BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Projector Angel Eye Headlights!
      08-30-2018, 09:19 AM   #1827
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Originally Posted by andyt26 View Post
What does that mean lol. Got a link to what you’re running?
Means that they are pushing the power of a 55W bulb to a 35W bulb which causes it to overheat and burn the projector. These bulbs are true 55W setups and won't burn. Not saying there aren't others out there but I've been happy with these so far:
http://retro-solutions.net/product-i...IT-pid664.html
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      09-01-2018, 12:48 AM   #1828
Craven_01
Drives: 2013 F30
Has anyone been able to get a clean beam cutoff? I adjusted the bulb position to center the hot spot but this is the best I can get it l. The first picture is the left headlight. The second on is the right. Third picture is both headlights.
      09-08-2018, 05:12 PM   #1829
akhenat0n
Drives: BMW 320i 2014
What is the best place to get the DEPO angel eyes for a 320 2014 ? They seem to be backorder on every site I check
      09-09-2018, 07:16 AM   #1830
akhenat0n
Will these fit north america models? Seems to be the only option I found...
https://www.schmiedmann.com/en/produ...oduct=FLXF3031
      09-10-2018, 09:27 AM   #1831
akhenat0n
I contacted them and they said: Yes these should fit no problem, however they are intended for euro versions.
Should I be worried about "not intended for but should fit" ?
Anyone ever installed those on US models?
Thanks!
      09-13-2018, 09:23 AM   #1832
Craven_01
Drives: 2013 F30
Thanks!
They will fit but the beam pattern will be different.
      09-17-2018, 02:40 PM   #1833
Flro2131
Drives: 2017 bmw f30 320i
Hello,
I current own a 2017 bmw 320i with stock halogen light and I want to replace it with retrofit Lci headlight. The retrofit headlight are for 2015 models, but aren’t all bmw headlight unit the same size? So, it should be able to fit fine.
      09-21-2018, 12:43 AM   #1834
andyt26
Drives: 2015 BMW 335i Msport
Anyone know where I can replace this part? The shop I took it to glued the adapter for my LED bulbs onto that part and now I can’t get it off -__- just emailed USR but in case they don’t offer a replacement for that part I want to know what else I can do to replace that part.
      09-21-2018, 09:18 AM   #1835
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I'm not sure you can honestly. Just get some solvent and remove the glue.
      09-21-2018, 09:23 AM   #1836
obert
obert's Avatar
Drives: 2013 328i
Originally Posted by Flro2131 View Post
Hello,
Same so you should have no fitment issues.
      09-24-2018, 11:37 PM   #1837
andyt26
Anyone know which bulb clips I can buy that will work with Morimoto HID’s and these headlights?
      09-25-2018, 05:14 PM   #1838
akhenat0n
USR finally got the lights in stock, just ordered them. I went through a lot of pages in this thread, there's a lot of info lol... I don't know if someone with the info could just quick reply my question.
What the most common lightbulb used with these lights? Just bright halogens?
Thanks
      09-26-2018, 08:58 AM   #1839
Craven_01
Drives: 2013 F30
Thanks
Before I installed a HID kit, I had H7 Phillips Diamond Vision. It's whiter than stock halogens .
      09-26-2018, 09:37 AM   #1840
akhenat0n
Thanks for the info. What HID kit did you install? Is it worth it or the angle eye is sufficient for the look?
      09-26-2018, 10:55 AM   #1841
Craven_01
Drives: 2013 F30
I think it's worth it to upgrade to a HID kit. I installed DDM Tuning Ultra Canbus HID kit with 5500K bulbs. The output is definitely brighter halogens. Others have used The Retrofit Source H7: MORIMOTO ELITE kit. With either kits you'll have to use H7 bulb adapter. I had trouble with the bulb positioning. If you plan on going this route, install the HID bulb before your install the headlights.
      09-26-2018, 10:57 AM   #1842
Craven_01
Drives: 2013 F30
The Retrofit Source has the bulb clips for the Morimoto HIDS.
      09-27-2018, 12:02 PM   #1843
akhenat0n
I will receive my DEPO angel eyes tomorrow and I think I will go with the HID option for the bulbs. I did a lot of research and ended up with that:
HID Parts
H7 HID Adapter : https://www.theretrofitsource.com/h7...ros-49083.html 10$
H7 Morimoto HID Bulb: https://www.theretrofitsource.com/hi...to-xb-hid.html 40$
H7 35W Canbus: https://www.theretrofitsource.com/ba...anbus-35w.html 90$
Total: 150$
      09-27-2018, 12:51 PM   #1844
jlorenzo125
Drives: 320i Sportline
HID Parts
Total: 150$
Where did u purchase the depo lights? I got mine from an ebay vendor and installed em last night. My bulbs are GP Thunder 5800K Super Bright White H7 halogen bulbs.
      09-27-2018, 12:58 PM   #1845
akhenat0n
Got them on https://uniquestyleracings.com
      09-27-2018, 07:28 PM   #1846
jdrew
Drives: 2006 330xi
Noob here. First timer to BMW. - looking for cliff note version.
The DEPO headlamps is just the housing along with the "angel eyes". No bulbs correct? What bulbs? Can LED fit? Why on earth will this throw a code?
I dont think i have been this confused upgrading headlights before.
      09-27-2018, 07:38 PM   #1847
jlorenzo125
Depo headlights are the whole unit, with led drl "angel eye" rings built in, but halogen bulbs in the projector lenses. High beam is halogen bulb as well. Bulbs are included.
Some people place LED or hids of their own replacing the halogens that come with the depo units. This could throw an error code due to our cars having the can-bus bullshit in our cars. (Google can-bus for further explanation on that.)
Hope that helps.
-before upgrading to depo units, I had LED bulbs in my oem headlamps replacing the halogens and never got an error code. I bought specific leds that claimed it would not throw an error code, and they never did.
      09-27-2018, 07:55 PM   #1848
jdrew
Drives: 2006 330xi
So.....if I want the halo ring/angel eye look I go with depo units (or equivalent) and then get good bulbs. If I just want to be able to drive at night I can just get good bulbs.
Can I ask what LED did you have?
