11-04-2019, 09:10 PM | #1 |
Rep 100
BMW Brake Torque Specifications
Hi,
I own a 2016 435i xDrive and am looking to replace the brake discs. If you have a service manual for the F32, and willing to lend me the values for job, please let me know. Thanks! |
11-04-2019, 10:47 PM | #2 | |
Rep 5,390
I highly recommend upgrading the four brake rotor hold screws to stainless steel so that they will never rust and seize. Both Turner & ECS sell them for ~$15/set of four. Also recommend Zimmermann rotors. High quality German rotors better than OEM because they are zinc coated against rust. Very reasonably priced. Best replacement street pad is Hawk 5.0. Superior in every way to stock pads. More reasonably priced than inferior pads that others taught. Replace brake fluid every two years for safety. At same time upgrade to StopTech stainless steel brake lines for ~$106/set of four. There are other stainless lines that cost more. Much more solid brake pedal feel. Hope this helps! |
mgc999115.00 |
11-05-2019, 09:20 PM | #4 |
Rep 5,390
Here are some Hawk 5.0 brake pad part numbers that I forgot to attach
11-06-2019, 07:35 PM | #5 | |
Rep 100
11-07-2019, 05:27 PM | #6 | ||
Rep 5,390
The first line of the torque specs is just the single screw that holds the brake rotor onto the hub. It's the part that I said likes to rust on so replace it with a stainless steel screw. I'll see if I can find diagrams to illustrate the other two. |
mgc999115.00 |
11-07-2019, 05:38 PM | #7 | |||
Rep 5,390
11-07-2019, 07:37 PM | #8 | |
Rep 100
- Mike |
11-07-2019, 08:43 PM | #9 | ||
Rep 5,390
mgc999115.00 |
11-07-2019, 08:53 PM | #10 |
Rep 100
Tags |
#435i, #brakes, #f32, #xdrive |
