01-15-2019, 03:35 PM | #419 |
Rep 243
Hi. Thanks for your tool! I removed Esys, the premium launcher, reinstalled again and then applied the Hack. When trying to do coding I keep getting 'please enter correct pin' and I'm sure I've entered the correct pin as during the launcher setup.
What should I do? I already reinstalled Esys, launcher and hack twice.. EDIT: got it to work, apparently it wasn't necessary to go to that menu. Coding worked fine. Thanks! |
01-16-2019, 07:45 AM | #420 | |
Rep 274
To answer your question about changing the installation date of E-sys by script, I would have to look into that to see if that's possible. However, I would have to be sure that the culprit is actually the installation date, instead of the creation/change date of E-sys' installation folder(s) for example. Would you like to be my guinea pig and do a test to see what happens when we change E-sys' folder dates to the present on your system? I can provide you with a script. The worst case scenario is that you would have to reinstall E-sys again with a predated system clock. Cheers, Tony |
01-16-2019, 07:51 AM | #421 | |
Rep 274
Cheers, Tony |
01-16-2019, 07:59 AM | #422 | |
Rep 274
Cheers, Tony |
01-16-2019, 08:05 AM | #423 | |
Rep 274
Open Windows File Explorer and go to "shell:UsersFilesFolder" (without the quotes). Find the subfolder called Documents and do a right click -> Properties. Under the Locations tab, what is the path for this folder? |
01-16-2019, 08:38 AM | #424 | |
Rep 1,141
More than happy to test things. As I said, this laptop is only used for diagnostics, so I can do anything to it without fear of breaking other stuff. Even a fresh install of Win10 wouldn't be an issue. Ian. |
01-16-2019, 10:08 AM | #425 | ||||
Rep 45
01-18-2019, 05:18 AM | #426 |
Rep 68
Hey Toni,
I fail since the beginning. I am stuck with the priviledges. Cannot run the script because of elevated access. But actually I run it as administrator while I log in as Administrator. What am I missing? Thanks |
01-18-2019, 05:09 PM | #427 | |
Rep 274
Cheers, Tony |
01-18-2019, 06:39 PM | #428 |
Rep 274
01-19-2019, 08:24 AM | #429 | |
Rep 5
Just a minor fix. I'm using the latest Windows Home Insider Preview build and your 1.7.0 script was not working. Had to change just one line: Code:
rem Change execution path of this batch file to current folder cd "%~dp0" Code:
rem Change execution path of this batch file to current folder cd /d "%~dp0" |
01-21-2019, 03:22 PM | #433 | |
Rep 26
This is the order that I installed things: E-Sys Launcher Premium Rearm 1.7.0 vcredist_x64 jre-7u80-windows-x64 E-Sys_Setup_3_28_1_b46869 then deleted c:/Data/psdzdata dir and copy a content of psdzdata inside of v4.12.41_PSdZDATA_Lite to c:/Data/ ESysLauncherPremiumSetup_2.8.2_Build_155 After I run Laucher Premium as an admin, nothing happens at all. The wheel spins for few seconds like is doing something and then nothing happens. Please help! |
01-21-2019, 03:58 PM | #434 | |
Rep 274
My guess is you've got a relocated Documents folder. Read a few posts back to see how to check and either resolve the relocation, or adjust my script to point to the relocated instead of the default folder. Cheers, Tony |
01-21-2019, 04:00 PM | #435 | |
Rep 26
It looks like I had to re-run Launcher Premium 3-4 times and then it worked without issues.
When the E-sys started, I am greeted with the screen that is in the attachment (please see attached pic). What should I do on this screen? Just accept defaults or something else? Quote:
01-22-2019, 06:28 AM | #436 |
Rep 74
Drives: BMW 330i G20 2019 Sportline
Hi Tony,
Iīve run your script as described but cannot open esys launcher 2.8.2. I moved the date back to Nov 2018, then run the script as admin and the launcher is still asking for pin and confirmation. There is no msg about date manipulation. I am running windows 10. Any ideas? Do I have to run the launcher as admin as well? Thanks in advance |
01-22-2019, 07:13 AM | #437 |
Rep 172
Drives: 2015 328i
Did you try just entering any pin?
01-22-2019, 07:27 AM | #439 |
Rep 74
01-22-2019, 07:30 AM | #440 |
Rep 172
Drives: 2015 328i
Last times I used esys with the date reset it always asked for a pin. I just enter 1234 and continue.
clock, date, esys, launcher, premium |
