02-20-2016, 07:08 AM | #9990 |
Rep 40,666
You cannot send or receive PM''s yet. Send me one when you can.
02-20-2016, 11:15 PM | #9992 |
Rep 1,771
Hey Shawn, i've had my F32 for a year now and I decided to get some coding done because it looks fun and the options that can be coded look pretty cool. Can you send me all the necessary links and downloads I need to get started? Much appreciated!
David
Instagram: @dg_g20
02-21-2016, 03:33 AM | #9993 |
Rep 40,666
PM sent.
02-21-2016, 09:40 AM | #9994 |
Rep 4
most up-to-date software
shawnsheridan....from the looks of it, you've been sending PMs containing the link to the software for years. Just wanted to see if I can get the link as well. I've tinkered with the idea of whether or not I would try coding my car (2015 F30 335i M Sport), and i've made my decision to go ahead and give it a go. Thanks.
02-21-2016, 01:47 PM | #9995 | |
Rep 40,666
02-21-2016, 05:55 PM | #9996 |
Rep 3
Dear Shawn,
Also I want to change settings of my car, so could you send me all the necessary links and downloads I need to get started? I am terribly sorry to inconvenience you, but I appreciate your correspondence. Best Regards |
02-21-2016, 05:57 PM | #9997 |
Rep 40,666
PM sent.
02-21-2016, 06:01 PM | #9998 |
Rep 1,236
I have this really weird problem, if someone can help me out I would really appreciate it.
I downloaded and installed all the software and coded my car once successfully. When I went back to code my car again I could not connect. I would not get any connection for ethernet on windows and e-sys would say connection via vin not possible. Nothing seemed to fix this. I then installed everything on my other laptop and was able to code again. But it only worked one time. The second time I tried to connect I got the same problem again. Does anyone know why I am only able to connect one time, then not being able to connect at all? I've tested this with 2 different cars, and I was only able to connect to 1 car once, then no connection to either car works. |
02-21-2016, 06:35 PM | #9999 | |
Rep 157
02-21-2016, 09:27 PM | #10000 |
Rep 1,236
02-22-2016, 12:46 AM | #10001 | |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
run CMD.exe as administrator and run the following lines Code:
netsh winsock reset netsh int ipv4 reset
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
02-22-2016, 01:20 AM | #10002 |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
02-22-2016, 07:36 PM | #10005 |
Rep 232
Hey Shawn, I have had my F30 for a little while and I want to get some coding done because the "improvements" seem pretty awesome! ( I Cant stand auto start stop) Can you send me all the links and downloads I need to get started? Thanks so much!!
02-22-2016, 10:03 PM | #10006 |
Rep 3
Drives: 2014 BMW 328i
Hi Shawn, could you please send me the links to download the software and data files...I want to enable enhanced bluetooth on my F30 (2014 328i) ,not getting the link anywhere in the forum, thanks for your help!!
02-23-2016, 12:39 AM | #10007 | |||
Rep 40,666
02-23-2016, 02:42 PM | #10009 |
Rep 39
I have a 2016 3Touring with navigation and was wondering if there is a way to use the GPS system to display MPH [I am Canadian and my speedometer only shows KPH]? My smartphone navigation app shows speed in either metric or US calculated by its GPS. Is there a coding that will display speed? My car can display MPG or L/100KM, as well as miles or km driven, so the data is there somewhere.
Any help with this is greatly appreciated since I drive in the USA a lot and have to quickly multiply by .6 to know my current MPH. |
02-23-2016, 05:18 PM | #10010 | |
Rep 40,666
