12-15-2019, 08:34 PM | #2 | |
Rep 1,067
12-15-2019, 10:46 PM | #3 | |
Rep 5,399
I've got a '15 335i xDrive. Getting moderate drop springs is pretty straight forward for my model. I had the two choices below: Eibach Springs: Front drop 0.8", Rear 0.6". Gets rid of some of xDrive reverse rake where front wheel gap is more than the rear. About 10% stiffer than stock. Dinan Springs: 0.75" all around so doesn't change reverse rake. About 30% stiffer. There are other spring sets that drop 1.5" or more. People do it but it puts stress on the front xDrive suspension that isn't designed for it. Some include H&R, and a different Eibach part number. Your car may have different options. The more that you drop a car the more you need to be concerned about the shocks being designed for the shorter piston travel. A lowered spring set can quickly destroy stock shocks as they bottom out all the time. For my car, Koni Special Active Shocks work well with moderate drop springs. I have Eibachs. Other shocks that are designed for dropped springs include Koni Sport Yellow (which are adjustable for ride quality) and Bilstein B8's which have just one setting done at the factory. If you have an xDrive with the adaptive suspension, many guys have installed the moderate drop Eibach Springs and like them. Search for forum posts from Farkle! He puts out great information about springs, shocks and bump stops. Hope this helps! |
CntryClub007489.50 |
