03-20-2014, 04:51 AM | #67 |
Rep 40,774
If you have KAFAS module, you should be able to add 5AC and VO code FEM_BODY to get HBA.
The problem as you wrote is you have no switch to toggle HBA On and Off. As a workaround, in F10 FRM (Front Light Module), you could code FRM => FLA_AUTO_AKTIV => aktiv, which would make HBA on as the default.
03-20-2014, 09:57 AM | #68 | |
Rep 84
Fluffy Russian СaT
08-09-2014, 03:05 PM | #69 |
Rep 188
So I have my car, I have all the assistants except for HBA, I have LDW, SLI, FCW, blind spot detection and all the parking cameras.
If I code the auto on for HBA, doesn't it require a controller/motor to move the beams out of the oncoming traffic view? I know my beams can go up and down, but I'm I'm sure they are able to go left and right. |
08-09-2014, 11:21 PM | #70 | |
Rep 40,774
You are thinking of the Glare Free High Beams, which requires HBA and AHL, with the light motors being part of the Adaptive Head Light function.
08-10-2014, 05:49 AM | #71 |
Rep 188
Gotcha, I was under the impression that the HBA was the same as AHL.
I was thinking of wiring a my own switch for HBA since I don't have it on the stalk that I would add near the other FCW, LDW and ABSD buttons, if that doesn't work I may just buy the assembly that has the stalk button... My next question would be: Is AHL a documented retrofit? Do I need to change the whole lights assembly or can I just bolt on the motors and controllers complete with wiring and then coding? |
08-10-2014, 08:53 AM | #72 |
Rep 40,774
It's a big job and a lot of money. See this post:
http://f30.bimmerpost.com/forums/sho...d.php?t=938803
08-10-2014, 06:17 PM | #73 | |
Rep 188
08-14-2014, 01:10 PM | #74 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
So my 335 has LDW.....but i guess its turned off? Im not sure how to turn it on. I have the Blind spot assist thing off cuz thats annoying as hell, are the two related?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
08-14-2014, 01:30 PM | #75 |
Rep 40,774
Active Blind Spot Detection uses Radar Sensors, and Lane Departure Warning uses Camera, either FLA or KAFAS. The only thing they have in common is they both vibrate the steering wheel.
08-14-2014, 02:33 PM | #76 |
Rep 67
Like Shawn said, they're not really related, but if you do have LDW the switch to turn it on is by your left knee, below the headlight control.
2014 335xi | Luxury | Technology | Imperial Blue Metallic | Saddle Brown Dakota | Driver Assist Plus | Cold Weather | Active Cruise Control | Harman Kardon
08-20-2014, 12:50 PM | #77 |
515
Rep 1,063
Yea I noticed the switch, but it still never does anything? i guess its broken?
08-20-2014, 01:20 PM | #78 | |
Rep 297
so it's possible this was done at the dealer and that is why you never can "feel" it working... To see if its turned on (besides at the switch), in your dash between your speed and RPM, you will see two vertical yellow lines. When your driving, you will see triangles pointing towards the lines if the road has a yellow or white stripe on one side, and a dotted or solid line on the other... |
08-21-2014, 01:38 PM | #79 | |
515
Rep 1,063
08-21-2014, 01:44 PM | #80 | |
Rep 297
I think you can also retro fit the switch - I remember seeing somebody posting this in here or one of the forums... on your cluster, remember they don't make a cluster for each car, its one size fits all- and if the sun hits your dash right, you will see all the little indicators, etc that you may or may not have available. |
12-23-2014, 10:05 AM | #81 |
Rep 20
Speed limit display
Hello everyone.
I Bought a BMW F30 (316D sport), and I order optional packages such as Navigation system Professional, Visibility package, Active Security package (Lane change warning system, Driving Assistant, camera on the back of rear view mirror) but i did not add the Speed limit display(£220)! I was wondering if its possible to add any FSC Code in order to add the Speed limit display? |
12-23-2014, 10:12 AM | #82 | |
Rep 40,774
12-23-2014, 03:03 PM | #83 |
Rep 20
01-20-2015, 04:48 PM | #84 | |
Rep 6
Indeed there is no such "ANZEIGEVARIANTE" FDL code in KAFAS2 anymore, but there is a renamed one (sometimes it's an advantage to be able to translate German into English ): KAFAS2 => 3020 TLC_CODING, 0B => DISPLAY_VARIANT This was set here to value "04" (= "lanes_if_system_is_on,_arrows_side_dependant_ on_ availability") by default anyway, but you may want to check it. BUT: That does not set LDW on by default (it's even unclear what it really does). If you want to set LDW on by default in an F3x car with KAFAS2 ('cause you don't have the dashboard switch), set the following: KAFAS2 => 3020 TLC_CODING, 0B => TLC_START_VERSION => 01 (you need to change the hex value itself here!) This will lead to an "UNKNOWN" value, but don't be confused, it's correct. The default is "PIA_mode = 03". The full set of all required codings for a plain and stand-alone working LDW (and also of all unnecessary and even harmful ones imposed by VO coding of 5AD to an F3x with KAFAS2 which need to be removed) can be found in these Bimmerfest posts: HTH. |
02-13-2015, 05:37 PM | #86 |
Rep 40,774
It means if a car has Lane Departure Warning (LDW) it has the requisite hardware for Speed Limit Info (SLI) as they both use the same Camera / ECU. But again, without a 7E FSC Enabling Code, you cannot enable it.
02-13-2015, 06:00 PM | #87 |
Rep 604
04-27-2015, 03:09 AM | #88 |
Rep 72
Can this code be bought and any idea how much it is?
