BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Non runflat tyre pressure
      09-30-2017, 12:10 PM   #1
Welsh springer
Drives: F32 LCI
Hi guys
After some advice what is the recommended or best advised tyres pressures for non RFT
Tyres I am running are
225 x 45x 18 XL 95
255 x 40 x 18 XL 99
I have Nokian WR A4 tyres ready for the winter and not exactly sure what pressures to run.
Any help appreciated
      09-30-2017, 12:59 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Originally Posted by Welsh springer View Post
Hi guys
225 x 45x 18 XL 95
255 x 40 x 18 XL 99
Are the winter tyres you have ready, the same spec as the tyres you are currently running? If so, then try the same pressures, as air pressure carries the weight, not the stiffer RFT sidewalls.
If not the same spec, is there a similar spec referenced on the door shut placard, if so, run as recommended, tweak to suit use.
Remember if you use an XL tyre, you may (according to load rating) need to adjust to a higher pressure to carry the maximum rated axle loads. (XL are load rated at 2.9bar, not 2.5bar as standard tyres).
