02-07-2019, 01:27 PM | #1805 | |
Rep 102
Do you have a new firmware from Louie? |
02-08-2019, 02:04 AM | #1806 | |
Rep 606
Installing apps also dont work since it keeps indicating download pending... Ive removed waze to install it fresh but thats now not possible. Waze is way better than maps.... Weird thing is that all is killed when not on screen.. also things like the DAB or Tasker.. |
02-08-2019, 02:43 AM | #1807 | |
Rep 102
02-08-2019, 06:12 AM | #1808 | |
Rep 190
Did you manage to solve the sorting issue with the music player somehow? I have all my tracks with numbers in front but the app does not sort them correctly it appears to be random listing on the start of the list and then starts to sort them kind of correctly. i tried to clear the cache to force it re arrange things but nothing really changes. Also my files do not have any .dots in the file names. So i end it up using poweramp instead of the stock music player but the use of the idrive knob is better for daily use. Any help appreciated. |
02-08-2019, 10:35 AM | #1809 | |
Rep 32
Disappointed in response or even lack of response from Ugode despite several chase emails on black screen with "No signal". Only done it a couple of times after about an hour journey using Google maps. So not sure if it's GM related or maybe overheating. |
02-09-2019, 04:57 AM | #1810 | |
Rep 606
the no signal issue can be caused by this since the output voltages are not the same so the android unit receives an overvoltage on the gps antenna. Remove the splitter and use separate for your idrive and android system. It solved it completely for me. Home network or hotspot doesn't change it for me it seems.... |
02-09-2019, 05:08 AM | #1811 | |
Rep 32
02-10-2019, 05:41 AM | #1812 |
Rep 2
Hello! I also have a problem with my 10.25" android 7.1 HU's. I I bought the unit from aliexpress in september 2018. At the beginning it worked fine, then the screen began to block when I was using waze. After that, I uninstaled waze but every time, after 10 min of using, the android system it's blocking. The bmw original menu it's working fine.
I updated the android 2 times but the situation is still the same. I'm not using a splitter for the GPS antenna. I do not know what to do!! Many thanks for your help!! |
02-10-2019, 06:36 AM | #1813 | |
Rep 19
02-11-2019, 05:14 AM | #1814 | |
Rep 7
I've unbricked my device thanks to you. It was pretty hard to deal with the SMD resistor which is really really thin, but it worked ! I was trying to install another ROM on the device, I shouldn't. |
02-11-2019, 02:41 PM | #1815 | |
Rep 36
I have a lot of folders and usually my files start with a number, song number like 01-02 etc. and no problems at all. |
02-11-2019, 02:50 PM | #1816 | |
Rep 190
You have metadata in your mp3s also ? Artist , album etc ? I am wondering if there is a difference between the app from September with November. I had some free time today and tried several solutions. The one that worked was to total format the sd card , rebuild the MBR sector and copy all the music files again. Now everything is ok with the sorting in music app. I am running the 28/11/18 firmware. Last edited by koutsouk; 02-12-2019 at 07:34 AM.. |
02-14-2019, 04:57 PM | #1818 |
Rep 2
Hello again! I have a question: my unit is a 10.25 andoid 7.1 unit with a MCU for NBT system but I think my F31 from 2013 has a CIC system. When I ordered I've sent photos to the supplier from aliexpress but he said that I have a NBT and sent to me a android unit for NBT.
Here are some photos with my unit. Please let me know if I have a CIC or NBT. Many thanks!! |
02-15-2019, 02:20 AM | #1819 | |
Rep 36
Let me know if you face issues with some files with metadata like "Feat." etc... |
02-15-2019, 04:42 AM | #1820 |
Rep 9
i have installed on a F30 with retrofit NBT, the unit powers up, i can access both idrive and android. only issue is, i am unable to set the time in idrive, so on my speedometer cluster it shows ---- and also sound only from left. google maps takes forever despite showing 7 locks in gps test app
02-15-2019, 04:57 AM | #1821 | |
Rep 47
Judging by the connector I'd say its NBT. But search the thread to make sure. |
02-15-2019, 10:12 AM | #1822 | |
Rep 777
https://www.bimmer-tech.net/blog/ite...cic-nbt-nbtevo |
02-18-2019, 08:21 AM | #1823 |
Rep 81
For you guys who have it installed, how's Carplay on the Ugode (or other) units?
I really want to add carplay functionality to my 2014 but I figure why not pick up a bigger display for pretty much the same price. |
02-20-2019, 12:26 PM | #1825 | |
Rep 33
For the price of ugode device + carplay adapter compared to retrofitting a larger bmw screen and some other carplay box, no doubt I would buy it again. |
02-20-2019, 04:50 PM | #1826 | |
Rep 31
