09-16-2020, 02:36 AM | #3719 |
Rep 1,048
09-16-2020, 06:30 AM | #3720 |
Rep 47
Today it is known to use this function together with Today it is known to use this function together with AIRMaTIC STATUD (I think it was the name of the other option)ATUD (I think it was the name of the other option)
09-19-2020, 12:52 PM | #3721 |
Rep 22
Hi everyone. I want to ask members with a wireless carplay dongle, does carplay popup automatically few seconds after the android unit boots.
I am asking because i have an unit with built in carplay, and each time am on the car i need to go to bluetooth settings click to sync my phone then go to z link for carplay. So i am thinking of buying an external dongle if it performs faster. Am on carplay 99% of the time so it’s important for me. Thanks |
09-20-2020, 06:36 PM | #3722 | |
Rep 18
Can you pls reshare the file thanks |
09-21-2020, 09:23 PM | #3723 | |
Rep 71
Gabo
09-22-2020, 09:25 AM | #3724 |
Rep 22
09-23-2020, 06:45 AM | #3725 |
Rep 592
09-23-2020, 08:06 AM | #3727 |
Rep 2,366
Drives: E63 645Ci
Thanks
For that you would have to give up iDrive controller in OEM system, make a custom board for the controller and use it as a keyboard/mouse in Android. So no, not possible if you want to retain any control in OEM. |
09-23-2020, 09:17 AM | #3728 | ||
Rep 551
with the help of tasker i intercepted the MCU lines which stop / pause all media on android side Good luck and good day |
09-24-2020, 02:34 AM | #3729 |
Rep 4
Level control system failure after installing Android
Hi guys. I’ve updated my 2011 cic x5 with one of the systems locally available running android 9. There is however one prominent problem. I’m getting a “Level control system failure” after installing the system. Any help would be appreciated. I think there is some wiring issue that needs to he resolved.
Last edited by Kmerchant; 09-24-2020 at 02:37 AM.. Reason: Addition of error images. |
09-24-2020, 03:14 AM | #3730 | |
Rep 1,048
Everyone with this Android system installed has this message at his error Logs. Kri |
09-24-2020, 09:26 AM | #3731 |
Rep 116
Hello everyone, I have a couple of questions regarding the CarPlay with Android 9 HUs:
1) I connected the bluetooth to the OEM microphone, but every time I receive/make a phone call, it switches to the Android microphone (which has a lower quality) and I need to change it again from the iphone.. Does anyone know how to solve this issue? 2) When I receive/make a call, the volume is much much much lower compared to the music, even if on the audio setting of the Android screen I've set it higher.. Am I the only one with this problem? |
09-24-2020, 11:44 AM | #3732 | |
Rep 4
Regards, K. Merchant |
09-24-2020, 02:05 PM | #3733 | |
Rep 1,048
This can cause multiple ecu`s to produce error codes. Best way is to delet all the entire errorlog and check it after some days again. Kri |
09-25-2020, 01:11 AM | #3734 | |
Rep 4
09-25-2020, 02:52 AM | #3735 | |
Rep 1,048
there is not much that can be made wrong when installing the HU, ignition should at least be off. Kri |
09-25-2020, 03:29 AM | #3736 |
Rep 2,366
Drives: E63 645Ci
Funny you say that... I was rerouting my mod mic cable yesterday and it was getting dark so I had ignition off but my interior lights were on. As soon as I was done and plugged my unit back, screen came up alive. But as quickly as I pressed dome light button, CAN messages started circulating through the car network and screen went immediately off.
09-25-2020, 03:37 AM | #3737 |
Rep 399
Since the Head Unit is powered as soon as the doors are unlocked, there will be a CAN error when you disconnect the HU from the harness, unless you disconnect the battery first. But as Kri says, we all get this, just clear the errors you have and check again after a few days. You should not get CAN errors again then. I have no errors at all on my E87 with Android screen.
09-27-2020, 04:07 AM | #3738 | |
Rep 4
09-27-2020, 02:11 PM | #3739 | |
Rep 1,048
Please show a screenshot of the fault codes after you have cleared them. Kri |
