10-14-2021, 09:31 AM | #4027 |
Rep 74
Drives: BMW E92 320D
Hi,
I found them thanks to you and downloaded the NBT M. I have a problem cause I'm only seeing the boot image, can't see the boot animation. Any help, please. |
10-14-2021, 09:59 AM | #4028 |
Rep 2,366
Drives: E63 645Ci
10-19-2021, 07:40 PM | #4029 |
Rep 1,407
Drives: 13' F30 328i 6MT
Just noticed im on version 3.8.0 and there is a newer one, My audio and software has worked perfect with Apple Car Play and Android etc.. Is there any benefit or reason to update it to the latest and greatest? I use Carplay 95% of the time.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
10-19-2021, 08:00 PM | #4030 |
Rep 1,576
Based on the advice given by others on this thread: do not update if it works and if you are happy with it. You are increasing the chances of something going wrong that's specific to your setup. Check out the features of the new version and see if you see anything that greatly benefits you that's worth taking a risk.
10-20-2021, 12:07 AM | #4031 | |
Rep 1,407
10-24-2021, 02:23 AM | #4032 | |
Rep 5
10-25-2021, 02:56 AM | #4033 |
Rep 2,366
Drives: E63 645Ci
10-25-2021, 09:18 PM | #4034 | |
Rep 5
only issue is that the aux-usb is kinda poor quality, need to do a proper plug in to remove any hissing anyone able to recommend alternatives? i found 1 on aliexpress but i dont think it is worth $30 Last edited by CAPSNOSPACE; 10-25-2021 at 09:42 PM.. |
10-25-2021, 10:31 PM | #4035 | |
Rep 1,407
Android HU > USB port out > USB cable > DAC USB port in > DAC AUX port out > AUX cable > car AUX port in I run this DAC it was like $130 but worth it https://www.amazon.com/dp/B07HGCQ6NY...roduct_details Sounds exactly like my OEM HK now and filled in what the Android setup was missing.. On a side note does anyone know how to get the Android Volume to remember its setting? Everytime I get in the car I have to raise the Android Volume, It just doesnt save.. Is there a trick?
10-25-2021, 11:26 PM | #4036 | |
Rep 5
https://play.google.com/store/apps/d...ol&hl=en&gl=US Had the same issue too and the app fixed it, the rating is misleading but it works for me I increased the default volume for a few apps namely Zlink for external apps internal apps i increased the default volume for Android Settings and a few others which i thought were related to sound settings |
10-25-2021, 11:28 PM | #4037 | |
Rep 1,407
10-25-2021, 11:46 PM | #4038 |
Rep 1,576
Let me understand the USB to DAC issue:
The sound/audio that is generated & processed in the Android HU and resides inside...is digital. But, the Android HU's has to output that somehow and they are using some cheap-ass internal DAC (Digital to Analog) audio output circuits way below CD-quality. That Android HU outgoing analog-signal is normally connected "internally" directly to the car HU's AUX port via the quad-connector interface between the Android HU and the car HU. Alternatively, the Android's own (external) AUX cable is connected to the car's armrest AUX input which uses another AUX port of the car's HU. The quality of the audio of both of these Android HU AUX's is about the same. Now comes the external DAC solution: It takes the nice clean internal Android HU's digital signal and "siphons it" out via the Android HU's USB port into a quality high-fidelity (and pricey) external DAC adapter with at least 44kHz (CD quality or higher) analog output capability. This analog is then fed into the car's AUX port in the armrest. Why doesn't the Android HU's BT connect directly to the car HU's BT? Or, if the Android HU's lacks that feature, why can't we use a USB to Bluetooth adapter from the Android HU USB-port and wirelessly transmit to the car's HU BT? The audio would remain digital all the way...? Last edited by fe7565; 10-26-2021 at 12:23 AM.. |
10-26-2021, 12:20 AM | #4039 | |
Rep 5
however, i believe the latest android HU with BT5.0 will fix it nicely(?) now that you mention it, i shall try and insert a BT 5.0 dongle into the USB of the Android HU, see if it works as an alternative source Just tried, doesn’t work besides, given the current market of micro DAC/Amps, 1 can find a very affordable DAC that will make the difference sound night and day though i cant comment if the returns will diminish as we creep towards the higher priced DACs cheap DACs : Shanling UA1 / Creative SXFI Amp / iBasso DC01/02/03/04 mid tier : lotoo paw s1 / dragonfly black high end : dragonfly cobalt / THX Onyx / Earmen Sparrow Last edited by CAPSNOSPACE; 10-26-2021 at 12:57 AM.. |
fe7565552.50 |
10-26-2021, 01:29 AM | #4040 | |
Rep 2,366
Drives: E63 645Ci
It goes like that: NEXT UP, YOU WILL NEED TO KNOW HOW TO USE ADB ON YOUR COMPUTER TO CONNECT TO YOUR DEVICE TO MODIFY BUILD.PROP (((((WARNING))))): IF YOU DO NOT KNOW HOW TO DO THIS RELIABLY WITH THE NEXT FEW ADB COMMANDS, DO NOT PROCEED. IF YOU DO NOT DO IT PROPERLY AND ALL IN ONE GO, YOU WILL, I REPEAT, YOU WILL BRICK YOUR DEVICE AND SEND IT TO A BOOT LOOP. WE DO NOT HAVE A RELIABLE UNBRICKING GUIDE SO YOU HAVE BEEN WARNED. System Changes: 1. You will have to execute these ADB commands in a sequential way, ABSOLUTELY DO NOT EXECUTE ANYTHING IF YOU DO NOT KNOW WHAT YOU ARE DOING 2. Follow instructions here: https://gist.github.com/nicholaschum...9c7d5fa73176a1 3. After instructions are complete, go to Settings -> Sound and then Max out your Audio volume. This will now survive reboots after the commands above. Remember these instructions must be done all over again if you update your system. DO NOT COPY AN OLD EDITED FILE FROM A PREVIOUS EXECUTION TO NEW UPDATES OR YOU WILL ENSURE A BRICK. |
fe7565552.50 |
10-26-2021, 01:32 AM | #4041 | |
Rep 1,407
10-26-2021, 01:38 AM | #4042 | |
Rep 2,366
Drives: E63 645Ci
fe7565552.50 |
10-26-2021, 02:22 AM | #4043 | |
Rep 2,366
Drives: E63 645Ci
1. DAC. 2. Microphone (didn't end up using it that much though). 3. My keyboard app 😅 4. Custom theme which got replaced with ID7 launcher. 5. Custom boot animation. Couldn't fix shit screen quality though 😕 |
11-09-2021, 10:00 AM | #4045 |
Rep 108
Hello,
I am planning to buy Android Multimedia with Car play and Android 10 system. It has 32GB and 2GB ram. What do you think about 2GB Ram? Will it run Navigation, Youtube, and related things smoothly? In my area it is so rare to find 4GB ram multimedia. For the reference, this is the link for the navigation I am planning to buy: https://www.kupujemprodajem.com/auto..._id=1517758339 Last edited by klepic; 11-09-2021 at 10:08 AM.. |
11-09-2021, 08:22 PM | #4046 | |
Rep 2,366
Drives: E63 645Ci
11-12-2021, 05:48 AM | #4047 |
Rep 108
I got with 2 gb and its working perfectly!
Can anyone help me with the split screen? What to do in order to stretch it? I upgraded from 6'5' multimedia. I got CIC system. |
11-12-2021, 06:12 AM | #4048 | |
Rep 2,366
Drives: E63 645Ci
As for the split screen, it should work the same as on any other Android device but not all app might support that. |
