BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Grinding noise from center console.
      12-07-2019, 05:40 PM   #1
Sterek
Drives: f30 340i
Ugly sound when accelerating, seems to sound like coming from center console. anyone else have this problem with their f30? 2016 340i
Pauloxxi339.00
      12-07-2019, 07:37 PM   #2
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Yikes, sounds dreadful. My bet is exhaust heat shield touching the driveshaft, not that uncommon on any car, really.
      12-07-2019, 08:27 PM   #3
Sterek
Drives: f30 340i
so should i bend it out of the way. I scheduled a appointment at dealer on Monday.after reading some forums people say that the ebrake cable can b
e rubbing on the driveshaft.
      12-07-2019, 11:09 PM   #4
psyki
E36fiend
2014 X5  [0.00]
Yeah you'll want to bend it out of the way or better yet, determine why it is loose and take corrective action. I have to imagine it wouldn't be hard to spot something touching the driveshaft if you can get underneath the car. Could be a fastener came loose or something like that. Good luck and let us know what you find.
      12-07-2019, 11:28 PM   #5
On3Bad40
On3Bad40's Avatar
Drives: BMW 340i
Had the same issue with my 340i , took it to the dealer while it was still under the 50k miles warranty . They said it was the e brake line rubbing against the drive shaft . They fixed it haven't been an issue since
Bad40
      12-08-2019, 09:28 AM   #6
SCS55
Drives: E90,F30, F80
Almost positive it's the rear parking brake cable. My 2015 does exact same thing. Dealer quote of $799.00to fix. Part (clip) was $11.40 with a BMWCCA price from my dealership parts department. Spoke to a tech on the way out and he said I'll have to drop the rear fuel tank about 3 to 4 inches to get to it. Planning on diy'ing it next week.
djacinto373.00
      12-09-2019, 02:09 PM   #7
Sterek
Drives: f30 340i
Okay i dropped it of at the dealer this afternoon. waiting to hear back from them. Im hoping my cpo warranty will cover it. If they want 700$ to do it, ill do it myself. link your diy if you do a write up on it please.
      12-09-2019, 02:31 PM   #8
SCS55
My dealership said no on my CPO coverage. Good luck. Depending on the outcome, I'll post a DIY ASAP.
      12-09-2019, 03:05 PM   #9
JDTX
Drives: 2016 428i GC Alpine White
2016 BMW 428i  [0.00]
Interesting it's not covered by CPO... this would not be 'wear-n-tear' is it? maybe it is?
2016 428i GC
      12-09-2019, 03:30 PM   #10
Sterek
Drives: f30 340i
fingers crossed
      12-09-2019, 03:31 PM   #11
Sterek
Drives: f30 340i
you would think. its only 200 miles over 50k
      12-09-2019, 04:43 PM   #12
Sterek
Drives: f30 340i
well 170$ later for a diag and not covered under warranty should of diy'd. Gonna pick it up and order the part maybe do it this weekend. Someone should start a campaign for this.
      12-09-2019, 05:55 PM   #13
Sterek
Drives: f30 340i
Also debating on just using zip ties to fix it. If the plastic is so brittle maybe a ziptie would hold up better.
FastF30521.00
      12-09-2019, 08:07 PM   #14
JavN
JavN's Avatar
60
Drives: 2023 M3 Comp/Xdrive
My 335i is doing this exact same thing, any idea what exactly is it with the parking brake cable? Is it just that a clip broke and the cable is touching something, or does the cable it self need to be replaced?
      12-09-2019, 09:11 PM   #15
Sterek
Drives: f30 340i
i fixed it with two zipties. 900$ fix or two zipties? ill explain how i did it and try to take pictures
Aldor2787.00
FastF30521.00
zrile91.00
      12-09-2019, 09:35 PM   #16
Sterek
Drives: f30 340i
so there is a plastic retaining clip that holds the rear parking brake lines up and away from the driveshaft. The plastic clips break off the retainer. So i decided to take 2 zipties on each side and tighten up the line closer to the top of the heat shield. I was only able to get one good picture.
https://ibb.co/BNRVxTS
Appreciate 6
JavN60.00
Aldor2787.00
F30lolz6798.50
OC_F32118.50
      12-09-2019, 10:58 PM   #17
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
A tech friend said CPO just started covering it.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
      12-10-2019, 06:35 AM   #18
F30lolz
I can haz cheezburger?
F30lolz's Avatar
6799
Drives: 14 Sahara/08 335xi/22 Maverick
My 2015 320 started doing this a few months before it got totaled. My 428i didn’t do this when I picked it up nearly two months ago but now the sound is creeping up at times.
We need to demand a recall!
Originally Posted by RaptorKTM View Post
Also our E90 330 and 325 will soon have some sort of boost. So there is actually more of a chance to get more hp out of a 330 then a 335 in my opinion
      12-10-2019, 09:46 AM   #19
Sterek
Drives: f30 340i
My dealer would of if my car had less than 50k. I have CPO warranty and it wasnt covered.
      12-10-2019, 09:47 AM   #20
Sterek
Drives: f30 340i
yeah i agree they need to make it out of metal so it doesnt keep snapping
      12-10-2019, 12:23 PM   #21
N55Msport
N55Msport's Avatar
Drives: 11'E90 15'F30 16'F80
Very nice. I already bought the clip and still planning on installing it after this business trip, but if the zip ties solve the problem I'll go that route instead of dropping the tank etc.
      12-10-2019, 01:49 PM   #22
Sterek
Drives: f30 340i
Plus i would trust zipties a lot more than the cheesey clips. they also make metal zipties if you want to make sure it will never break again
SCS55291.00
