07-27-2019, 12:54 AM | #1 |
Rep 13
Base Audio - Speakers only upgrade
Hi Everyone,
Speakers on my 7-year-old F30 have aged and needed to be replaced. I was thinking about what options I got here? I have installed sub and speakers in few cars (E90, E92) so I'm technically SOUND about this :P Few things I'm thinking about: 1) Buy the same speakers currently fitted and replace them (Least preferred) 2) Buy some good aftermarket speakers with mounts and replace 4 door speakers (Most preferred) 3) Buy some good aftermarket speakers and under-seat sub with mounts and replace all 6 speakers. (Tempting) 4) Buy expensive plug and play speakers (Maybe underseat subs as well) Another concern is will any of this provide some good difference in sound without putting an amp? Waiting for your suggestions here Also interested if you know good plug and play brand worth buying Thanks in advance. |
07-27-2019, 12:59 PM | #5 |
Rep 23
Me again... What about a set of tweeters? You need to get units that are high pass filtered and you could tap into the lines going to the door speakers.
To me, if you are on a budget the biggest improvement for your money would be tweeters. |
07-27-2019, 02:07 PM | #6 | |
Rep 10,473
07-27-2019, 10:33 PM | #7 |
Rep 13
07-27-2019, 10:34 PM | #8 |
Rep 13
07-27-2019, 10:35 PM | #9 |
Rep 13
Thanks for the suggestion, my car got base audio-only so two speakers at the front and two at back only. I would rather look into putting up a amp
07-27-2019, 10:45 PM | #10 |
Rep 10,473
07-27-2019, 11:22 PM | #11 |
Rep 13
07-28-2019, 06:23 AM | #12 | |
Rep 2,180
I would suggest the OEM Alpine amp/speaker kit as an upgrade.
07-28-2019, 01:56 PM | #13 |
Rep 16,088
There's very little out there in replacement speakers that are worth the money. These seem to be, but availability outside of the US is probably spotty.
https://www.parts-express.com/grs-b1...odels--292-490 |
07-29-2019, 12:48 PM | #14 |
Rep 12
SoundstageDSP™
Hi Everyone,
After reading through the convo here I thought it would be appropriate to chime in. We have a Plug-in-Play package that comes with: -Soundstage™ Series 3-way Front Speaker Package (MIDS + TWEETS+UNDERSEATS) -Custom Crossovers with Vehicle-specific Acoustic Tuning -Integral Audio® Phantom™ Subwoofer System (PSS-F30) [Optional - select option above] -Amplifier by ARC Audio, Class-H delivering 75W per front channel and 250W to subwoofer -SMARTConnect™ plug-n-play wiring harnesses -Custom Mounting Brackets & Adapters 100% Complete Kit - Everything you need - down the last screw. This package was made specifically for your vehicle and we are offering it at a very big discount as we prepare to roll out the newer version for the more recent F series. Here is a link to check out and I'd be happy to hop on the phone with you to answer more questions! https://integralaudio.com/soundstage...eries-f3x.html Cheers, Last edited by Trey @ Integral Audio; 07-29-2019 at 12:54 PM.. Reason: Grammar |
base audio, speaker, upgrade |
