BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      10-04-2019, 10:03 AM   #111
BPAC306
BPAC306's Avatar
Drives: M240I X
subscribed
M240i xdrive - K&N Drop in, MPE
12.3 @ 108 Stock
      10-04-2019, 11:55 AM   #112
GT500R
Drives: BMW X3M
Originally Posted by OzBMR View Post
Here's another 4th gear run with E30 fuel mix using the MHD Stage 2 95/102 map.
Looking forward to testing this out at the drag strip in the next few weeks. Should better the DervTech tune.
https://datazap.me/u/ozbmr/m140i-mhd...21-22-23-24-25
Why does your car shift so early? My car shifts around 6800 rpm... hmmm
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance
10.84@127.43 / +1912 DA NH Dragway |
10.6@130 Dragy / +820 DA The Streets |
NOW: Tesla Model Y Performance
      10-04-2019, 06:28 PM   #113
BPAC306
BPAC306's Avatar
Drives: M240I X
BM3 Stage 1 93
how does she look?... + MPE and K&N pulled a 3.9 0-60 on the dragy
run#1 http://www.bootmod3.net/log?id=5d97d040ae729b71057f0b83
run#2 http://www.bootmod3.net/log?id=5d97cfffae729b71057f0b82
run#3 http://www.bootmod3.net/log?id=5d97cf68ae729b71057f0b80
and issues with the little knocks on the 2nd run? All in 3rd gear
12.3 @ 108 Stock
kern4174449.50
      10-04-2019, 07:52 PM   #114
GT500R
Drives: BMW X3M
Originally Posted by BPAC306 View Post
BM3 Stage 1 93
how does she look?... stock + MPE and K&N pulled a 3.9 0-60 on the dragy
So stock or BM3 Tune?
      10-04-2019, 07:55 PM   #115
BPAC306
BPAC306's Avatar
Drives: M240I X
BM3 Stage 1 93
Typo. Logs are all bm3 Stage 1
12.3 @ 108 Stock
      10-04-2019, 09:31 PM   #116
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
BM3 Stage 1 93
Nice car and quick Draggy times.
Accelerator pedal is 100% from about 2500 RPM but Load Target only gets to where it should be by about 3000 RPM, then overshoots, boost spikes up to nearly 19PSI.
I'd expect a Stage 1 tune to have Load Target to be at around 170 as soon as the pedal was 100%, hit 16 - 17 PSI and hold that pretty well flat through to redline. Apart from that the first run looks pretty good. I think it would get a nicer Timing transition and ramp without the boost spike.
What fuel are you using?
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
      10-04-2019, 11:11 PM   #117
BPAC306
BPAC306's Avatar
Drives: M240I X
BM3 Stage 1 93
Always 93 octane
12.3 @ 108 Stock
      10-05-2019, 12:49 AM   #118
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
I always have the car in Sport+ Manual shifting when logging and manually shift about 6300 - 6500 RPM
      10-05-2019, 03:52 AM   #119
kern417
Cheapskate
4450
BM3 Stage 1 93
yep i see the same thing.
Also, what version are you running? i used to get boost spikes, but v2.0 fixed it for me.
You also have some timing pull on cyl 1. My logs show the same thing. I tried regapping my stock plugs to 0.022" and it helped. You can also try getting fuel from a different gas station to see if the one you used is just lower quality.
      10-05-2019, 06:45 AM   #120
GT500R
Drives: BMW X3M
What’s the advantage to doing that? I log same but once the rpm goes past 6k I flip back to drive them back to Sport on the shifter to let the computer do the shifting.
      10-05-2019, 06:51 AM   #121
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
The fastest gear changes with xHP Stage 3 are in that mode and at the drag strip I've found fastest ET and MPH changing just after 6000RPM with stock turbo.
      10-05-2019, 09:12 AM   #122
BPAC306
BPAC306's Avatar
Drives: M240I X
BM3 Stage 1 93
Running version 2.0
I'll try a different Station and I have new plugs sitting in the counter that need to go in... any issues with that knock?
12.3 @ 108 Stock
      10-05-2019, 09:49 AM   #123
kern417
Cheapskate
4450
Running version 2.0
gapping/swapping plugs will help with that as well. it's likely the knock is causing your timing pull. i had the same thing but after gapping my plugs (and switching to the e30 tune) it's pretty much solved.
i think we have something over cylinder 1 that could be affecting timing. i've read that the pcv is over cylinder 1, so that can affect timing due to blow by. but i need to do more research to see if that's really the case.
      10-06-2019, 09:18 PM   #124
BPAC306
BPAC306's Avatar
Drives: M240I X
Running version 2.0
Staring to get a bit discouraged... my best times equate to my stock best times but picked up 3 mph. Stock time slip and new dragy attached
Another long log. Going through gears
http://www.bootmod3.net/log?id=5d9a24d8c090c61ab1d8996e
12.3 @ 108 Stock
      10-06-2019, 09:38 PM   #125
gabrmdoom
Drives: BMW 340i
I enjoy reading logs and understanding how our cars work, so I thought I'd make a thread where the community can submit logs for feedback. We don't need to lock it down to one tuner since the engine parameters are pretty universal, as long as you have data that you can share on here through your platform, datazap, google sheets, etc. I also want to track baseline parameters so people know what to expect from their tune. The more submissions we get, the more info will be publicly available.
[SIZE="3"]Recommended Logging Method:[/SIZE]
1. Shift to the appropriate gear (8AT Users: Use 4th, 5th, or 6th Gear; 6MT Users: Use 3rd or 4th Gear)
2. Start at 2000-2500rpm
3. Floor it (8AT Users: Don't press the kickdown under the pedal)
4. Stop at 6500-7000rpm
[SIZE="3"]Recommended Logging Parameters:[/SIZE]
Throttle Angle
Engine Speed
Boost Pressure (Requested)
Boost Pressure (Actual)
AFR/Lambda (Requested)
AFR/Lambda (Actual)
Ignition Timing (Requested)
Ignition Timing #1 (Actual)
Ignition Timing #2 (Actual)
Ignition Timing #3 (Actual)
Ignition Timing #4 (Actual)
Ignition Timing #5 (Actual)
Ignition Timing #6 (Actual)
Knock Detected
[SIZE="3"]Things to look for[/SIZE]
Boost more than +/- 2PSI from target
More than 3° timing pull
AFRs increasing from target
I really dont understand much of whats happening in this thread so can someone baby me thru this?
I paid justing whitted (twisted tuning) $425 like 3 months ago for email tune. Im running mhd with jb4 backend flash. As of recently im getting a misfire. I step on the pedal and suddenly an incredibly loud pop occurs and i lose power. I read codes and it says cyl 5 and cyl 2 are misfiring. I changed my plugs before tuning and ive been going back and forth with him increasing boost and such. I dont run meth, and i dont get any of this. I use shell 93 if that means anything and im scared that ive been scammed. Can i forward the whole email list to someone knowledgeable and see if maybe you guys could help? I can provide a misfire log or anything else, please just someone help?
I bought this car like 2 years ago cuz of the supra hype. Someday itll be a 900 awhp beast. Maybe?
      10-06-2019, 09:45 PM   #126
gabrmdoom
Drives: BMW 340i
https://drive.google.com/file/d/1BGD...w?usp=drivesdk
Everyone has access to view this. Forgive my ignorance. This is a 3rd gear WOT pull from about 2800 to 6500 shifting to 4th with a misfire. It constantly happens under load and its very unpredictable. What is the limit for email tunes anyway?
      10-07-2019, 01:29 AM   #127
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
The logged data indicates things are not going well. Have you shared the logs and your concerns with your tuner?
Boost, AFR and Timing is all over the place. Maybe post up on n54tech forums where there's more JB4 MHD BEF experience?
      10-07-2019, 01:30 AM   #128
gabrmdoom
Drives: BMW 340i
Yeah i have and he hasnt been so helpful. Ill sign up for n54tech now. Thanks.
      10-07-2019, 02:07 AM   #129
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
The data in the run doesn't look bad, boost up top is about 16 PSI, AFR's are 12.5 - 12.7, timing looks OK for 93 octane fuel.
If you wanna go faster increase octane and boost (Stage 2) and consider xHP for custom launch control and faster shifts. You should also try shifting manually at 6000 RPM for 3rd and 4th gears.
Do you have access to E85? If so you should try adding some up to about 30% ethanol content, which would increase octane to about 98.
The most recent Draggy shows a 60ft of 1.84 vs 1.76 at the track. 0.1 in the 60ft = 0.2 in the quarter
kern4174449.50
BPAC30689.00
      10-07-2019, 06:57 AM   #130
kern417
Cheapskate
4450
I haven't used draggy but a few things I see
- You ran up hill
- You short shifted second (I'd run out to 7k every time if that's possible)
- Slower 60 ft as mentioned above will hurt your times
- Not sure if draggy compensates for roll out that gives you a better time at the track
I'm just speculating, but a flat road and roll out + better 60' could get you a 12.0.
Logs don't look that bad, just the same timing pull on cyl 1. No knock. Did you swap plugs?
First off - i wouldn't say you've been scammed. You're working with a reputable tuner that has tuned a lot of fast cars. But sometimes things come up, so now it's time to diagnose. Just be thankful you have software that allows you to log and get to the root of the issue.
Things that I see in your log after some formatting
- Timing is very low
- Boost target is very high (20 psi)
- You are overboosting (25+ psi)
- Something weird is happening at 4200-4800rpm, your rpms go up and down and your throttle closes (clutch/tire slip?)
Things to try
- Can you post the datazap link? It'll be easier to translate the log data
- Is there any way to log with higher resolution? Every 1.25s is not enough.
- Is map 6 the right map for a backend flash and no meth? Can you run the backend flash with jb4 in map 0 or completely disconnected?
- Pull your spark plugs and check them. Just because they're new doesn't mean they aren't the issue or at least help indicate what the issue is
      10-07-2019, 01:21 PM   #131
BPAC306
BPAC306's Avatar
Drives: M240I X
Tuner says my octane looks crappy.... how can I tell based on the charts? still need to swap the plugs and maybe find a good shell station.
12.3 @ 108 Stock
      10-08-2019, 01:11 AM   #132
kern417
Cheapskate
4450
Your timing should slowly go up with your engine speed. If there are any dips, that indicates timing pull. Knock is also an indicator that timing is too aggressive for your fuel quality.
What i do when looking for timing issues is hide all of the lines except for engine speed, throttle angle, and igntiong timing #1, #2, etc. It'll be pretty obvious if any of the cylinders are pulling timing. Pretty much all of them will follow the same pattern, then you'll see one cylinder drop below and begin climbing back up.
A little timing pull from time to time isn't a big deal, it just means the car is doing what it's supposed to. But if it's consistent and more than 2-3 *, i'd start looking into ways to fix it.
hybris204.50
