11-05-2016, 12:28 PM | #1 |
Rep 1,052
Drives: 2022 M8cs
2015 435xi track car planning
I bought the 435 this spring after no longer imagining the M4 as my dream car. Test driving an M6 changed that. Not so satisfied with the 435 so I acquired My dream car last week and the 435 will be my track car.
I am no longer racing motorcycles and turned my race bike back to street but need to get back to the track. Looking at Area 27 in Oliver ATM but Mission is closest. So, to track the 435 at Mission I know I don't need much power but the N55 needs more power down low. If you know Mission, you also know one needs a good brake setup and a better handling car. This is what I've done to the 435 thus far. Looking for suggestions: FBO with JB4 and retained MPE exhaust I already have MPE aerodynamics which may be moot anyways M4 carbon fiber strut brace which tightens up struts and reduces body roll...theoretically All other body reinforcements as on M4. Extension strut rods, etc. lightened reinforcing plates, etc. Winter projects needing advice: Change out rotors with drilled/slotted two piece (RacingBrake?) Change out front and rear pads (Pagid?) See how MP brakes perform and go to 6-pot if the MPEs don't perform Change out suspension but no idea what to do as it's xDrive (trade for bone stock 440 RWD 6MT?...start over) Camber plates? Lighten the car up a bit 18 inch wheels? Track tires of some sort I may be a squid and get the Electronic steering wheel. Thoughts? I am a noob to car racing but have my SCCBC novice in a '08 325. |
11-05-2016, 11:23 PM | #2 | |
Zooombie attaaack!!
136
Rep 1,179
11-05-2016, 11:56 PM | #3 | |
Rep 1,052
Drives: 2022 M8cs
I wasn't seeking guidance on how to use my cars but thanks anyways for the thoughtful insight. |
11-06-2016, 10:22 PM | #4 |
Zooombie attaaack!!
136
Rep 1,179
Apparently you do need guidance on how to use your cars or you wouldn't be trying to set up a 435i xDrive for track racing.
11-07-2016, 12:33 AM | #5 |
Rep 1,052
Drives: 2022 M8cs
one word...
counseling |
11-07-2016, 12:47 AM | #6 | ||||
Zooombie attaaack!!
136
Rep 1,179
Honest advice for you...either trade for M235/M240 or a Cayman. You're going to spend so much time and money setting up a touring car it just makes no sense whatsoever. The 435 xDrive will eat up tires and brakes like crazy, overheat, and just not be much fun out there as every time you upgrade something you'll find a new weak point... |
11-07-2016, 10:24 AM | #7 |
Rep 1,052
Drives: 2022 M8cs
I see every forum has its trolls.
11-07-2016, 10:43 AM | #8 |
Zooombie attaaack!!
136
Rep 1,179
Guy with 435i xDrive: I want to make it a track car. I already have an M6 and I'm going to tell you all about it, but don't you dare suggest I just use that. I want to completely change the suspension, change the wheels/tires, add power, and change a bunch of parts to make it stiffer. Or, maybe I should just buy a 440i?
You have said you are willing to buy an entirely new car for this. I gave you advice and you don't like it. Sorry you bought the wrong car to track. |
11-07-2016, 12:17 PM | #9 |
Rep 1,052
Drives: 2022 M8cs
If you were actually able to read and didn't get bogged down being an @zz, you'd have realized it wasnt bought for the track. You should have understood that from your dissection of the origins post. But your preference was to go low-rent. Don't all of sudden get high and mighty about offering help.
11-07-2016, 01:16 PM | #10 | |
Zooombie attaaack!!
136
Rep 1,179
I don't get what you want. You want to know how to make it a track car? Change the tires, the brakes, the suspension, add an oil cooler, add a bigger intercooler. I would personally start there before adding power. You also suggested changing the car, and if you are willing to do that just buy a decent track car of which I gave you a few suggestions. We see posts like this all the time. People asking advice then rejecting it because they know what they want but not enough to not be soliciting advice... There is plenty of information on the forum of people who have already done what you are asking. Edit: Also, that's why nobody else is chiming in! They see the title and think it's a bad idea. |
11-08-2016, 02:58 PM | #11 |
Rep 1,052
Drives: 2022 M8cs
Then point to the posts instead of your initial approach. Go back and review your original reply and then wonder why you got the answer that you rightly deserved. Enough then...you already discredited yourself.
11-08-2016, 03:43 PM | #12 |
Zooombie attaaack!!
136
Rep 1,179
you sure showed me...search for yourself it's super easy
12-22-2016, 11:44 AM | #13 |
Rep 100
My best advice is also M235/M240, Cayman, or similar car for dedicated track use. By the time you put the necessary money in your 435 you will still have been better off getting a better suited track car.
12-23-2016, 10:22 AM | #14 |
Rep 1,052
Drives: 2022 M8cs
Thanks. I'll be using the 435 for the track which will be just fine. After talking with some local guys that have tried their hand at xdrives on this track, it's fine to just run what I have. All it needs for lapping at this track is wheels, tires and brake pads. I won't be racing it with the club.
12-23-2016, 08:38 PM | #15 |
Rep 100
hey hey get out of here with your reasonable suggestion...he was asking for advice as long as it conforms strictly with what he had already decided to do
12-23-2016, 10:30 PM | #16 |
Rep 1,052
Drives: 2022 M8cs
12-30-2016, 07:55 PM | #17 |
Rep 1,052
Drives: 2022 M8cs
When you don't know what to do with the xdrive, the only suggestion is replace it with something else. Lol. The first troll drives an Altima. There's a difference between racing and lapping on a track. You trolls have likely never been on a track but you like your smack hey?
12-30-2016, 10:16 PM | #18 | |
Rep 3,926
12-31-2016, 01:16 AM | #19 | |
Rep 100
12-31-2016, 03:11 PM | #20 |
Rep 1,052
Drives: 2022 M8cs
12-31-2016, 03:12 PM | #21 |
Rep 1,052
Drives: 2022 M8cs
