BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
proTUNING Freaks
      03-23-2024, 08:36 PM   #4071
Jay5k
Jay5k's Avatar
88
Drives: 2017 BMW 340i
This is what a bad o2 sensor looks like
https://datazap.me/u/jptsunga/bad-o2...-23-29&solo=29
Car had a rough idle, lean AFR spikes, misfires, and was sputtering.
Replace my plugs and injectors, but the issue was still happening.
Ended up being the o2 sensors. Wanted to share my experience.
Skyhigh1889.50
lpaulodt214.50
      03-24-2024, 02:50 PM   #4072
Krisztian93
Drives: Bmw 540i g30
Hi Im On mgflasher 98 ots map and i constantly have knock also timing correction can some one check my logs? My sparks brand new Ngk
https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=0
      03-24-2024, 04:45 PM   #4073
DieselDuck
DieselDuck's Avatar
86
Drives: BMWB58
You don't have knock ?
You got a few timing corrections but it isn't too bad.
Log looks quite okay.
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
      03-24-2024, 08:28 PM   #4074
Dantesboyz
recovering e36er
Dantesboyz's Avatar
Drives: 2017 M240i Xdrive
Went for a nice drive today
Did a quick E30 log
Shell 93 and Sheetz E85(measures E75) mixed to E32 on my Spool EAC
Right now I'm back on the stock hpfp
Sold the TU pump, DS25-250 on order as of this weekend.
https://datazap.me/u/dantesboyz/sund...7-48&zoom=0-52
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
      03-24-2024, 10:44 PM   #4075
Aplatosz
Drives: 2018 BMW 340i Xdrive
Misfires
Car is on a E50 blend with a DS25, Flowmax turbo, and 50/50 chargepipe WMI 59k miles
Was stopped at a gas station and when turned the car on got a drivetrain malfunction and flashing CEL, read the codes and gave me a few misfire codes on cylinder one, car had a very obvious misfire at idle but not so much once I gave it any gas, on the drive home was able to get a datalog and looked like it was running very very lean but had no timing corrections or knock, went I got home pulled the plugs and they all looked clean and oil free, didn't notice any irregular smoke from the exhuast, and also opened up the oil cap while it was running to check for smoking which it wasn't. Changed out plugs and still have the same issues, was thinking the lean afr could have messed something up but not showing any symptoms of a blown engine, thinking something to do with injectors may be the issue, datalog of that small pull is below.
https://www.bootmod3.net/log?id=65fb...b463058d0f1d7c
      03-25-2024, 03:15 PM   #4076
Dantesboyz
recovering e36er
Dantesboyz's Avatar
Is it possible something came loose on the inlet side like the vent return line?
Dirty MAF, maybe filter oil on it?
Just the first couple things I'd check...
      03-25-2024, 11:04 PM   #4077
Aplatosz
Checked all hoses and connections, read the codes again and these were the exact ones, injection shut off was a new one that I started experiencing
Looked into my spark plug hole to the best of my ability and saw a little bit of black fluid on the piston along with the piston looking darker than the others but spark plug was clean
Going to check out injectors tomorrow an if I can’t find anything, time for a compression test
      03-26-2024, 11:50 AM   #4078
Krisztian93
Yes i have knock low rpm,, and also boost pressure target 17 psi or so and car only holds 16.5 or so… The air intake pipe that connects to the turbo there is little leak i see oil residue the o ring bad can that cause this?
      03-27-2024, 09:17 AM   #4079
g340ix
Drives: 2017 BMW 340i xdrive
there is no knock shown on your logs, just very minor timing corrections, it also looks like you're not flooring it until 3,800 rpms
      03-28-2024, 06:01 AM   #4080
Lenny5409
Drives: BMW F31 340i 2017
I'm experiencing some issues with my tune (MHD stg2+, or stage2 hpfp as they call it) The logs don't look good at all when running E40, it looks way better when i tested running on "normal" fuel (RON98)
I recently installed MHDs flexfuel sensor so these are the first runs with the sensor, what could be wrong/ should I do diffrently?
Mods & info:
MHD software + flexfuel sensor
4,5'' VRSF downpipe
TU HPFP
xHP stg3
Sparkplugs changed about 5000km ago
Run 1:
https://datazap.me/u/lenny5409/stage...51-52-53-54-62
Run 2:
https://datazap.me/u/lenny5409/run2-...51-52-53-54-62
      03-29-2024, 04:27 AM   #4081
Krisztian93
Aham and what you guys think about boost pressure ? Is it boost leak?
The Airfilter pipe thats goes to the turbo i have there slight oil residue , this o ring is bad can this cause boost leak?
If you check my log it cant keep the target boost
13718648429
      03-30-2024, 02:14 PM   #4082
muumio
Drives: M140i xDrive
Hi!
Hopping in to tune my B58 (gen1) and before going further is there something alarming on this log? Sadly I forgot to record with lower octane map and also forgot to flash xHP map before test runs..
For now everything is stock except K&N air filter. Spark plugs (NGK) are changed recently but I have no clue how old ignition coils are. One says renew after xxx km, one says renew if misfires so is it suggested to renew them just in case? Error logs are clean. DP, charge pipe and intake pipe will be replaced later when I have time. No plans to go further than stage 2.
https://datazap.me/u/muumio/mhd-stage-1?log=0&data=5-22
      03-31-2024, 06:36 AM   #4083
JonasM40i
Drives: BMW X3 M40i LCI
Here is my first custom mhd map log after upgrading the turbo (Turbo Systems Stage 2) and the hpfp.
https://datazap.me/u/arminatz/upgrad...og=0&data=4-24
Next week I will get a higher flowing downpipe. At the moment I have a 300 cell HJS dp and so I am limited in power output.
But for the basemap its quite good in my opinion.
      03-31-2024, 06:38 AM   #4084
JonasM40i
Originally Posted by muumio View Post
Hi!
Is that the stock map? The timing corrections are not looking good in my opinion. I would not get up in power. Which fuel is in it?
      03-31-2024, 07:23 AM   #4085
muumio
Oh, I though that info can be seen via link. MHD stage 1 98 map and fuel is 98.
      03-31-2024, 07:56 AM   #4086
JonasM40i
Ah ok, sorry, didn't see it.
As I said, in my opinion too much timing corrections.
I would try the 95oct map and see, if there are less corrections.
      03-31-2024, 12:13 PM   #4087
mzgourovski
Drives: 2016 BMW 340i f30
Hello all,
I am having some timing correction issues, and think that my fuel pump is crashing. Can someone please take a look at my data logs?
Its a gen 1 b58 with a stage 2 93 octane MHD map. (always get fuel from buc-ees)
(I have a TU pump at home waiting to be installed, is this my sign to install it?)
3rd gear pull
https://datazap.me/u/crispynapkin/3r...&data=21-22-24
4th gear pull
https://datazap.me/u/crispynapkin/4t...&data=21-22-24
TIA!
      03-31-2024, 12:19 PM   #4088
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
492
Drives: BMW 340i xDrive
Originally Posted by mzgourovski View Post
Hello all,
3rd gear pull
4th gear pull
TIA!
If it crashes you'll know due to backfiring but you're getting awfully close to crashing. Yes its time to install the tu pump.
Dustin Braun @ Braun Performance Tuning
      03-31-2024, 12:44 PM   #4089
mzgourovski
Yup, the other day, I had a scare that it backfired and lost power. Scared me to death, but then drove like normal again. Sounds like it crashed then.
Thank you!!!
      03-31-2024, 09:12 PM   #4090
Dantesboyz
recovering e36er
Dantesboyz's Avatar
https://datazap.me/u/dantesboyz/dorc...47-48-49-57-62
First log with the new Dorch DS25-250 installed
Running a nice e50 mix on MHD e40 map
Did a few pulls and so far results seem repeatable
The fuel lines Dorch sent me to fit my existing ECA we're a perfect fit 👌
      04-01-2024, 02:03 AM   #4091
virus_art
Drives: Bmw 340i xdrive
Hi! Could you guys please check this 4th gear pull log?
Is the timing correction acceptable or...?
I want to know if the numbers are fine or should i go with stage 2 91octane?
Stage 2+ 93octane map
https://www.bootmod3.net/log?id=6607...efb514fd3c14f1
2018 240i xdrive automatic
Catless dp and bosch tu hpfp.
      04-01-2024, 08:09 AM   #4092
DieselDuck
DieselDuck's Avatar
86
Drives: BMWB58
It's fine
