07-02-2020, 11:17 AM | #23 | ||
Rep 7,602
IAT - The IATs already start at a high value, almost 30F over ambient. Were you at a stop light or in traffic right before this? That could explain why they started so high. The significant rise is typical of stock IC, which is why i always recommend a IC even for stage 1. High IATs in themselves do not necessarily cause damage, but significantly increase the likelihood of knock and timing being pulled, especially if the octane of your fuel isnt great. High IATs are not good for power. Boost - generally OK, but boost control for the first half of the pull is a bit erratic/wavy. So its WGDC. timing - looks surprisingly good for the really high IATs, especially if this is a 91 tune. If one cylinder is always getting timing pulled it suggests there might be a plug issue or a coil issue. Could be as simple as the gap is different than the rest by a few thousandths. Throttle angle - seems to feed in slowly rather than opening all at once. Don't usually see that in BM3 logs, at least not stage 2, but doesnt necessarily mean there is an issue. Also, MAF - do you have an intake, air scoop, or anything not stock on intake? The reading is pretty erratic. |
07-02-2020, 01:19 PM | #24 | |||
Rep 101
Timing - do I need to have the spark plugs taken out and gap checked again or is this difference in cyl 3 ok? will read the threads on proper plug gaps Maf - stock intake thank you for your help! Overall seems pretty good from my understanding and not much to worry about other then my IAT |
07-02-2020, 01:30 PM | #25 | |
Rep 7,602
Timing - I mean honestly you can just pull plug 3 and look at it and check gap... I dont think you said - OEM plugs? Mileage? Gap? Its not a major issue, you can keep running it as it is without danger or anything, but if you are in pursuit of perfect timing and especially if the plugs are already old anyways, it might be time to check that one or change them all. MAF - strange the readings are all over the place then, but i see that on quite a few logs... no idea why . Mine are just a smooth curve. Yup i think you were on point. |
07-24-2020, 12:47 PM | #26 |
Rep 7,602
Giving this thread a bump since it is a bit buried now and it might get some new eyes on it
For anyone new - read the OP https://f30.bimmerpost.com/forums/sh....php?t=1732327 Last edited by thejeremyman9; 07-24-2020 at 01:01 PM.. |
09-18-2020, 06:07 PM | #27 |
Rep 7,602
Free bump!
Just updated the first post with some additional details (in blue) and helpful links for logging with JB4. |
kitchener2.00 thatBimmerBloke872.50 |
10-28-2020, 04:05 AM | #28 |
Rep 474
First of all thank you for the detailed information. Please let me know if my logs okay.
2013 n55 8at PWG catless downpipe and charge pipe. Stage 1 ACN Bootmod3 with 107k miles Just changed the oem spark plugs to oem https://www.bootmod3.net/log?id=5f8b...0b43676892a3ef
J. D. Cordier
10-28-2020, 10:30 AM | #29 | |
Rep 7,602
Having said that nothing looks 'wrong' with your log. Timing isnt very good, especially for already being on ACN map, but its likely just fuel quality and IATs... Boost also falls off up top but thats typical for PWG. Your IATs are high and you have a huge IAT increase over the pull even though its pretty short because you are on stock IC, which is why i tell everyone to get an IC if you are going to be tuning your car at all. Get a 'proper' 4th gear log or two and post it in another thread if you want to follow up. |
jcordier160.50 |
10-29-2020, 03:06 AM | #30 | ||
Rep 474
J. D. Cordier
thejeremyman94362.00 |
12-02-2020, 08:27 AM | #32 | |
Rep 169
Amazing post! This is the kind of thing forums should be about more than bickering over who has the dopest CF lip bro!
I took notes on a little 5.5 in x 8.5 in ledger pad on my desk as I read through this. Walked away with about 9 pages of notes! I also learned a good bit about MHD and it makes me feel even more confident going this route as opposed to some other options I considered. Quote:
I liked how you included an example data log in the Manifold Boost v. Target Boost section. Did you thought about included similar examples for these other parameters that should be reviewed?
2015 F30 335i | Glacier Silver Metallic ///M Sport | Journal
2014 E84 X1 sDrive28i Last edited by silvrbreez; 12-02-2020 at 10:25 AM.. |
12-02-2020, 08:33 PM | #33 | |
Rep 7,602
I included logs in a couple sections to show specific concepts, yeah. Although i didnt explicitily include a log in each section, realsitically you can look at any of my logs posted up there and use them as examples when checking the different parameters. If you feel like one specific section needs a log or two as an example to better understand, let me know. |
silvrbreez217.00 |
12-03-2020, 11:33 AM | #34 |
Rep 55
Much needed in the community and for myself as well, cheers.
silvrbreez217.00 |
12-09-2020, 09:03 AM | #35 |
Rep 169
Did three pulls this morning. It was pretty cold out put I wanted to start doing some logs before installing FMIC & CP. This guide was incredibly helpful. The notes you added on 12/2 about throttle position vs. pedal % on a stock tune was helpful and lines up spot on.
Now, I have everything except VANOS parameters turned on in MHD but I still don't seem to have quite the parameters being track as you do on some of the runs you shared. Specifically, I don't see where I can select or am reporting values for HPFP, torque limits, and timing correction (to name a few). I wonder if those become available as parameters once you start flashing? Sorry if I missed that someone in the original post.
2014 E84 X1 sDrive28i |
12-09-2020, 11:19 AM | #36 | |
Rep 7,602
silvrbreez217.00 |
12-11-2020, 04:00 PM | #38 |
Rep 722
I was about to post my BM3 logs to the forum for feedback and came across this post. It’s absolutely fantastic!!! I’ve spent the last hour using the post as a reference guide to read my logs which I discovered look normal but I did see where traction control was kicking in.
Silverlining_m21733.00 thejeremyman94362.00 |
12-11-2020, 06:43 PM | #39 | |
Rep 7,602
04-16-2021, 08:12 AM | #40 |
Rep 21
2021 bump! Great info from OP, thanks! Curious if MHD monitor license is my best bet for logging or if there is a better value option out there? (Currently on MHD Stage 2+ tune)
04-16-2021, 09:43 AM | #41 | |
Rep 7,602
And you should just get the MHD monitor license. Well worth the money and other cheaper/free options will not have MHD "proprietary" logging parameters. |
04-16-2021, 09:46 AM | #42 |
Rep 21
Just purchased it thanks to your advice. Will do some logs next week and see how it goes. Thanks again
04-26-2021, 10:14 PM | #43 |
Rep 4,632
thejeremyman9
You mentioned something interesting that many few people have talked bout on any forums on the N55, The DME targets more timing when there is less boost. Why is that? I have seen that happen randomly on some logs from run to run on a friends car. Where sometimes boost is high and timing low, but another log, boost is a bit lower and timing is higher?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
04-27-2021, 11:32 AM | #44 | |
Rep 7,602
Different tuners use different approaches (i.e. more timing vs more boost), but for our engines we are pretty much always operating at the limit of how much timing you can run, which is why everyone's logs have timing corrections. Depending on how sensitive your ECU is to pulling timing it may be safer to run a little more boost and not tune at the edge of knock, especially on pump gas. But again for our cars the DMEs are very good at self correcting timing, even if your target is pretty aggressive for your boost and octane. There's also a lot of other considerations to choosing the right balance of timing and boost, like how it affects EGTs, how good your IAT control is (high IATs and a lot of timing is a recipe for knock), etc. But in the basic sense you want to run as much timing as you safely can for your boost level to extract maximum power. When you see people get tuned on the dyno its fairly common for the tuner to keep adding timing until the car stops picking up power, then dial it back (a little or a lot depending on how much safety margin they want). |
5soko333.00 |
