10-19-2021, 10:30 AM | #1 |
Rep 8
BMW F33 Rear Turn Signal Error 804875 after coding
Hi All,
This may be a simple or not so simple problem. I recently was posting the articles to help me resolve a 804875 error. Basically I used BimmerCode to code my 2014 F33 to accept LED lights in the rear turn signals in the REM. Once done I put in the LEDs and still got a light bulb error. I thought the lights were no good and did a backup recovery. I then dropped in the original filament bulbs. All errors were gone and the original filament bulbs are passing the warm/cold checks. What happened then was I noticed hyperblinking when indicating and the rear signals did not light up. I then removed a bulb to check and immediately saw the light bulb error - so I'm sure the bulbs are good and there is a signal going through them for the checks - but no power. I took the car to a BMW specialist who upon scanning the car saw error fault 804875 (One or several outputs have exceeded the approved number of short circuit cycles (Encodable). He then tried to clear / erase the error and restart the REM ECU. He was unsucesful and the fault remains. Even after that - there was no luck. I did share my log files with BimmerCode tech team who said 'we are working on a function to reset the short circuit counter for the BimmerLink app' and may take a few days. Have any of you faced this? I am going on a long roadtrip with my 3 year old and really don't feel safe driving without these rear turn signals. Its the only car I own right now. Please do try and help me if you know a fix to this. |
10-19-2021, 11:04 AM | #2 |
Rep 298
At least in the past the tool for that job (reset those counters) has been Toolset32, but personally I do not know how to use it. There are folks here such as Ibo24 who have helped others remotely with similar issues, but you need of course enet cable and a PC for that.
04-08-2023, 10:41 AM | #4 |
Rep 14
battlecat did you manage to fix?
I’m experiencing a similar issue: I changed rear indicators to LEDs, coded them to LED using Bimmercode however bulbs started to hyper flash hence, reverted back to stock halogens and recoded back. Now rear indicators won’t work at all, only the side, front and dash indicator signals work but they hyper flash. No dashboard / error warnings show either. Tried also hard resetting ECU by disconnecting battery for 15-20mins but no luck. |
04-08-2023, 12:01 PM | #5 |
Rep 16,081
Bimmercode won't cause hyperflash, but failing to code the turn signals to LED will. It's easy to miss doing them, since you have to separately code the different rear bulbs. Clear the error codes with your OBD diagnostic and repair tool. Disconnecting the battery doesn't reset anything other than the clock.
04-08-2023, 01:51 PM | #6 |
Car Hypochondriac
335
Rep 901
Bimmerlink has the ability to reset short circuit codes. Not a free feature though, I think.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
04-11-2023, 08:10 AM | #7 | |
Rep 14
04-11-2023, 08:12 AM | #8 |
Rep 14
04-11-2023, 08:55 AM | #9 |
Car Hypochondriac
335
Rep 901
No, if you buy the full version it's included.
04-11-2023, 09:34 AM | #10 |
Rep 16,081
You may have to code the front to LED as well, even if they're not LED, as the flasher works on both. But your picture doesn't show the rear turn signal LED conversion as being active.
04-11-2023, 10:27 AM | #12 | |
Rep 14
04-11-2023, 01:57 PM | #14 |
Rep 14
04-12-2023, 01:50 AM | #15 |
Rep 83
Make sure you have the cold bulb check (or whatever it's called exactly) turned off in Bimmercode. My car came with LED from the factory and the bulb check is turned off as standard. I once turned it on in Bimmercode and that caused the indicators to hyperflash
04-12-2023, 02:37 AM | #16 | |
Rep 14
04-12-2023, 03:47 AM | #17 | |
Rep 83
I can't connect my car at the moment so I opened up the Bimmercode app in demo mode. For some reason it doesn't show up there, but I hope it does with yours. |
04-12-2023, 07:27 AM | #18 |
Rep 16,081
04-12-2023, 08:58 AM | #19 | |
Rep 14
04-12-2023, 09:12 AM | #20 |
Rep 83
04-12-2023, 10:03 AM | #21 |
Rep 16,081
There are a number of codings that require changing multiple CAFD entries when using E-Sys. One of the nice things about Bimmercode is that it combines many of those into a single click operation.
04-16-2023, 07:38 AM | #22 |
Rep 260
It’s very common for the ground pin on the power connector to the rear turn signal/brake light to fail. Unplug the connector and inspect it CAREFULLY. Use a flashlight and make sure that all the pins are intact. On mine, a ground pin had completely burned away, and I could barely see the damage.
804875, error, rem |
