10-19-2021, 04:33 PM | #4621 | |
Rep 3
Has anyone tried out the MTK P60. I am curious if this unit will have a faster boot time and/or if extra ram will allow the unit to boot faster. Or has anyone tested the boot times of units with more the 4G and the SD625 and see boot time improvements? Additionally is this a real unit it claims an SD662 but I haven't seen it in the discussion? https://www.aliexpress.com/item/1005...08317864%22%7D |
10-19-2021, 05:46 PM | #4622 | |
Rep 2,366
Drives: E63 645Ci
If you value support (mostly community support but still regular updates from the manufacturer etc) and customisation options then you should stick to SD625 or SD662. Performance is the same on P60 and SD units, only differences can be seen in benchmarks but not in everyday usage. |
10-19-2021, 10:36 PM | #4623 |
Rep 50
Seems like one of the updates forces hotspot to turn on at start up? Any way to disable that? I've downgraded back to 2.3.6 but this issue persists.
If you open your wifi settings right at boot up you can see wifi is turned on, then maybe 30 seconds later it's turned off and hotspot is turned on. Really annoying when trying to root or enable kswoverlay. |
10-20-2021, 03:37 AM | #4624 | |
Rep 353
I was surprised recently that this screen has actual resolution 1920x720 and real SD625 (checked with CPU-Z and Aida64) but the SW is different from what we got used to it. It has balanced CPU cores load btw which is good and also better harness - longer between quad locks so easy to install it. I can't say this model is overall better or worse than those being discussed here, need more experience with it. |
10-20-2021, 04:15 AM | #4625 | |
Rep 2,366
Drives: E63 645Ci
Is that genuine Android 10 as well? So far I've only seen P60 units running A10 other than KSW SD units. But in the end if one doesn't care about updates, customisation options, community apps and support then I guess they can get whatever they want. |
10-20-2021, 05:47 AM | #4626 | |
Rep 1,048
But unless someone does open it to see the chip itself we never know for sure. Kri |
10-20-2021, 08:46 AM | #4628 |
Rep 2,366
Drives: E63 645Ci
10-20-2021, 12:10 PM | #4629 |
Rep 3
That would technically depend on how much data swapping is required during boot and also if there are any RAM tests during the boot.
Obviously the ssd is more likely to have an impact and so I am also curious if the 64/128/256 have different boot times as density of sdd can effect throughput or if they appear to be limited by the bus. Additionally it would be interesting if processing power impacts boot time. |
10-20-2021, 12:36 PM | #4630 |
Rep 2
Hello,
Is it correct that when you answer or making a phonecall via the BT phone/communication, that all other apps, e.g. TomTom, Waze, Google maps, feezes? Only the phone app works? If so, then maybe it's easier for me to use the iDrive for my iPhone. MCU Ver: 615095dALS-CIC-GTL-DC-210406 App Ver: Ksw-Q-Userdebug_OS_v3.1.5 System Ver: 10-8953EA-865938020791344 Storage: 45.52GB/64GB RAM: 4GB |
10-20-2021, 02:30 PM | #4631 | |
Rep 2,366
Drives: E63 645Ci
We are not discussing here a highly refined product like a flagship phone that can boot from cold in 10-15sec. These are hacked, poorly designed, unoptimised devices that use at least 2 year old hardware and devs hardly have any clue what they're doing. |
10-21-2021, 04:21 AM | #4632 | |
Rep 353
Fully agree if android is working well then no need updates. Regarding that HU, apart from broken English and Russian translation, it works well and fast. The only and big issue I faced was the sound noise in the background, the louder music is the more noise you can hear. When the engine is running it gives even more noise. I tested a phone via aux in the armrest and there's no that noise. So the issue is definitely on android HU side. I tried different aux setups - long cable from the HU to armrest, coded CIC for HU to be active and disabled aux/usb (to avoid using that extension cable), no difference. Tried also ground loop isolator, also no difference. Perhaps that long aux cable works like antenna? It is wired to the main android harness so I cannot unplug it, only to cut it off. This is what I'm going to do in the next round) Also perhaps separation of sound wires and shield them in the android harness will help. Any other thoughts? Perhaps I will open the HU and make the chip photo to verify that. There are no warranty stickers fortunately) |
Kri1083.50 |
10-21-2021, 04:35 AM | #4633 | ||
Rep 2,366
Drives: E63 645Ci
10-21-2021, 08:17 AM | #4634 |
Rep 124
Drives: BMW316da Touring 2014
Location: Ypres, West-Vlaanderen (near the tranches of WWI)
Can I update my Android HU from 2.8.6 to 3.1.5 in one time?
Do I have to reinstall all apps and configurations after this update? Now I have rooted my device and installed an image which I got from RedErik, do I hev to reconfigure this all? Thanks in advance. Last edited by rytec; 10-21-2021 at 08:26 AM.. |
10-21-2021, 08:26 AM | #4635 |
Rep 2,366
Drives: E63 645Ci
10-21-2021, 08:28 AM | #4636 | |
Rep 124
10-21-2021, 08:30 AM | #4637 | |
Rep 124
Wouldn't you recommend to update maybe? And do I have to reinstall/reconfigure all things? |
10-21-2021, 08:36 AM | #4638 | |
Rep 2,366
Drives: E63 645Ci
If you care for selecting music and video from your main tiles, then yeah might be good enough reason to update, but personally I wouldn't bother. I would use custom launcher that is fully customisable and allows you to select whatever you want wherever you want - like ID7 Launcher by Jellepepe. Yes, you have to redo most of your config if you update. |
10-21-2021, 08:47 AM | #4639 | |
Rep 124
I will have a look at the ID7 launcher |
10-22-2021, 10:03 AM | #4642 |
Rep 1
Hello Guys, Greetings from Lithuania 🇱🇹! I bought an e60 which has android head unit installed by previous owner. It's an android 10 4 gigs of ram and 64gb. Question is do all versions of head units with SD625 has an DSP chip? Because I can't find a EQ app. I'm attaching the pic of settings screen, maybe I should update it? And can this be done straight from 1.5.7 to 3.1.5? Sorry for my dumb questions!
