BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > Xdrive tire sizing question
      05-21-2020, 10:21 PM   #1
DS8_photo
DS8_photo's Avatar
644
Drives: 2018 330i M sport wagon
So I'm picking up a set of OEM 437m wheels tomorrow and I have a question about tire sizes. Both options are within 1% of each other (front to rear) in overall diameter. What I want to know is does it matter how much taller the tires are then the stock ones. The sizes are listed below so let me know your thoughts. Both options have the same front which is 0.4" taller then the original tire. Option 1 is 0.3" taller and option 2 is 0.6" taller then the original rear. Will that be a problem or is the only controlling factor the front to rear ratio that needs to be within 1%? Which both of these options are.
Current:
Staggered 18" style 398 Orbit Grey wheels
Front 18 x 8 with 225/45/18
Rear 18 x 8.5 with 255/40/18
Option 1:
OEM 437m whels
Front 19 x 9 with 235/40/19
Rear 19 x 10 with 265/35/19
This option is -0.4%
Option 2:
OEM 437m whels
Rear 19 x 10 with 275/35/19
This option is +0.8%
      05-22-2020, 12:29 AM   #2
alohasurftoad
option 2 is 0.8% front/rear diameter difference, fine for x-drive. a little more forward rake than option 1 but not much. a lil more understeer due to 40mm front/rear width stagger, but you may not notice or care.
personally, i like option 1. gaps are even, 30mm front/rear width stagger. more balanced appearance.
few have said you need to remain near the oem diameter of 26", however i've seen members run 0.8" over without issue. imo the 1% front/rear diameter difference is all that matters.
      05-22-2020, 09:46 AM   #3
DS8_photo
DS8_photo's Avatar
644
That's what my understanding as well. Thanks
      05-22-2020, 10:04 AM   #4
alohasurftoad
F30 x-drive, stock height,with 235/40-265/35 on OEM 437M.
https://f30.bimmerpost.com/forums/sh...&postcount=181
Best 437M thread. Many with x-drives. Read please read, if you have time.
https://f30.bimmerpost.com/forums/sh....php?t=1020367
option 3: 245/35-285/30, 0.4%, increased gap due to slightly smaller diameters, better if lowered.
https://f30.bimmerpost.com/forums/sh...&postcount=291
option 4: 255/35-265/35, 1%, reduced understeer
https://f30.bimmerpost.com/forums/sh...&postcount=265
DS8_photo643.50
      05-23-2020, 10:40 AM   #5
ryanf30
Drives: BMW 340
recently purchased the 437M wheels for my 2014 BMW 328i XDrive .
The wheels came directly off an M4 with the OEM Specs
255/35/19 19x9 ET 29
275/35/19. 19x10. ET 40
I understand this will not work with the XDrive system so I decided to square the set and bought 2 more 255/35/19 to match the front
My question is, Am I safe with this set up? Not sure how much my offset has changed with moving down the rear size from 275/35/19 down to 255/35/19 . I've noticed my EPS seems to be heavy one second then lighter the next. Is this incompatible with the F30 X-Drive?
Notes-
Stock suspension
Not lowered
Any feedback would be greatly appreciated!
      05-23-2020, 07:22 PM   #6
DS8_photo
DS8_photo's Avatar
644
Notes-
Stock suspension
Not lowered
The only issue I see is your rear tire will look stretched on a 10" wheel compared to the front. Other then appearance I don't see any issues with your setup.
