BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Please help identify wire color coding for fuel rail pressure sensorHey, These wires
      09-18-2021, 10:43 AM   #1
cxmplex
Drives: 2018 340i GT
Hey,
These wires are color coded. Can someone identify the order from right to left or left to right? I'm wiring a pigtail ATM to replace my connector that plugs into the fuel rail pressure sensor.
Here's an image of the wires and their colors, you could probably take a look at your own car and compare.
View post on imgur.com
I believe the order is as shown from left to right. Black/blue, blue/black, yellow. I'd like to know for sure though before I clip them and then wire them with the pigtail.
EDIT I tried black/blue, blue/black and yellow and got a short code, so that's not the order. Blue/black black/blue yellow?
2018 f34 b58
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E40 Mix Stage 2+ Tune | FX-150 HPFP
      09-18-2021, 10:45 AM   #2
cxmplex
FYI if anyone is curious this is the module 2 harness.
      09-18-2021, 12:40 PM   #3
cxmplex
Correct order from left to right is Blue/Black, Black/Blue, Yellow. For the HPFP QCV sensor, it's White, Red. You'll know if you did it incorrectly because it will cause a lot of other codes to appear related to shorts.
