08-18-2022, 05:59 PM | #287 |
Rep 134
08-18-2022, 07:26 PM | #289 |
Rep 134
Ok, not sure I can find an adjustable (or fixed!) in the UK guaranteed to fit (apart from £168 from Motech)
08-20-2022, 07:25 AM | #290 |
Rep 86
SirBiggles41.00 |
08-20-2022, 05:02 PM | #291 | |
Rep 134
08-20-2022, 06:36 PM | #292 |
Rep 666
is it worth it to get the F80/F82 brace? There are two parts, the rear aluminum and the front carbon fiber front strut brace.
i wonder if getting the rear aluminum brace only would accomplish what the aftermarket front strut brace does, or has to get the whole package (aluminum and the carbon fiber) |
08-20-2022, 07:49 PM | #293 | |
Rep 86
SirBiggles41.00 |
08-22-2022, 10:36 AM | #294 |
Rep 134
08-23-2022, 04:32 PM | #295 | |
Rep 7,607
sdbwisc66.00 |
08-24-2022, 07:32 AM | #297 | |
Rep 383
Honestly the difference you will see with these driving on the street is minimal at best. You really should be doing some for of motorsport before adding this. Especially because it makes access under the engine cover a PIA, if you choose to keep it on (and I would if you're driving on the street)
https://f30.bimmerpost.com/forums/sh...0&postcount=20 Retrofitting it isn't a simple part swap, as far as I understand. At minimum it requires new strut top-hats (or camber plates designed to accept it). A transverse brace would still probably have some effect on the chassis in f80 car's - although I'm sure it would be debatable if it NEEDED it. One reason BMW may avoid it is for serviceability reasons. Judging from the deflection in my weicher’s brace mounting plates it’s more significant than you think. Last edited by SuperLomi; 08-24-2022 at 07:47 AM.. |
08-24-2022, 01:44 PM | #298 |
Rep 7,607
I'm not saying the bar doesnt make a difference. I installed one, and i think it made a reasonable difference.
08-24-2022, 03:37 PM | #299 | |
Rep 5,392
https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 INSTALLATION VIDEO Photo shows mine, which I had powdercoated black to match my engine compartment. |
SirBiggles41.00 |
08-24-2022, 03:40 PM | #300 |
Rep 883
Didn’t notice any mention of the Racing Dynamics strut brace.
Here’s one installed on my N55 F36. I’m very pleased with it. More noticeable than I’d suspected it would be.. I’ve experimented with this brace unloaded, and with two levels of pre-loading. I‘ve ended up just running it unloaded - it’s just simpler. You can pre-load pretty much all braces. The pre-loading doesn’t matter much if it’s tension or compression pre-loading. It’s just adding a small amount of initial force to take the cross bar off neutral - you’re not trying to alter your alignment or trying to add camber with the strut brace. If you want to try preloading the brace, just install it with the car on jackstands or up in the air via the front center jack point. Only partially unweighted, where the tires haven’t lifted fully yet is a good ‘low’ pre-load level point (and an easily repeatable setting). Slop in a brace means there’s bad fit or design/fab problems. If the brace’s attachments to the strut top are solid & sound (materially and structurally able to transfer the forces into/from across the strut top mounts), and the cross bar’s fit adjustment when tightened-up makes it rigid, and all’s torqued proper, there should be no mechanical slop. There shouldn’t be any ‘lag’ or ‘softness’ to the brace’s ability to transfer loads at the transition point between tension and compression. BMW doesn’t use any pre-load with their brace designs. The strut brace is most effective operating in tension (while you’re turning), keeping both tower tops connected so they operate more as one vs. independently. The cross bar only typically transitions into heavy compression when encountering suspension jolts from rapid over-compression (hitting potholes, road bumps, curbing, jumps, etc.). Ideally it’d be a straight line connection, but the engine’s in the way. So braces bend up and over or even wrap around the front. These indirect paths can still function great, but doing so requires a beefier/stiffer construction of their connecting cross bars. If the attachment fittings or the cross bar are too wimpy, and can’t transfer the forces without deformation, the brace is just decorative. . |
SirBiggles41.00 Tommi_Mav65.50 |
08-26-2022, 07:25 PM | #301 |
Rep 134
Ok cool thanks guys. So basically; should be adjustable to tighten bolts to reduce slop, which could be more present with a fixed bar.
I think this is the adjustable Wiechers steel bar available in the UK https://www.mstyle.co.uk/wiechers-st...31-models.html |
08-27-2022, 10:53 AM | #302 | |
Rep 5,392
UPDATE: Here is the one that I have... https://www.mstyle.co.uk/wiechers-ra...0-and-f31.html |
08-27-2022, 03:43 PM | #303 |
Rep 1,425
Just installed the Wiecher's carbon fiber. The aesthetics exceeded my expectations compared to photos.
My vehicle is a F31 with the B46 engine. No clearance issues. Mine is post-LCI, so I installed a total of 6 new M8 (3 per side) with 30Nm + 90 degree torque for each (part #31306869931; https://www.fcpeuro.com/products/bmw...mw-31306862826). I can appreciate a noticeable improvement in steering tightness. Surprisingly, I also feel it has slightly reduced the steering-to-wheel slop I'm looking to reduce with monoballs.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
alohasurftoad3081.50 johnung4528.00 |
08-27-2022, 05:01 PM | #304 |
Rep 666
this is the one i m talking about. i think it doesn't exists on F3X, only F80/F82
08-27-2022, 05:04 PM | #305 | |
Rep 666
08-27-2022, 06:39 PM | #306 | |
Rep 1,425
I considered doing this, but ultimately decided the gains weren't likely substantial enough to justify the install efforts and extra cost.
2017 X5M - Current
08-27-2022, 07:11 PM | #307 |
Rep 666
Yes, I don’t think i will pay for the whole set, that’s over $1000, too much for a brace, but i am thinking just the aluminum part (in that thread it would be stage 1 and 2 only)
08-30-2022, 07:01 AM | #308 | ||
Rep 134
'16 BMW 440i GC AT | '17 LCI BMW M240i AT | '94 Mazda MX5 | '04 BMW M3 E46 6MT | '07 Seat Lean FR 2.0 | '01 Seat Ibiza Sport 1.6 | '94 Nissan Sunny LX 1.4 |
