BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Squeaky Rear End
proTUNING Freaks
      03-12-2018, 05:06 PM   #23
teaston
Drives: X3 M40d
Originally Posted by Aaron187 View Post
Yep coming from the rear right wheel, Strangely I only noticed this after getting my car washed. Really interested to know what the problem is.
It is very strange, i’ve never had this from any of my BMW’s including ones that have done well over 100k! A couple of them had a very similar squeak from the rear when getting in and out of the car though.
      03-12-2018, 05:19 PM   #24
Aaron187
Drives: F82 M4
Let me know the outcome if you get it checked out before me, Best of luck
      03-12-2018, 05:49 PM   #25
RoShambolt
RoShambolt's Avatar
351
Drives: Looking
Originally Posted by RoShambolt View Post
Just out of interest, have you tried pushing on the boot to replicate it with the car on level ground with the handbrake off?
No, what would that do?
I've had the car squeaking a lot lately getting in and out with the handbrake on, I have read in the manual about every so often driving off with the handbrake applied slightly to stop corrosion and asymmetrical braking, so was interested if it was any worse with applied or not. Maybe something sticking, or a corrosion build up after the increase in salt on the roads lately. Reading your further posts it seems unlikely though.
      03-12-2018, 05:50 PM   #26
teaston
Drives: X3 M40d
I did use my handbrake a fair bit in the snow! And did some doughnuts in Tesco car park! I wonder if one of those things are to blame!
      03-13-2018, 03:57 AM   #27
Smee
Smee's Avatar
505
Drives: BMW M4 F83
go get a can of lube and go spray all the joints. will take you a few seconds
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit
      03-13-2018, 04:16 PM   #28
RoShambolt
RoShambolt's Avatar
351
Drives: Looking
Surely blasting around helps to loosen everything up!
      03-13-2018, 04:24 PM   #29
M2Rush
Drives: 2014 BSM 335i x-drive
Bring it in... mine had the same problem, when I push down the boot it started creaking. It's likely the top bushing(like mine) but it's possible that it's the bottom. It's covered under warranty don't stress out. It happened to the rear passenger and I got it fixed but then 2 weeks later it's the driver side rear now... guess I gotta make another trip.
It's happens to many f30 owners but not enough for BMW to care.
      03-13-2018, 05:41 PM   #30
DriveS
Drives: F30 335d
Thats how I used to solve the noises on my old E92. Would come back after a few months though and I was never certain where it was coming from as there are so many joints!
      03-14-2018, 05:52 PM   #31
teaston
Drives: X3 M40d
Well i took the wheel off and was able to locate the noise to one of these two inner control arm joints so i've soaked them in WD40. It hasn't fixed the squeak yet but i'm hoping it will penetrate into the joints over night!
      03-16-2018, 04:27 PM   #32
Smee
Smee's Avatar
505
Drives: BMW M4 F83
that will be them. wd40 isnt the best stuff youd need half a can probably
how was it today?
      03-16-2018, 04:30 PM   #33
teaston
Drives: X3 M40d
how was it today?
It hasn't made any difference unfortunately, another trip to dealers is in order!
      03-28-2018, 03:39 AM   #34
teaston
Drives: X3 M40d
So it turns out it was actually a Lola rose joint which I guess is the ball joint below the hub.
As an added bonus they also did a full wheel alignment which my car was badly in need of after not having one for 55,000 miles!
      03-28-2018, 01:25 PM   #35
Norris-wf
Drives: f31 335d
Thanks for posting back what it was. Was it all covered under warranty? Must be great not having to listen to it creaking now again
      03-28-2018, 01:54 PM   #36
teaston
Drives: X3 M40d
Yes all warranty, including the £150 worth of wheel alignment!
      04-07-2019, 02:15 PM   #37
denz
Drives: 2015 BMW 330xi
I have a 2014 330i xDrive and have the exact same problem you mention. The squeaking only comes from the rear right suspension. May I ask what a "Lola rose joint" is? Would you have the part number? Thanks.
      04-07-2019, 02:32 PM   #38
teaston
Drives: X3 M40d
No idea what “Lola” is! A typo of lower probably.
Looks like probably part 3 here:
      04-07-2019, 03:51 PM   #39
Pequin
Pequin's Avatar
Drives: Enthusiastically
Interesting, is yours also coming from the rear right wheel well?
Mine too, odd. Last time they had it the told me it was the bushings and replaced the somethings but it still squeaks.
335D EB LCI - Debadged
      04-08-2019, 09:28 AM   #40
willjames
willjames's Avatar
Drives: G01 X3 3.0d M Sport
its common on most cars. the joints on the suspension arms need greasing or spraying with lube
my old Ibiza was terrible for it!!
You think I should put lube in my rear end??
Finbar Saunders and his double entendres
teaston10994.50
      06-14-2019, 07:13 PM   #41
GAAEcuador
Ecuador
Drives: F30 320i 2018
Same Screeching noise from rear right wheel
So my car has 23,000 kilometers on it and has had that horrible screeching noise coming from the right rear wheel since approximately the 14,000 km...ive only had the car for a little over a year, so im still under warranty.
Ive taken it seven times to the dealer and they cant find what it is, they say that due to "my way of driving" (which makes no sense and they cannot prove- keep in mind I drive it for work inside de city), the discs are burnt....
But looking at this forum, and seeing that this problem has been reported in these forums by e90´s and f80 owners, then im thinking there has to be some type of work-orders or recalls, or solutions under warranty for that...
Did anybody find a solution?...the noise doesnt go away....
      06-15-2019, 03:58 AM   #42
teaston
Drives: X3 M40d
If it squeaks when going over bumps or imperfections in the road then it is probably the lower ball joint as shown in my post above.
      06-15-2019, 08:47 AM   #43
Witney
Drives: Tesla Model-Y LR
Same here! My Oct 2017 335D has just been in to dealer to look at a "creaking sound" I was hearing from offside rear when reversing. They have diagnosed and advised the rear ball joint needs replacing. Going back in a week or two to be resolved. Surprising on an 18 month car with 36,000 on clock....
      07-03-2019, 12:59 PM   #44
GAAEcuador
Ecuador
It's more of a metallic noise and it only sounds when pulling away until I pass 25mph...
