06-30-2020, 03:07 PM | #23 |
Rep 255
Good idea, the dyno really would be ideal and I could use that as a last scenario for checking. I'm 90 percent sure tho it is coming from the turbo as it is on the front right side of the hood directly where the turbo is located.
06-30-2020, 03:26 PM | #24 |
Rep 3,185
The only way that would be an issue is if you have a silicone portion of the air/turbo intake. I think the William's elbow is the only one this could happen to.
06-30-2020, 04:19 PM | #25 |
Rep 909
Looking forward to the results.
Sleeper340i93.50 |
06-30-2020, 06:39 PM | #26 |
Rep 467
Best of luck. I see you're in the Seattle area. Where exactly are you taking the car?
Sleeper340i93.50 |
06-30-2020, 07:31 PM | #27 |
Rep 3,185
exhaust sounding lower could be a failing wastegate controller. Would happen on N54/5 when the boost solenoid would go out.
Sleeper340i93.50 |
07-01-2020, 12:16 AM | #28 | |
Rep 255
eksigned139.00 |
07-01-2020, 03:15 AM | #29 |
Rep 255
Just read up on it a bit, maybe you're right and my rattling sound is my wastegate. Especially since it's mainly at lower RPM. Gotta wait and see what we find tmmrw.
07-01-2020, 07:12 PM | #30 |
Rep 255
UPDATE: So from the boost leak testing the shop performed, they found a pretty sizable leak from the coupler post MAP sensor. They also put my car on the dyno as well and found that there was build up of soot around exhaust manifold runners/ gasket. Which means one of the gaskets from the turbo either came faulty, or was not torqued on properly from my installer.
Upon driving the car once the coupler was tightened, Throttle response and speed feels much better (yet to test if leak has fully been fixed) and the sound is little bit improved squeak wise, but is still there. They believe it is the faulty gasket causing all rattling , squeaking and the soot buildup issue as they said "There is visual evidence of PN the exhaust manifold leaking on the cylinder head" Do you guys know if Pure uses the same OEM gaskets? Or their own? If it is the OEM gaskets I believe I could narrow it to the installer but not sure either way. |
07-01-2020, 08:04 PM | #31 | |
Rep 585
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
Sleeper340i93.50 |
07-01-2020, 08:50 PM | #32 |
Rep 255
07-01-2020, 11:32 PM | #33 |
Rep 3,185
That's before the turbo... it's not a boost leak. Almost looks like the coupler is way too big to properly clamp down. Probably caused the whistling sound as air was sucked past it.
07-02-2020, 04:22 AM | #34 | |
Rep 255
On a side note, I need to change out this gasket ASAP. I'm pretty sure the burning smell I encounter occasionally on WOT pulls is solely due to the leaking gasket causing components to burn up, on top of the louder exhaust note and decreased performance. |
07-02-2020, 08:16 PM | #35 |
Rep 1,239
Yup thought it sounded like the focus with the intake sound glad you got it sorted
Sleeper340i93.50 |
07-08-2020, 11:10 PM | #36 |
Rep 255
Update: So I was just driving to the car wash when I heard a sound that resembled something disconnecting from my turbo area and right after I got a drivetrain malfunction message. Luckily, I was not far from home and turned around and granny drove back.
I noticed my turbo has 0 sound now after this event and is like it's not giving any power. My exhaust is definitely louder than before and has loud drone now. The power loss is pretty significant. Wondering if my exhaust manifold gasket finally went out.. Any thoughts anyone? |
07-08-2020, 11:14 PM | #37 | |
Rep 1,239
07-08-2020, 11:43 PM | #38 | ||
Rep 255
07-09-2020, 06:35 AM | #39 | |
mTekMods
2129
Rep 2,892
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
07-28-2020, 12:54 AM | #40 |
Rep 255
Another update: Just got my car back from the shop today with a freshly installed OEM gasket. Apparently my bolts were coming loose on the exhaust manifold. Good news is the Pure turbo was inspected/checked for shaft play and seemed perfectly fine along with everything else visually along with the power being restored. Bad news is the weird loose whistle sound is STILL THERE, mainly on partial throttle, gear shifts and burbles/pops. Thinking the oversized coupler was producing the sound I went ahead and replaced it with a proper sized coupler and still sound is there.
Took my friend along for a ride and he's thinking it's an exhaust leak and maybe my downpipe or something in my exhaust might be loose like a bolt missing, due to being able to hear the loose whistle sound from the exhaust pipe in the back during burbling/popping. Going to get my car lifted up tmmrw and hopefully I can find something while I double check my downpipe and check for vacuum leaks that maybe my mechanic missed. Frustrating to say the least Any thoughts are more than welcome : |
Supr3me551.00 |
07-31-2020, 12:53 AM | #41 |
Rep 255
So hopefully this is my last update before my car is fixed for good. My friend found a post where the OP had the same exact sound in his B58. BMW ended up replacing his whole turbo saying it was a wastegate issue, like some of you mentioned from the start and fixed the sound. Crazy thing is others had the same problem and it was on the stock turbo. Here is a link if interested.
https://f30.bimmerpost.com/forums/sh....php?t=1658133 Upon talking to Pure they haven't heard this issue at all for B58 but agreed to look at it if I send it back and will replace the turbine housing if found faulty. Really hoping the manifold is the issue because if not I'm down a car again for another 3 weeks plus shop fees +shipping fees and the same damn problem, which you guys will then hear on the news about a man drowning himself in the ocean with his car. Lol jk. |
Supr3me551.00 |
08-03-2020, 03:13 PM | #42 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Thoughts and Prayers!
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
imperfectluck425.00 Sleeper340i93.50 |
08-20-2020, 11:14 PM | #43 |
Rep 255
Alright so I got good news and bad news. Good news: Fixing my wastegate solved the rattle problem and the turbo spool sounds even better now.
Bad news: My turbo is done.... tried doing two WOT pulls and I heard a loud SCREECH which sounded like nails on a chalkboard which was very very loud and I'm sure the propellers are grinding against the metal causing that sound. Pretty frustrating because I told Pure about this that the play was bad and looked like it was scraping the sides and they said it was fine and even said they would realign it, but according to my shop guy they didn't even swap out the manifold or realign. Should have just went with Big boost with all this money, time and hassle I'm spending on installs/removal. |
Supr3me551.00 Uni-Rapide71.00 |
08-20-2020, 11:22 PM | #44 |
Rep 684
Frustrating.
2020 X3M
Sleeper340i93.50 |
