02-04-2021, 10:57 AM | #23 | |
1296
Rep 3,533
02-04-2021, 11:04 AM | #24 | |
Rep 7,607
It's only up to you to change gears when you engage manual mode. |
F20_M135i100.50 |
02-04-2021, 11:07 AM | #25 | |
Rep 7,607
Maybe fun if you wanted to flash it and hit the canyons for 15 mins or something? |
02-04-2021, 05:42 PM | #26 | ||
1296
Rep 3,533
02-08-2021, 10:13 PM | #27 |
Rep 551
- URGENT -
Hello, following a bad manipulation by removing options I flashed STAGE 1, when I noticed my error, I (re) flashed STAGE 2 which had been in place for more than 600 kilometers QUESTION: Am I obliged to respect the 80 kms of course before the tests in driving mode SPORT and heavy load on the gearbox? NB: Nice bullshit because I have to test the car today, so if the answer is: YES = I must / I will drive 80 kilometers before going to drop them off at the garage ... |
02-09-2021, 12:24 AM | #28 | |
Rep 7,607
F20_M135i100.50 |
02-23-2021, 05:51 AM | #30 |
Rep 551
I have set up for 3 days the option to start in 2nd gear on my F20 PWG, I do not know if this really helps the transmission as it indicates in their manual, but the starts are less "violent" and this 'is more pleasant.
I am still worried about the stress (pressure) of oil made because I have never drained my car transmission and it at 85,000 kms Do you think there is a risk? |
02-23-2021, 06:39 AM | #31 | |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
n55david1295.50 |
02-23-2021, 07:48 AM | #32 |
Rep 944
In a manual with dry clutch it would certainly lead to more slip and greater wear. However in an auto with torque converter the slip doesn't do that type of damage, and with 8 speeds (and a short first gear) it makes some sense to move off in 2nd most of the time.
What I don't like about it is the hesitation that stepping on the gas brings on, as the car takes a moment to decide to change down to 1st and achieve that before moving off. This moment feels like an eternity when all you are after is quick movement from rest. I've got over it by selecting Sport gearshift at junctions to preselect 1st to get over this hesitation. |
02-23-2021, 11:26 AM | #33 | ||
Rep 7,607
Also, ZF guidelines are 150,000km for the pan and fluid change now. Of course, shorter interval if you drive harder than average. But 85,000km isn't bad. Maybe 100,000km (which is what it used to be) for a tuned car. See attachment. Quote:
F20_M135i100.50 |
02-23-2021, 02:41 PM | #34 |
1296
Rep 3,533
all I know if any of you 2nd gear launch fbo stock turbo guys wanna race from a dig let me know min $500 a race.
02-26-2021, 02:28 PM | #35 |
Rep 551
Well... I'm sorry to insist but I find the report passages with the Xhp Flashtool software extremely slow
Even with stage 3. Maybe it's just my vehicle (f20 pwg) but I have more this feeling of waste of time than of gain Recently I put the gear changes back to the stock point, because I hoped that this slowness came from that, but no ... Nothing helps, I click on the pallets and almost 1.5 seconds later, it goes (above or below) it is incredibly slow. I remember that when I drove this vehicle for the first time, changing the paddles gears told me: "wow! It's really very fast!" The problem is that I have reset (supposedly) original with XHP FLASHTOOL, but in reality I think this is not my file, but a generic of a random F20 no matter what it is either 125i or 118 diesel, they must offer the same maps, which is not the case with BMW M for sure! Here I am with a slow and perfectible gearbox, whereas I had a much more efficient /// MPerf prepared gearbox. Again and again the same conclusion: I'm disappointed (and angry with myself for having given in to this gadget) nb: the readjustment of the gearbox is a solution of last resort that I have not yet done, which seems rather suitable when you encounter concerns of hesitation in changing gears, or of suspicious movement of gears, this n fortunately not my case, but I'm still stuck with RBT Tuning |
02-26-2021, 03:02 PM | #36 | |
Rep 7,607
If you are talking about the delay between pulling a paddle to change gears up or down and the actual gearchange happening, are you in comfort mode / D trans (shifter to the right)? This is a known side effect of XHP. You must be in sport+ and S trans (shifter to left) to get instant/fastest paddle response. Regardless of which stage you flash, you will get a big delay between paddle and gear change if you are a comfort/D. Yes, this can mean even slower than stock response in the same mode. But the response will definitely be faster in sport+/S. Also, i dont think when you flash back to stock it uses a generic map. I am pretty sure it uses your stock map file. On your final point, i dont know if by "readjustment" you mean resetting adaptations, but you don't want to reset transmission adaptations. |
F20_M135i100.50 |
02-26-2021, 11:20 PM | #37 |
Rep 551
Hello thejeremyman9, That's exactly it; in everyday life, I am not in SPORT mode with lever pulled to the left, I am in ECO mode / be in COMFORT mode, with the reflex when I have to enter a fast lane to pull on the paddle to avoid screaming the engine, and there ... A disaster, I frankly have the impression of having a LADA or DACIA.
The worst is when I have to overtake, but I don't want to do KD, then I lower the gear with the paddle at the wheel to try to pass quickly = inefficient. If this lag is "known" I do not even understand that the users are then not honest with themselves <= XHP FLASHTOOL is only a software for SPORT mode ONLY The other modes are very poorly managed, whether manual, automatic, rpm for overpass points, downshifts This software should not be recommended for any user of an M Performance or BMW Motorsport car. The advantages are 0, except maybe for wild runs and circuit races, but there again, Xhp FLASHTOOL does not specify it anywhere. Make no mistake, I am especially angry with myself for having given in to this so-called "+ paying" which does nothing! Maybe just the display of reports on the dashboard ... it's funny but that's it ... |
02-27-2021, 01:34 PM | #38 | |
Rep 7,607
So I guess i am just not sure why you find the need to use the paddles in D/comfort. You can shift with your right foot as needed. |
02-28-2021, 09:25 AM | #39 |
Rep 551
My way of driving? lol !! So I am buying a product that must dictate my way of doing ??
Is such an obvious and penalizing lag normal? and should not be mentioned? I am not arguing, I am giving my point of view and you are giving yours, but I do not have to agree to what you say. Your vision of the software comes from your mapping of the gearbox and the engine of your car. Let's be honest, this product does not add anything to Sportive or GT range vehicles except maybe, in SPORT mode only. 1 F20 M135i Xdrive series vehicle: I tried = I fired him, and I take this opportunity to give my point of view. Thank you and good day |
02-28-2021, 10:13 AM | #40 | |
Rep 1,119
02-28-2021, 10:58 AM | #41 |
Rep 551
Hello,
I have tried stock retrieval and don't want to be slanderous, but I'm pretty sure what Xhp Flash says about "replacing original mapping" isn't correct. The gears still don't shift like before, or am I fixing too much? I don't understand what you describe as "just removing the torque limits" Xhp Stage 1 mapping removes "latency" from gear changes to pallets? |
02-28-2021, 11:02 AM | #42 | |
1296
Rep 3,533
I'm taking a screen shot of these last few replies for some groups I'm in. Pure gold. I give you my thanks my good sir.
02-28-2021, 11:04 AM | #43 | |
1296
Rep 3,533
