10-02-2017, 04:22 AM | #23 |
Rep 15,858
High speed driving is where the bi-turbo engines really do excel. The engine choice debate has existed since the first 30d & 35d models have been around. Many (including myself) feeling we didn't see much difference in typical UK driving. Yes better at both the bottom and top end, not being in dispute. A forum member who was driving one of the first E60 535d models, much of the time in Germany, commented on how the real benefits were outside UK speed limits. The harder pull at speeds above 100mph, marked the real difference between a 530d and 535d, speeds we just don't use on public roads over here.
Soul_Glo13347.00 |
10-02-2017, 04:31 AM | #25 |
Rep 13,043
Drives: BMW M340I G20
Yes the 8 speed auto makes a great job of masking engines that are not as good as they could be. The 2.0d with the manual is a pig. But very nice with the auto.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
Soul_Glo13347.00 |
10-02-2017, 04:32 AM | #26 | |
Rep 922
Like I said before, I'm glad I bought this car, because otherwise I would have been like "if only I had got the 335d", and it would bug me. I have it out of my system, next time I am sticking only to an sDrive model. If it will be possible to buy a x35d in sDrive then I may consider it, otherwise x30d with sDrive.
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
10-02-2017, 05:34 AM | #28 |
Rep 922
For me, I felt a difference after the remap, across from very slow to very effin fast
Soul_Glo13347.00 |
10-02-2017, 05:43 AM | #29 | |
Rep 3,967
Besides it will improve performance in It's weaker range like 30 -70mph for example and stop a well remapped sdrive 330d pulling away from you a little A stock f30 335d can barely pull on my remapped 320d 80 -110kph .. they really are weak for the power and overall performance of the car in that range, ..a remap fixes that though |
Soul_Glo13347.00 |
10-02-2017, 06:30 AM | #30 |
Rep 1,846
The thing is the x35d will make max boost at pretty much at any RPM (well above 1200RPM IIRC) so initial acceleration will be quicker that's the point of the turbo setup as well as good low down and high up performance, the 330d will need time to spool (not that its slow) and will die off earlier.
I'd love to see the drive train loss figures as its been banded about on here, between RWD and 4WD - in reality its only a couple of percent which translatea to not massive power deficit. In all honesty I'd be more than happy with a remapped 330d, but i think my next car will be some sort of performance hybrid. |
Soul_Glo13347.00 |
10-02-2017, 06:45 AM | #31 | |
Rep 3,967
This gives a rough idea.. http://www.zeperfs.com/en/duel5992-5613.htm |
10-02-2017, 06:48 AM | #32 | |
Rep 1,846
10-02-2017, 07:24 AM | #33 | |
Rep 15,858
Take the directly comparable 330d RWD vs. 330d xDrive, and expand the in-gear increments to 50 - 112mph. Very clear the weight, drivetrain and parasitic losses are not insignificant, xDrive "as a package" adds 2.3 seconds. Drivetrain losses are not fixed, a percentage, or linear, it's a most complex and misunderstood subject. Steady state losses have little bearing on the losses while under (hard) acceleration. |
10-02-2017, 07:35 AM | #34 |
Rep 6,945
Despite liking the 30d, I'm surprised by the suggestion on this thread that the performance difference is narrow. It doesn't feel like that.
ACS indicate that the 330d sDrive takes 14.9 seconds from 80-180km/h versus 11.8 seconds for the 335d. Quite a difference. Admittedly this includes a small element over 100mph http://preisliste.ac-schnitzer.de/ac...01&ID_NR=11645 http://preisliste.ac-schnitzer.de/ac...00&ID_NR=10315 |
10-02-2017, 07:36 AM | #35 | |
Rep 1,846
I agree (varying factors like tyres bearing etc) it's a rough estimate but it's the best rough estimate you'll get based on rpm/speed unless we take the engine out and bench dyno it However I believe that the xdrive can transfer power from f/r but still has connections/losses? In black and white a x35d is faster but not by a great margin and as the op found out in real terms. I wanted a 4wd because I'm self employed and if I don't go to work I don't get paid ha. Last edited by Ajs_435d; 10-02-2017 at 07:42 AM.. |
10-02-2017, 07:44 AM | #36 |
Rep 15,858
When we talk about wheel horse power vs. engine horse power, are we calculating it under acceleration, or at a steady state? An engine at peak power, (or any other power output for that matter) holding a theoretical road speed, has got 'x' amount of drivetrain losses, which can give a WHP for that particular condition. Calculating acceleration losses is another thing altogether. The more 'stuff' you have to accelerate, (extra diff, transfer box, driveshafts, etc.), the greater the losses. The harder the pull, the more friction, windage, etc.
10-02-2017, 07:49 AM | #37 | |
Rep 1,846
Enjoying this thread makes my lunch break more interesting haha. |
10-02-2017, 08:36 AM | #38 | |
Rep 15,858
What I see in the context of real world driving, and many have commented on this over the years, the 35d engines can appear a little underwhelming. Stretch the working envelope and the 35d engines show more of a performance difference. All made more complex by BMW going xDrive 'only' on the 35d. Blunted the typical UK 'real world' performance differences, compared to the 330d RWD. As to drivetrain losses, all kinds of numbers are banded about. As you know, even dyno testing is not an exact science. Only a separate engine dyno (as you mention) can really get a baseline figure, to start any meaningful calculations. Even then it is limited to one set of conditions, would take a lot of specific testing to generate/plot graphs over a range of operating conditions. |
Ajs_435d354.50 |
10-02-2017, 09:20 AM | #39 |
Rep 922
Definitely an interesting topic. Thanks for the knowledgeable inputs.
10-02-2017, 11:05 AM | #40 | |
Rep 3,967
http://www.zeperfs.com/en/duel5992-6195.htm 330d sdrive 13.6 335d xdrive 12.6 |
10-02-2017, 12:13 PM | #41 | |
Rep 6,945
10-02-2017, 12:26 PM | #42 | |
Rep 3,967
The average varified performance figures on the link I provided are .. * Measures (at real speed) by the following car magazines : Auto Motor & Sport, Sport Auto |
10-03-2017, 03:29 AM | #44 |
Rep 25,114
Not sure if this has been added but back in the day when I chose 335d BMW support made it cheaper per month on PCP than a 330D so that was that.
My car made front page of Bimmerpost
