12-07-2020, 05:44 PM | #331 | |
Rep 818
Drives: 2021 BMW X3 M
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
12-07-2020, 05:45 PM | #332 |
Rep 818
That's probably stock spec. I got my car back in factory spec on the same springs.
12-15-2020, 07:16 PM | #333 | |
Rep 10
03-29-2021, 10:12 AM | #334 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
Hi Everyone!
Thought I'd contribute as well. This thread and few others made me pull the trigger on 437Ms. 2018 BMW 340i xDrive - Stock M Adaptive Suspension. Tire specs are: Kumho Ecsta PS91 F:235/35/19 R:265/30/19 Very satisfied with the tires!! They are super sticky for the price. However, i do wish i went with a bigger sidewall set up because with my current set the sidewall are very thin. I wanted to go for a little more meaty set-up.. With stock suspension there is no rubbing at all. But... The wheel gap (Mexi-Flush) is really bothering me I did purchase H&R Sport Springs and will have it installed sometime this week. Will update my post again. |
04-13-2021, 08:15 AM | #335 |
Rep 10
Here's my 437M wheels... an absolute steal for $1100 off FB marketplace in Milwaukee with TPMS and rubber, reduced to $825 after I sold the tires.
I am on stock suspension. Tires are Continental Extreme Contact 235/40 and 265/35 which are almost identical for circumference (due to Xdrive). I wanted Michelin Pilot Sport 4S but my dealer said Michelin was really affected by the COVID shutdown. Last edited by KrampusF30; 04-13-2021 at 08:17 AM.. Reason: tire size |
alohasurftoad3076.50 |
04-29-2021, 07:51 AM | #336 |
Rep 2,146
Drives: F80 M3
thanks to the invaluable info in this thread I was able to get dialed in
Instagram: http://instagram.com/e90nate
05-05-2021, 04:41 PM | #337 |
Rep 426
How are you guys with Pre-2014 cars handling the TPMS? My tire shop told me that I can't swap the sensors from my 397 wheels to the OEM 437's because they're not compatible. I have a 2013 335i sedan.
05-11-2021, 11:57 PM | #338 | |
Rep 30
05-24-2021, 04:07 PM | #340 |
Rep 133
Drives: F32 435dx
Just adding my 435dx (stock height) with the so sexy 437m in OEM M4 MPSS tyre combo.
06-05-2021, 10:40 PM | #341 |
Rep 5
F30 lowered on 437M wheels
Time to contribute to the thread. Lowered on Super sport springs, M performance front bumper & painted gloss black lip
09-09-2021, 03:36 PM | #342 |
Rep 13
437m on 2017 440i coupe xdrive
Hi guys! I drive a 2017 BMW 440i xdrive coupe and want to change my wheels to 437m staggered rims (19x9 & 19x10). I visited a tire store and they gave me two possible options for this set up, 235/40/19 and 265/35/19 . The other option is 225/40/19 and 255/35/19. I want to know if this is a safe set up and won't mess up my xdrive system or cause any problems to the car. I have stock height no modded springs or lowered.
09-21-2021, 02:55 AM | #343 |
Rep 1
09-22-2021, 12:37 PM | #344 |
Rep 4
My wheels
Hello!
Just wanted to show you the wheels i just add to my car, I got them in black glossy. The tires at the front are 225 45 R19 And at the back 265 45 R19 |
09-22-2021, 01:45 PM | #345 | |
Rep 1,502
Drives: F36 435xd
235/40/19 and 265/35/19 should not be a problem. I've been running that for almost 3 years and approx 80.000km without an issue.
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
09-23-2021, 09:33 AM | #346 |
Rep 60
11-19-2021, 03:57 AM | #347 |
Rep 296
Just a little bump for this thread, I have just read a whole bunch and found it very informative. I just picked up a set in Ferric Grey and am hoping to fit the 225/40 and 255/35 combo as I'm running air suspension and shall need as much clearance as possible especially on the inner front as the airbag on my strut protrudes further out than the stock set up.
Hopefully I can pull it off without rubbing the bag as I love the concave OEM look these give. I may see if my tyre shop can fit the run flats from my OEM 442M fronts just for a test fit before dropping £££ on fresh tyres. |
11-28-2021, 12:42 PM | #348 |
Rep 296
Just an update after a test fit today
Pics are with a 5mm spacer up front to help clear the air bag / strut Stock tyres (275 / 255) will not let me air out completely so will be swapping for 255 / 225 |
01-31-2022, 08:06 PM | #351 |
RedBaron3
26
Rep 24
Running Squared
01-31-2022, 11:37 PM | #352 |
Rep 1,827
Found a seller who bought an extra set for his F80 to go square using the rears so he ended up with 4 fronts that he had no use for.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
RedBaron325.50 |
