BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Heated Steering Wheel Function Retrofit discussion and sharing
      07-29-2018, 07:00 AM   #199
Hawko
Drives: F36 435D 2019
Originally Posted by blackdevil View Post
Hi, thinking about doing this retrofit and have a question.
The control unit has 2 connections with white surrounds, the 2 pin goes to the lane departure and the 4 pin goes to the heater pad, the steering I've seen only has 2 pins coming out of the heater pad, is this the right steering wheel ? If so, what are the 2 other pins from the control unit for ?
Thanks in advance.
The steering wheel should have 4 wires
There are 2 connections for power the other two are for the thermal switch.
If you look at the picture below it shows my steering wheel connected to the control module.
      07-29-2018, 11:23 AM   #200
blackdevil
Drives: X5
Looks like the steering wheel I was looking at is not heated, it has the Hands on Detection which is a 2 wire connection.
Thanks.
      08-11-2018, 09:07 AM   #201
FBMWWINS
FBMWWINS's Avatar
604
Drives: M8C Coupé & M240i Coupé
I had an original an M4 steering wheel WITH heating retrofitted on my F32 435i. I coded VO, wrote to ECU and ensured the following parameters be set as such:
CODDT_BYTE_00_SZL_LIN = LHZ_aktiv
LIN_VARIANTE_LRE = lre_tlc_lhz
LIN_VARIANTE_SZL = szl_4Band
LRE_Verbaut = aktiv
Unfortunately the LED light of the button does not light up. The kombi shows steering wheel heat is ACTIVATED (when button pressed) but the wheel does not heat up.
Have I forgotten some steps? Missing some coding options perhaps?
Any input is very appreciated. Thanks
      08-12-2018, 04:49 AM   #202
Hawko
Can you check for power at pins 1 and 4 on A83 4B ? this is assuming you are not using the airbag connector spare pins.
If using the airbag pins check you definitely have power on them.
Can you check for error messages with E-Sys - I had wrong SZL message
      08-12-2018, 11:42 AM   #203
FBMWWINS
FBMWWINS's Avatar
604
Hi Hawk,
thanks for your suggestions. I wanted to check for errors with ISTA+ but unfortunately my version on the laptop is somehow corrupt and cannot open the program.
Of course it could be it's not getting power as the button does not light up. In fact only a short message appears in Kombi "steering wheel hear activated" but nothing happens for the rest... and no LED tells me it's like "dead". As for the pins I would have to go back to a local specialist here who mounted it for me.
I will see that I get ISTA reinstalled. I use E-SYS only for coding not sure how you can see errors there. I can say that during coding I had no errors - all went fine and smooth. In a German forum someone suggested coding all ECUs of the car? I was advised to do FEM_BODY, ICM and KOMBI that should suffice.
      08-18-2018, 03:16 PM   #204
FBMWWINS
FBMWWINS's Avatar
604
So finally I had a specialist look at it today (someone who really knows the WIRING stuff of any BMW) and he figured out almost immediately that one wire had not been connected at all and turned out to be the decisive one! Once he connected it, the LED light of the button lit up upon turning on and the wheel itself began heating up! The mechanic dude who mounted it for me last week omitted such a vital connection..... I will ask him for a refund as I'm still very upset!
Good news for myself I added S248 in FA and the options I coded stood correct and I didn't make any mistakes there. That is what I doubted at first. Well it's all good now. Thanks to those who replied here.
      09-03-2018, 05:30 PM   #205
vadimo
vadimo's Avatar
Drives: 2014 F30 320D X-Drive
2020 M340i  [0.00]
where does the 3' F30 320dX Switch, steering wheel heater fits in? does it plug in somewhere locally as its a very short fly lead or does need extending?
https://www.realoem.com/bmw/enUS/sho...diagId=61_2819
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
      09-03-2018, 05:36 PM   #206
obert
obert's Avatar
Drives: 2013 328i
It fits on the bottom part of the steering wheel column cover
      09-04-2018, 03:48 AM   #207
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
The switch plugs into the szl column module just behind the trim covers.
vadimo310.00
      09-04-2018, 04:51 PM   #208
vadimo
vadimo's Avatar
2020 M340i  [0.00]
thanks guys^
i been looking at Switch unit steering column
https://www.realoem.com/bmw/enUS/sho...59#61319351144
i found it confusing where same part number has different arrangements, i.e. 61319351146 which shows Steering wheel heater = Yes but same part number further down shows Steering wheel heater = No
Confusing
      09-12-2018, 10:17 PM   #209
jaydaman93
Drives: 2016 bmw 328i xdrive
Can someone help me figure out what part numbers i need for a heated steering retrofit for my 2016 328i. I have the sportline steering wheel with vibration and paddles. I bought a sportline steering wheel with vibration and paddles and heated through ebay. I am still waiting but im trying to figure out what else i need. I know i need the button and the trim. I also need a connecting cable and a control unit? I cant seem to figure out the control unit part number i need. Everyone has the m sport control unit. Is it the same part number for the sport line steering?
      12-11-2018, 06:54 PM   #210
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
LRE_Verbaut = aktiv
I've seen these variables using EXPERT MODE in bimmercode. Can you detail what each means? Under LinSteeringWheel in the FEM, I could only understand one var and it was the cycle time before the heated steering wheel turns itself off.
My car already came with heat and vibration coded for the steering wheel. It stopped working last week. I only have bimmercode and would like to deactivate the heat module, and then reactivate it, as sort of a pseudo-hard-cycle. If this doesn't make it again I guess I will have to find ISTA for my Mac and buy a cable.
      12-12-2018, 09:48 AM   #211
FBMWWINS
FBMWWINS's Avatar
604
Hi,
this is how you can sum them up:
LHZ (Lenkradheizung) ist the German abbreviation for heated steering wheel.
SZL (Schalt Zentrum Lenkrad) is the Switch cluster steering column
LRE (Lenkrad Elektronik) is the Control unit, steering wheel electronics
LIN = Lin Bus (LRE is connected at LIN)
LIN_VARIANTE_LRE = set with the lre_tlc_lhz parameter if car as Lane departure warning (Vibration) und heated steering wheel
      12-12-2018, 05:19 PM   #212
Logicoeur
Logicoeur's Avatar
991
Hi,
THANK YOU KIND SIR! I had found that variante setting when sifting through the expert mode options. Coding the module inactive and then active WORKED! Steering wheel is toasty again!
      12-13-2018, 02:32 AM   #213
FBMWWINS
FBMWWINS's Avatar
604
Glad it worked out.
      02-04-2019, 06:20 PM   #214
Ferryh
Drives: BMW F30
Hi, im planning to retrofit my f30 with heated steeringwheel. I already have a heated wheel installed but have a couple questions. I have a "normal" szl without vibration or heating functions. So can i plug the switch (to enable heating) in the szl without problems? My + and - will be tapped out cigarette lighter and will be placed in pin 1 and 3 of airbag connector. Thanks for any help
      02-05-2019, 08:18 AM   #215
doughboy
doughboy's Avatar
1545
I'm not sure, I did this mode on my F06 M6GC (same as F10 chassis). Mine had power adjust steering column and the button for this uses the same socket on the SZL as the heated wheel button does, so the socket was good to go.
I don't know on F30 if you will even have the socket pinned out to receive the heated wheel button if the SZL was specced without it.
Sorry I can't be more helpful.
      02-06-2019, 03:30 PM   #216
Hawko
Ferryh
See the very first post - this gives you the part numbers of SZL that does and does not support steering wheel heating. Even though an SZL may have the socket for connection of the switch as doughboy says it may not be pinned out.
      02-06-2019, 03:51 PM   #217
Simon89
Simon89's Avatar
Drives: F30 330D XDrive
Is there a definitive but concise list of what is required?
There are a lot of part numbers kicking about!
13' F30 330D XDrive
      03-07-2019, 05:07 AM   #218
doughboy
doughboy's Avatar
1545
I'm selling the parts to add heated wheel to an F10 & F06 5 & 6er.
https://www.ebay.co.uk/itm/173825904989
All but the on/off switch is the same for an F30.
Also 2 bespoke looms, 1 to get from clock spring to heater controller module and one to get power from armrest cigar lighter to back of clock spring.
Needs coding of course, this is £300 of parts for £99 "buy it now"...
:thumsbup:
      03-12-2019, 07:09 PM   #219
AZ-M007
Drives: BMW F30
I am selling Heated steering wheel without airbag
https://www.ebay.com/itm/293000364437
It’s m sport heated steering wheeelwithout airbag.
      03-13-2019, 03:30 AM   #220
doughboy
doughboy's Avatar
1545
Still for sale - £10 bid only at the monent...
My wheel has sold, but the parts and looms to add it are on ebay:
LIN Heater controller (in wheel one)
Heater switch (for M5 or M6)
Wheel loom for heating
Supply loom to add plug into SZL
Loom to take from airbag socket wheel side and connect to heater controller.
Check part numbers as listed..
Thanks..
f30, heated, heating, steering, wheel
