10-27-2018, 12:40 PM | #67 |
Rep 479
This may sound dumb, but I tightened some of them, loosened them and re tightened to ensure the 17ft lbs. Could that have impacted it?
10-29-2018, 11:44 AM | #68 | |
Rep 1,572
Should not have any impact. I guess its possible that one of the sparkplug washers may have failed (I've never experienced it) and some fuel vapor is venting. Pull the ignition coils off and check inside with a light to see if you see any fuel pooling or a strong gas odor in a particular plug. |
10-31-2018, 09:12 PM | #69 |
Rep 3
This was one of the most organized and informative posts I've seen, so props to that. Very thankful for the info (my turn for plugs and coils), but have a bit of an off topic question.
My 1er's valvetronic motor has failed, and I've searched the internet with the hopes of finding a good DIY. So, any links, advice, etc., would be greatly appreciated. Thanks, John |
11-03-2018, 05:05 PM | #70 | |
Rep 1,572
Hope this is what you are looking for: https://www.fluidmotorunion.com/bmw-...shaft-failure/ https://bmwtechnician.com/2017/03/27...etronic-motor/ Unfortunately, it doesn't appear that Bentley has a Manual for your car. |
11-04-2018, 12:56 PM | #71 |
Rep 1,934
It was a great day in NE to do this job ! Thanks for the write ups guys. Looks like it was also a good 60K on the OEM plugs. Replaced with the Bosh equivalent part# ending in S
12-12-2018, 11:27 AM | #72 | |
Rep 25
I've retorqued all six plugs, no difference it seems. Should I be tightening to spec with a torque wrench using a universal joint attached to the extension bar? I heard that may throw off the actual torque values. It's driving me crazy, sure would love everyone's opinions on this. |
01-24-2019, 12:21 PM | #73 | |
Rep 258
Seriously, I’d like to know. Two people having the same problem is worrisome. |
02-14-2019, 08:54 AM | #74 |
Rep 832
Drives: 2019 G01 X3
Do you guys use any dielectric grease when replacing the spark plugs?
03-01-2019, 11:43 PM | #75 |
Rep 1,827
AFAIK, it's not recommended.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
03-01-2019, 11:44 PM | #76 |
Rep 1,827
Nice. I'm sitting on a new set, waiting for my next day off to swap em. Did you change the gap at all or just go with how they came?
03-02-2019, 07:41 AM | #77 | |
Rep 1,934
.... For now
jh_f301307.00 |
04-16-2020, 01:52 PM | #79 |
Rep 7,607
Sorry to bump a little bit of an older thread here but wanted to confirm the approach people are using with respect to using a universal joint. After seeing a few threads recently about cracking the spark plug insulators (and other consequences of doing so), i am wondering if people are using the tools as follows:
3/8 torque wrench --> extension --> U joint --> thin walled socket. This seems to be what the manual is stating to do, see attached photo. |
04-16-2020, 01:59 PM | #80 |
not good, but bad
333
Rep 361
Yep, check out my spark plug guide DIY. Just go to my username .com and you'll see it.
John in VA988.50 |
04-16-2020, 02:26 PM | #81 | |
Rep 7,607
Just to confirm, you torqued them with the ujoint in place as i described? Were you not concerned with the Ujoint affecting torque spec? |
Operator Mo64.50 |
04-16-2020, 04:23 PM | #82 |
not good, but bad
333
Rep 361
Correct. I torqued to spec then gave it a tiny smidge more. No problems in 2 changes.
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
Operator Mo64.50 |
