08-01-2021, 11:41 AM | #1 |
Rep 572
Exhaust cooler has broken whilst towing the caravan to Bridgewater.
Can anyone recommend any indies around the area? Anybody know a rough repair cost? Need it repairing as we have days out booked. I'm frightened to use it now. I'm assuming it can damage other things if I carry on using it due to the loss of pressure? Item no 1 i think Any help appreciated. Last edited by 3-GT; 08-01-2021 at 11:48 AM.. |
08-01-2021, 07:00 PM | #2 |
Rep 8,485
AFAIK the corrugated section of pipe is integral to the EGR cooler - you may need to replace the entire EGR cooler unit.
In the meantime, as an emergency fix, I'd get some exhaust repair 'putty' or similar from Halfords or a motor spares shop. There's bound to be one nearby. A hairline crack would just make the cats bit smelly but if the pipe has sheared it's potentially a lot riskier (exhaust gas being very hot could damage other components).
3-GT333.00 |
08-01-2021, 08:24 PM | #3 |
Rep 572
Ye it does look like a complete unit unfortunately. An expensive one at that.
I'm thinking of maybe going down the EGR delete route now - blanked off and coded out. I've been trying to think of some sort of temporary fix. I'm thinking now of getting a steel scourer/wire wool, twisting strands together, cover in exhaust putty, wrap it around the split area and clamping with a jubilee clip. Hopefully that will stop a lot of the leakage. Luckily I only had a few miles left when I noticed something was off. |
08-02-2021, 12:30 AM | #4 |
Rep 1,049
Drives: F31 320D Xdrive Msport+
Assuming you were towing within the maximum towing weight guidelines/tolerances.
How long ago did you have the recalled EGR replacement because you could have had a faulty part fitted if has failed like that. Worth checking because it was done within the last two years all parts have a two year warranty from fit date if done by BMW so you would probably only have to cover the labour costs. Or If you have an extended original or AUC warranty you will just have to cover the excess amount if you have one, regardless of part fit date.
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
08-02-2021, 01:51 AM | #5 | |
Rep 1,239
As others have said, its trash sadly, id be very careful running it, you really risk of fire... I would personally take it up with BMW, like goat has said has it had a recall? Although its the EGV valves that normally get replaced the cooler might of been damaged or disturbed when the work was carried out. |
08-02-2021, 07:53 AM | #7 |
Rep 8,485
Correct. 2 years warranty.
08-02-2021, 07:55 AM | #8 | |
Rep 8,485
You'd need to check where they insert the blaming plate though - no use if it's after the split in the pipe.
08-02-2021, 02:40 PM | #9 |
Rep 572
Thanks for the help guys.
I've managed to bodge it with exhaust putty, holts exhaust bandage repair then a jubilee clip. So far it looks to be holding well, will be keeping a close eye on it. Drove to and from Weston super mare. Doesn't seem to be leaking much. Thanks for the recommendation Watsey, will give them a ring in the morning and ask. The car is a 65 plate 320d with a B47 engine. I've owned it for two years, bought from a main dealer. Never had a recall done I've also checked if it's due one. Car was towing well within limits. Caravan fully laden weight of 1235kg vs car capability of 1600kg. |
10-18-2021, 10:03 AM | #11 |
Rep 572
I thought I'd update this.
I managed to nurse the car home with the bodge. Once I got home I ordered and fitted a blanking plug to close off the port in the exhaust manifold until it can be fixed, this obviously threw a EML. I had two options, get it coded and keep the blanking plug in place, or stick it into the dealership and hope BMW grant a goodwill. As the car was due a service I took option two. So a bit of background, the car is a 65 plate 46000 miles was bought from a main dealer (a different one than I use) with full main dealer service history. In the end there was no cost to me for the repair, they even replaced the intake pipe below that had melted slightly, although it only looked to be cosmetic to me when I spotted it. Good result. |
