02-18-2014, 11:35 AM | #23 |
Rep 883
Yes. A remedy is pending.
02-18-2014, 12:30 PM | #24 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Cool - thanks for the info. Too bad they didn't catch the issue before releasing them...
02-18-2014, 01:24 PM | #25 | |
Rep 883
Anyone else installing these things yet?
02-18-2014, 01:37 PM | #26 |
Rep 886
What was the problem exactly and what was the remedy?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
02-20-2014, 09:49 AM | #27 |
Rep 349
Ideas on how to get the ID of springs w/o taking them out? I've got the M-perf suspension.
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
02-20-2014, 12:27 PM | #28 | |
558
Rep 1,477
Drives: 335i
Here's an online converter to automate the math...
02-26-2014, 08:18 PM | #29 |
Rep 210
I'd love to get an update on these camber plates. I have new Motion Control coilovers in the box waiting to go on once the damn snow stops in Chicago and when I know there is a well sorted camber plate. Do we know what the "remedy" is?
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 |
02-26-2014, 09:26 PM | #30 |
558
Rep 1,477
Drives: 335i
They did a slight redesign, and the new "street" version of the plates (with full suspension travel range retained, and apparently with the noise issue addressed) should be out in a couple weeks.
02-27-2014, 12:07 AM | #31 |
Rep 36
With more caster are you able to feel bumps and tire grip transmitted through the steering wheel? I can't feel it at all with the stock setup. Everyone blames EPS for this, but I've always wondered if it was just a lack of caster.
02-28-2014, 06:54 PM | #32 |
Rep 210
I'm not a suspension expert but I suspect the minimal feel you are describing has less to do with caster and more to do with an overall soft suspension. Camber plates, when properly set, should increase grip on corning but not necessarily feel unless you move to a firmer suspension.
02-28-2014, 07:21 PM | #33 | |
558
Rep 1,477
Drives: 335i
The effects are all positive.
03-22-2014, 07:23 AM | #34 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
So basically I will need these? I have my 335 lowered on H&R super sports with AG f310 20x9 and 20x10.5
04-05-2014, 08:18 PM | #36 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
GC is still in the redesign process on these-hopefully they'll get something out the door sooner rather than later
05-12-2014, 04:48 PM | #38 |
Rep 573
Talked with them a few weeks ago - they're close on the "Street" plates
Street meaning for std spring diameter, fixed spring perch |
05-12-2014, 09:34 PM | #39 |
558
Rep 1,477
Drives: 335i
I spoke to them this afternoon - they said still a few weeks out.
08-29-2014, 07:20 PM | #40 |
Rep 586
I got the "Street" plates installed today and I am getting this clunk noise...I would have to call and find out. Just my guess though, it sounds like bearing moving around.
G05 - M Performance roof spoiler
08-29-2014, 07:54 PM | #41 | |
558
Rep 1,477
Drives: 335i
Please keep us posted on what you find out regarding this clunk.
08-29-2014, 08:05 PM | #42 |
Rep 1,084
08-29-2014, 08:07 PM | #43 |
Rep 586
Sounds like this is very normal on the ground control plates with spherical bearings...
08-29-2014, 08:16 PM | #44 |
Rep 586
This is new version, "Street" plate, Item is called CCPF30STREET.
