08-06-2020, 04:00 AM | #23 |
Rep 585
Not natively, but apparently it runs well with VMware / windows 10
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
VipinLJ1941.50 |
08-06-2020, 10:44 AM | #24 |
Petrolhead
1942
Rep 3,521
Thank you! If only my windows laptop worked....sigh
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
08-08-2020, 01:55 PM | #25 |
Rep 122
You can also use VirtualBox (it's free!) instead of VMware or Parallels.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
08-08-2020, 02:04 PM | #26 | |
Rep 122
I found that when entering the column headings from the MHD log in the settings it works as well:
OzBMR574.50 |
08-08-2020, 09:42 PM | #27 | |
Rep 585
As long as the column heading match the header from the csv it's all OK.
08-08-2020, 10:05 PM | #28 |
Petrolhead
1942
Rep 3,521
Thank you! I'll check that out tonight and see if it works with MacOS Catalina.
Current:
02-05-2021, 11:53 AM | #29 |
Rep 413
First real dry day this year 8°C / 48°F
Ran the same flat stretch of road. Same 99RON fuel on each run. Only ran the 95RON maps as the 98RON don't run well with -6 timing corrections. Mods: 200 Cell DP, TU HPFP Results from the Virtual Dyno. Stock: 300 whp MPPSK: 336 whp MHD Stage 1 95RON: 388 whp MHD Stage 2 95RON: 402 whp I plan to run the MHD E30 Stage 1, 2, 2+ as a comparison in the next week on E37 fuel. EDIT: Air temperature dropped to 8°C
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
12-24-2021, 10:57 PM | #30 |
Rep 2,357
Hi
Anyone else having this problem? Running latest 1.8.3. Windows 10 all updates installed...
(A Dane in China) |
12-30-2021, 08:15 AM | #31 |
Rep 2,357
After editing my .csv in Excel it is being saved as semi-colon separated instead of comma. I spent two hours trying to figure out what how to fix this... The list separator in Windows setting is already set with comma and in Excel also.....WTF?!?!
(A Dane in China) |
12-30-2021, 10:19 AM | #32 | ||
Rep 122
Sometimes you need to restart the app and or Windows because it doesn't always import the .csv files properly. At least that's what I've found. Quote:
I don't import them because I also don't know how to properly save them. I just open the .csv file and delete the rows that are not full throttle and then save it.
12-30-2021, 06:53 PM | #33 |
Rep 420
Here is the log from the dyno. Can you check in the program? This dyno featured 690BHP. 860NM.
https://datazap.me/u/glemm1970/dyno-...rk=15-19-11-17
M140IX. Turbo Pure 800 Cast.
12-30-2021, 07:29 PM | #34 | |
Rep 2,357
(A Dane in China) |
12-30-2021, 07:33 PM | #35 | |
Rep 2,357
(A Dane in China) |
12-30-2021, 08:03 PM | #36 | ||
Rep 175
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
12-30-2021, 08:05 PM | #37 |
Rep 2,357
CSV problem solved!
Using CSVed to edit which is great
(A Dane in China) |
Uni-Rapide71.00 |
06-25-2022, 03:36 AM | #38 | |
Rep 1,010
Is that the actual numbers from the dyno ? what's that 64 peak torque unit ? why no torque parameter showing 860 NM ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
06-25-2022, 04:16 AM | #39 |
Rep 1,454
This seems very accurate. I always suspected I was in the ~530awhp range.
Daw Turbo on E40, stock timing (10.5 - 11 degrees). 27-28 psi.
2022 CT4-V Blackwing 6-speed
OzBMR574.50 talontdone174.50 |
02-02-2024, 10:15 PM | #41 |
Rep 1,457
Great thread. I just set mine up. I used Virtual Dyno with my 335is and I'm happy I came across this.
I have the Doc Race 6266BB flex fuel tuned on DI only. Attached with 2 of my recent logs. Last edited by B58; 02-02-2024 at 10:22 PM.. |
