BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Intake manifold removal I'm screwed
      11-01-2020, 04:11 PM   #1
Pussiwillow
Drives: Alpine white 2014 335i msport
Well removing the intake bolts pulled threads from the head on a cold engine
REMOVING them
I don't even know wtf to do now
      11-01-2020, 04:13 PM   #2
Pussiwillow
Can I cry
Is that acceptable lol
      11-01-2020, 04:15 PM   #3
Pussiwillow
How tho
Glizzy3.00
      11-01-2020, 04:23 PM   #4
Pussiwillow
Anyone know the stud size
I'm gonna go to a hardware store and see if I can run a stud down there after cleaning the threads up and loctite and use a nut
      11-01-2020, 06:13 PM   #5
Pussiwillow
Plot twist
I was able to catch the remaining threads and got it torque down; however gonna order a stud and epoxy/loctite it in place or the like when I have a chance
      11-01-2020, 06:46 PM   #6
5w20
Drives: Bmw 435i
Originally Posted by Pussiwillow View Post
Plot twist
If I recall correctly they looked like a M8x1.25 thread pitch.
      11-01-2020, 07:33 PM   #7
Pussiwillow
I found the studs on fcp euro
Ordered 2 of the stud and nuts
Yeeyee
AmuroRay246.00
      11-01-2020, 07:51 PM   #8
jbiswurm
Drives: F30 335i msport 6mt
Interested in what job you were trying to do when this fiasco ensued...
sspade1898.50
      11-01-2020, 07:54 PM   #9
Pussiwillow
Oil filter housing gasket
You have to remove intake manifold enough to shift it over and out a few inches to get to a tough bolt on the housing.
Bolt was stiff the entire time, nothing I could do but pull it at that point; looks to have seized to the threads of the head oddly
Not cross threaded, as there's 6 remaining threads or so in the head and bolt still perfect
Freak thing I guess
Sucks but I'll replace it with a stud like the remaining ones have; and it'll be good
Just irritated
It's buttoned you, priming the water pump and oil pump as we speak
Super easy job, just lame a freak thing happened :/
      11-01-2020, 08:30 PM   #10
FastF30
FastF30's Avatar
484
only thing I can think of is a HeliCoil... Hopefully your fix will hold...
      11-01-2020, 08:32 PM   #11
Pussiwillow
It'll be ok
Anyone know how to kill fuel or ignition on these cars
Having a hell of a time removing the injector connectors
      11-01-2020, 08:59 PM   #12
Pussiwillow
Removed the coils
Priming now
      11-01-2020, 10:02 PM   #13
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
It'll be ok
Pull the fuse for the injectors.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      12-01-2020, 08:42 PM   #14
HH1815
Drives: '15 BMW 335i 6mt
It'll be ok
It'll be ok
anyone know where the fuse is? i couldn't find it when I did the ofhg
15 335i x-drive 6MT.
Catless DP, CP, Intake, BM3 STG1 93
      12-01-2020, 11:55 PM   #15
Pussiwillow
It'll be ok
It'll be ok
I couldn't find it either, I pulled my coil connectors and just primed it
Probably washed the walls down with fuel but it's better than not priming it I guess ha
1k miles she's doing good
AmuroRay246.00
      12-02-2020, 05:37 AM   #16
LA1Z24
Drives: 2014 435i M Sport
In the shop, I would clean the aluminum off those studs, and re-use them.
      12-02-2020, 09:06 AM   #17
Pussiwillow
That's what I did as a temporary fix
I ordered studs and chased the threads and good to go
