03-25-2019, 04:58 PM | #67 |
1296
Rep 3,532
Got mine last week and replaced it over the weekend. My old one looked brand new still with no issues. Still went ahead and replaced it but I feel like i wasted a few dollars lol... oh well, cant hurt.
03-27-2019, 07:20 AM | #68 |
Rep 176
03-29-2019, 01:38 AM | #69 |
Wing Chun Shifter Speed
36
Rep 181
barely touched mine and it snapped off. glad I took care of it now rather than later.
Current:F82 M4 | BM3 Stg 2 MultiMap FF | AA EL Midpipe + DP's | KW HAS
Totaled:F30 335i | ER Chargepipe | ER Down-Pipe | Wagner Intercooler | BMS Intake | Meisterschaft Exhaust | MHD BEF JB4 Map 3 / 30% e85 / 50/50 Meth |
AZ330FZL46.50 |
03-29-2019, 06:18 AM | #70 |
Rep 12
This was the second thing to fail on me, after my charge pipe. Thankfully also the last! The darned hose also broke around the connecting elbow there. Much like everyone else here it broke on me within the 4X,XXX miles area.Ran me about $80 at the dealership for a new hose plus a big bottle of coolant.
04-12-2019, 10:11 AM | #71 |
Rep 8
I must have snapped mine when installing a new intake. Was a little ticked at the time but I guess it is better than it failing while driving. Cost me $50 in parts plus a drive 40 miles away in a snowstorm since the closer BMW dealership was out of the part. Worst part was having to drive the wife's minivan to get it.
04-12-2019, 10:12 AM | #72 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
That would suck.
04-12-2019, 10:52 PM | #73 |
BMW CCA Member
488
Rep 808
Pretty much every plastic part under the hood is pretty brittle. My local BMW shop said the turbos just cook/heat cycle everything.
On a related note, I'm at 57k miles and just replaced my charge pipe. The pipe was fine but the PVC-style hoses that plug on/off just disintegrated when trying to remove them. It's a $90 part and none of the dealers stock it, so it's a solid week from order to getting it in hand. |
04-15-2019, 03:10 AM | #74 |
Rep 373
I'm not sure if this needs it own thread but i feel this should be another PSA the PCV vent hose that connects from the tappet cover to the turbo inlet pipe has broken on my car. This is the 3rd car with similar mileage in my area that i have see broken. car has 46000miles (75000km)
part number for the hose (f series n55 not e series) 11127599753
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
04-19-2019, 01:49 AM | #75 |
Rep 222
Guys, if i just swap this hose for new one, i dont have to worry about bleeding the system after? Is there usually some coolant in the hose or is it empty when not running? Thank you
04-19-2019, 02:44 AM | #76 |
Rep 762
if you are just replacing it as a preventative measure, you should not have to bleed the system. I would let someone else chime in with 100% confirmation because I'm 90% sure..
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
JuiceQuadre54.00 |
04-19-2019, 03:01 AM | #77 |
Rep 331
Drives: 2012 335i Sedan Sport Line
Was making some updates to my 80k mile N55 and was preparing to remove the bumper and barely touched the coolant line and it snapped right off. Then tried to gently remove the other side and it crumbled in my hand. Once I got the replacement it was super easy to install. If you are higher mileage this is a must do.
07-15-2019, 03:35 PM | #78 |
Rep 135
Excellent PSA. Mine broke right around the time you posted this, but on the other end at the expansion tank. It just so happened to break right after I spent 30 min trying to teach the girlfriend stick (a lot of stalls and jerky starts), so I suspect that may have been the reason the already brittle hose finally broke off. Who knows.
I was at around 56k miles (2013 335i). |
07-30-2019, 11:28 PM | #79 |
Rep 5
Nice to see this is a common issue for these cars once they hit a certain mileage. Mine just broke this evening when checking the seal on the turbo outlet pipe for a boost leak. Leaned my arm on the end that connects to the coolant reservoir and it just snapped. Didn't even put that much pressure on it. Thankfully the car had been sitting for a few hours with the hood open so the engine was quite cool when it happened. Guess I know what I'm doing in the morning.
I'm at about 73k miles (2015 335I)
'15 335i xDrive M sport - BM3 Stage 1, Injen Intake
07-31-2019, 12:10 PM | #80 |
Rep 1,499
You don't need to bleed the system is replaced as preventative maintenance. I replaced mine as a precaution, didn't bleed and had no issues.
JuiceQuadre54.00 |
07-31-2019, 12:34 PM | #81 |
Rep 123
Drives: 2022 BMW M340i xDrive
Just changed mine over weekend as a preventative measure. Didn't notice anything wrong with my current one, but after replacing I did notice what looked like some hairline cracking near the underside of the fitting....so I'm glad that I did. I am at 58k on my 2014. Easy replacement, took less than 5 min. No bleed necessary when I did it.
12-30-2019, 11:25 PM | #82 |
Rep 148
Drives: F30 335i sport line
Garage List 2012 BMW F30 335i S ... [0.00]
2006 BMW 330xi [0.00] 2007 Toyota FJ Cruiser [0.00] 2003 MINI cooper S [0.00] |
Here is a video of the part replacement
12-31-2019, 12:33 PM | #83 |
Rep 260
Threads like these are SO valuable! Thank you so much for taking the time to share this with us. I'll check it on my car. Preventative maintenance is worth it's weight in gold.
Thank you thank you! |
01-01-2020, 01:30 AM | #84 |
Rep 373
Add me to this list. Dealer replaced my thermostat that was stuck open under warranty the other week - and I noticed they also replaced this reservoir coolant hose, so that's good news as I'm at 58k.
01-01-2020, 02:04 PM | #85 | |
Rep 3,946
04-19-2020, 09:04 PM | #86 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
What MeesyGarage BMW said....great cinematography.
Of course you have to bleed the coolant system after replacing the hose, since the cracked hose let air into the system. When you replace the hose more air gets in. Doesn't matter if the coolant reservoir has fluid in it. Coolant System bleed procedure is automated and simple. If the coolant level goes down after the bleed and you have too top off the coolant in the reservoir, you have to bleed it again. Best price on the hose is at Pelican Parts and BMW Parts Pros. FCP will replace it free every time it breaks again with a lifetime warranty. Get a gallon of BMW Blue coolant and distilled water. I would by 2 hoses. Install one and keep the second for the future. The hose goes under the front grommet for your air intake. Every time you or a mechanic touches the air intake warn them about this brittle hose. Check it for a break or leak when you are done. You know this hose is cracked, when there is steam coming from the driver's side front of your hood or kidney grilles. You will see liquid spray on the top of the engine near the driver's side hood latch. There will be no leaks under the engine near the radiator. A trail of liquid flowing on the ground behind the car is common. You might not get a low coolant or overheating warning at first, unless you are on the highway doing the speed limit. Cheers |
04-22-2020, 12:27 PM | #87 |
Rep 146
I replaced mine today on a 2014 335i with 30k miles, nearly all long highway trips. Nothing was wrong with the old one I took off and I couldn’t even break it after trying multiple times so I suspect high mileage is the main issue. There is no need to flush the coolant system if yours isn’t cracked because it’s a return line and won’t get flushed with that flush procedure listed above. If you look at the side that goes into the coolant reservoir, it goes in at a level above the Max fill level, meaning even if you flushed it manually with coolant, one end is exposed to air above the max fill level and would empty itself out regardless. Only reason to flush is if you let air into the system with a broken hose.
04-22-2020, 12:32 PM | #88 |
Rep 422
Drives: F87 M2 DCT, F15 X5
Just happened to me with 95k miles on the car. Perhaps this could be stickied somewhere for some "standard" maintenance when buying a used F30.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
