basically said I wanted a "sample" when they usually deal in numbers like you say. But you're right, there's probably a reason they're so cheap. Might just lower the car first and see if it looks better
      12-17-2017, 10:41 AM   #5
olie123
Thanks for the info
      12-21-2017, 03:36 PM   #6
TekUK
Drives: 435d GC
I'd be careful. I've bought some aftermarket stuff directly from China via eBay and have been disappointed with the quality on all of them. You won't be able to return them if the quality is crap. Go for a used set of OEM or a used reputed aftermarket set.
335d, 405m, replica, reps, wheels
