11-15-2019, 09:11 AM | #331 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
kern4174446.50 SteelBlue4670.00 |
11-15-2019, 09:43 AM | #332 |
Rep 3,876
@floridaorange
Great. So when you find the answer to that (in Bimmerpost or elsewhere), let me know please: "And I definitely want to know how to flash back to stock xdrive, not x-deletes version of x-drive, I never thought of that."
11-17-2019, 04:56 AM | #333 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
Somewhere I probably still have the dealership training white paper from xDrive introduction.
M have different bias, 0:100, FWD are 100:0. everything else is. 40:60. Period. Programming schmogamming. The actual code might vary but the results being output are identical despite hardware differences. 40:60. And if I remember my fact sheet, that changes over 100 mph to more like 20:80 for improved stability. And it works pretty fine. You aren’t saving hardly any power by adjusting the bias to 0:100, you are still powering all the extra rotating mass... just using the ground to do it indirectly instead of the driveshaft. I could see this being useful for burnout contests and Dyno pulls. And that’s about it. I thought I’d hate the awd, but it’s pretty good. I think the old viscous coupling was a bit smoother to engage. I’m sure with a less laggy turbo you could take advantage to really power thru the corners by applying power early and tightening the corner to let the car 4 wheel drift slightly under power on the way out. That’s how we did it on the “good old days” of viscous couplings and torsens |
Skyhigh1889.50 floridaorange10152.50 |
11-17-2019, 02:45 PM | #334 | |
Rep 776
Little bit different than flashing via their software. |
11-17-2019, 03:46 PM | #335 |
Rep 3,876
The desire is to be able to do it easily yourself.
11-18-2019, 07:37 AM | #337 |
Rep 2,639
Need to be parked, and on ignition mode.
It's faster now if you use MHD black wifi adapter, it's compatible with xDelete and XHP now.
11-18-2019, 07:37 AM | #338 | |
Rep 2,639
There's a considerable difference when I went xDelete.
11-23-2019, 06:15 PM | #339 |
Rep 609
Drives: F31 330D xDrive MPPK ACS
And what is the safety critical software you are publishing via the App Store?
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) |
Skyhigh1889.50 |
11-23-2019, 06:20 PM | #340 | |
poopycat
266
Rep 791
I kinda see where you are going in 1 direction there, but my direction is an absolute. Seems fun, if you are out of warranty. |
11-23-2019, 06:33 PM | #341 |
Rep 1,934
Ok Boomer.
11-24-2019, 03:44 AM | #342 | ||
Rep 3,876
But I was more thinking that I would like to be driving my own vehicle's native, stock XDrive software when in XDrive, not XDelete's dump of some other vehicle's (potentially different/outdated) load. In other words (irrespective of warranty considerations) I (and this is just me) would definitely prefer to be riding stock when not using the XDelete RWD.
11-24-2019, 03:56 AM | #343 |
Rep 609
This is your problem. I have built and owned old cars. That says nothing about my age.
11-24-2019, 10:30 AM | #344 | |
Cheapskate
4447
Rep 4,993
Ok. But that has no bearing on a new option that has been proven across platforms. |
Pittcrew34.00 |
11-26-2019, 05:06 AM | #345 |
Rep 565
I am a bit confused.
Most of the folks on here are US / Canada and have petrol 35i engines with xdrive have done the x delete. You are turning off the traction control and getting lots of wheel spin back end moving out and this is of course a safety issue. Over here BMW will only sell the 335d in xdrive in am led to believe because they think the torque is too much for rwd only from a safety perspectve. Over here in the UK we have lots of 340i engines running only rwd as stock. BMW seem happy to sell these that people can run without the traction control. So I am at a loss why the 335i engines from an xdrive with xdelete are felt to behave so badly and as they are surely just behaving like a 340i with the traction off that BMW build? The fault to my mind is not removing the x drive but removing the x drive and turning traction off. Maybe I am missing something? |
11-28-2019, 01:04 PM | #346 |
Rep 3,876
This is peculiar. Would the following preclude flashing of XDelete as well?
https://www.2addicts.com/forums/show....php?t=1603379 Has anyone with a late SW version / update done recently attempted to or successfully done XDelete? (the thread is for a different model, but the same i-Step codes appear on our vehicles) There are very competent and knowing-it-all Software engineers here which I am sure will contribute with the best they have, as they always do.
11-30-2019, 07:57 AM | #347 |
Rep 295
Not a F30 but I've had xDelete on my E90 since it came out about a year ago.
Works great and zero issues. Mostly use the RWD mode but have tried the snow and sport modes. Always keep reverting back to RWD mode. Drives better and less wear/tear on the transfer case, front differential and front drive shafts. I'll turn AWD on for bigger snow storms but that's about it. |
11-30-2019, 07:40 PM | #349 |
Rep 2,670
I'll tell you what - the car turns waay better & my MPG went way up running rwd.
As far as gaining a bunch of HP, not so sure about that. |
11-30-2019, 08:33 PM | #350 |
Rep 1,031
Drives: Like a bat out of hell.
I have a RWD 430i and wish I had AWD... SIGH
antzcrashing1910.00 |
12-01-2019, 11:23 AM | #351 | |
Great Teacher
1086
Rep 1,305
12-06-2019, 08:20 AM | #352 |
Rep 295
If anyone has the pre email login version, do not update it unless you absolutely have to.
They now require an internet connection to authorize the app every couple weeks. Meaning if you have any trouble with google play, login problems or no cell reception, you will not be able to re-flash when needed. Also disable any ability for the app to auto update. They have also blocked older APKs from initializing so once you update, you're SOL. Incredibly stupid. |
