12-04-2020, 11:36 PM | #134 |
Rep 420
I have methanol on top of the firmware with boost boost through JB4. Who just drives the E30 / 40/50 there, you can limit the moment in the firmware to an angle and boost. Weak gears in 8hp50 are 1-4-6 and 7/8 won't take more than 25/27 psi either. Personally, my machine cuts the moment by itself and drops the boost from the current 24psi to 14psi in 6th gear after 230 km / h. So I have limited the moment to XHP.
But finally it will be possible to adjust everything only in the next season. It's winter now. Snow, ice and cold. So I will start driving and tuning from the end of April 2021.
M140IX. Turbo Pure 800 Cast.
Supr3me551.00 |
12-09-2020, 04:46 PM | #135 |
Rep 348
Running XHP Stage 3 on my m240i. Anyone else have this "inactive shadow code" is for the transmission? When I check for codes with XHP it says none but MHD shows 421892. Thanks! Any feedback appreciated.
Pure800 - DS2 HPFP - Nostrum S1 - ER Catless DP - Remus Non-Resonated Catback - BM3 Flex Fuel Kit - Ross V1 VTA PCV - Custom Tunes on MHD/BM3 - xHP Stage 3 - TCKline SA/DA Coils - Apex ARC8s - Vicrez Carbon Fiber CSL Trunk - ALP Laser System - Escort Max 360c with Blendmount + more... | IG: kianf22 |
12-12-2020, 07:41 AM | #136 |
Rep 525
hi folks,
just tried to connect my pixel 3 to the car for the first time to flash xhp. Have i bought a dud cable? https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 its connected via an ethernet>usbC adapter, into the phone. The adapter shows it's green and orange led's flashing, a message on the screen says "allow xhp flashtool to access AX88179?. i click ok. I go into xhp app. press connect. and it just says can't establish connection. i've tried about 3 times, same result. have i just bought a crap cable? The phone has definitely recognised the connection though? EDIT: well apparently i have to configure the ethernet settings on the phone.......but i cannot see anywhere in android 10 giving me the option to do that. any ideas? Original Poster Mani H. 8/13/20 @ben Solomon, the connection is between a car and the phone, for coding ability. There is no access to the car network, the static IP is needed to guarantee DHCP handshake. It's quite disappointing because even an iPhone has that capability..android 11 doesn't allow you either. Looks like this will be the last Pixel phone for me. Great.........looks like you cannot use ENET if you have a pixel 3 on android 11 at least. Now i have to get a usb Dcan instead. Last edited by gippy; 12-12-2020 at 08:05 AM.. |
12-13-2020, 06:13 PM | #137 |
Rep 348
Anyone else have this??
mgeller51.50 |
12-20-2020, 04:18 AM | #138 |
Rep 389
Drives: 18 BMW M2LPower
xdrive drivetrain is very capable
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
02-16-2021, 01:12 PM | #139 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Do you guys think xHP tune will affect smog emissions?
Car got flagged by the state randomly as I'm trying to sell the car here in California. I am currently running BM3 tune which I flashed back to stock and relocked the DME. |
02-18-2021, 05:21 PM | #140 |
Rep 348
If you flashed your DME back then I don't get why you can't just flash xhp back to stock... it's rather simple. What do you mean "randomly flagged?"
02-19-2021, 12:21 PM | #141 |
Rep 200
So over time, removing the toque limiter with xhp hasn't hurt the transmission for most users? Asking before I look into purchasing. Haven't even gone stage 2 yet, but if it will reliably increase performance I'm all for it. (If you respond with your experience please specify which xhp flash you're using) thanks
02-21-2021, 03:15 PM | #142 |
Rep 22
Tried to install/use/flash xHP today. No luck. I succesfully flashed MHD stge 1 months ago. Changed from RON98 to RON95 today. After that could not connect to the car with the black MHD wifi adapter.
Should I do something with the two codes that I received for the flasher and maps license? Running MHD today I also had a shadow code: - DME active codes - None - DME shadow (inactive) codes - 1FB101 - Check Control message (ID 229): Vehicle battery charge low!. - Transmission active codes - None - Transmission shadow (inactive) codes - 420801 - Electric motor clutch 2 sensor: Supply short circuit to B+. Any help with the shadow code or even better: loggin into xHP and connecting to the car is much appreciated. |
02-21-2021, 03:29 PM | #143 |
Rep 4,876
ZERO luck with the app on my Galaxy S9 + USB->ethernet->ENET cable after the Feb 19th update. It will connect to the car, but then I need to disconnect from the car for it to check for updates, and then it fails, since it's not connected to the car.
They do have a Win10 version now though. That worked A+, first time, with no BS. |
02-23-2021, 10:52 PM | #145 |
Rep 20
Running mhd stg2hpfp e40 tune. When initially installed xhp stg3 it worked. However lately when trying to launch the car hard it does not want to shift gear. From 1-2 or sometimes 2-3. Or does a jerky terrible shifts.
Retuned the xhp to 'stock' setting and the problem disappeared . Has anyone experienced anything similar? |
02-24-2021, 07:20 AM | #146 | |
Rep 4,876
El Lechero13.50 |
02-24-2021, 07:24 AM | #147 |
Rep 4,876
02-24-2021, 10:19 AM | #148 | ||||
Rep 200
02-24-2021, 02:25 PM | #149 |
Rep 4,876
02-25-2021, 01:58 AM | #150 | |
Rep 200
02-28-2021, 04:46 AM | #151 |
Rep 22
Received help from xHP. Not sure what went wrong in the 1st attempts. You need to follow the manual carefully, select flight mode etc and switch multiple times between connecting to the car via Wifi and back to the internet via 4G. Eventually have it all working and flashed stage 3. First impression is good. Transmission matches a lot better in the diffrent modes with a slightly tuned B58.
03-01-2021, 06:48 PM | #152 |
Rep 4,876
They did just have a new app update a couple days ago. I can use the mobile app now as well. Now it logs into your account to retrieve your vehicle, then you can connect to the car to do the magic.
04-07-2021, 10:12 PM | #153 | |
Rep 780
Exhaust pop during upshift seem to more noticeable in stage 2 tune rather than stage 3. Comfort/eco pro seems similar to stock but the biggest difference is how fast gear change is when in Sport+. Very good tune overall and extremely happy
2020 BMW G07 X7 3.0d M Sport
2018 Audi FY Audi SQ5 2016 BMW F36 440i GC M Sport |
04-27-2021, 03:28 PM | #154 |
Rep 2,047
Just flashed stage 2 on my 440i - got mppsk and a downpipe in preparation for BM3 stage 2.
Got mixed feelings about xhp - the shift are certainly impressive, particularly in manual. But I do 90% of my miles in sport+ partially as I prefer the higher shift points. With xhp is changes gear when it hits 3000rpm even under hard accelleration. Can this be changed? If not, I will just flash back to stock and forget about it.
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
